missypooofdallas
#1 Posted : Sunday, February 10, 2008 3:00:01 PM(UTC)
missypooofdallas
Washer will not spin, but does barely agitate intermittently. There is a strange noise coming from the drain pump. What do you think the problem is?
#2 Posted : Monday, February 11, 2008 12:35:01 PM(UTC)
The first thing I would do is remove the bottom panel, disconnect the hoses from the drain pump and check for a foreign objects inside.
It suppose to be an envelope with the tech sheets behind this panel and if the drain pump is not the issue, then perform troubleshooting as described in the tech sheets.
- The part number for the drain pump is AP2108083
Here are the break down diagrams for the Frigidaire washer Model GLTF1670AS0
Kaanjii
#3 Posted : Saturday, August 29, 2009 12:22:03 PM(UTC)
Kaanjii
I followed Gene's directions and removed the pump. My water was not coming out of the washer (Fridgedaire GLTF1670AS0) and I had that wierd noise when it was on the "final Spin" cycle. Luckily for me it was a small 2 inch nail that had stuck in the pump fan and was preventing the pump from spinning. I saved $100 and it only took 1/2 hour of troble shooting because I went to this forum.
Kaanjii@cox.net
#4 Posted : Saturday, August 29, 2009 3:42:05 PM(UTC)
I'm glad you were able to fix it with no cost to you. Thank you for the feed back.
Maytag Washer Doesn't Complete Spin Cycle (Washer Repair)
by glmoore0001 2/5/2024 6:32:24 AM(UTC)
GE WBSR3140DAWW Does not spin during rinse/spin cycle (Washer Repair)
by nj_999 12/23/2023 3:31:43 PM(UTC)
Whirlpool washer spin cycle towels only problem (Washer Repair)
by kylo67 10/1/2023 5:54:44 PM(UTC)
Noise and wobble during spin cycle in top load Whirlpool washer (Washer Repair)
by Guest 8/19/2023 5:31:59 AM(UTC)
Maytag Maxima front load washer hangs on spin cycle (Washer Repair)
by jcross100 8/6/2023 11:56:11 AM(UTC)
MVWC7ESWW0 - jumps to spin cycle (Washer Repair)
by Guest 7/15/2023 10:08:10 AM(UTC)
Washer banging sides and walks all over when spin cycle (Washer Repair)
by Guest 6/29/2023 6:24:43 PM(UTC)
Kenmore Washer bounces around on spin cycle (Washer Repair)
by JerryCaldwell 6/1/2023 12:44:27 PM(UTC)
Excessive vibration during spin cycle (Dishwasher Repair)
by JerryCaldwell 5/14/2023 9:36:02 AM(UTC)
MAYTAG WASHER NO GOING INTO SPIN CYCLE (Washer Repair)
by Guest 2/27/2023 8:13:04 AM(UTC)
Whirlpool, grinding badly at end of spin cycle (Washer Repair)
by cdestuck 2/6/2023 10:54:05 AM(UTC)
whirlpool lsc8244bq0 agitates during rince and spin cycle (Washer Repair)
by Guest 1/31/2023 12:30:04 PM(UTC)
Loud noise at start of spin cycle that stops once at high RPM (Washer Repair)
by tollisal 1/28/2023 8:48:50 AM(UTC)
washer fills with water at spin cycle (Washer Repair)
by Guest 1/26/2023 1:13:27 PM(UTC)
Whirlpool Washer WTW5105HW1- Loud Spin Cycle- Spring/suspension question (Washer Repair)
by gabeTBP 1/21/2023 6:26:31 AM(UTC)
