Hi there! I have LG washer that worked fine for a few years and lately it has a problem: It does not spin at all and I do hear the motor running. I opened the back and I checked the bolt holding the rotor and it was loose. After tightening it now runs fine in one direction and still making a grinding noise when is changing direction. Any ides? I tried to remove the rotor and I am having difficulty. It turns a couple of turns and then it get stuck. Should it not come loose all the way? Thank you for your input.
