Discuss
Pump or timer
 in
Washer Repair
I replaced the bearings, belt and wax motor. my problem now is when it gets to the drain and spin
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Pump or timer
  #1 (permalink)
Old 09-18-2013, 09:10 AM
Junior Member
Doug51 is on a distinguished road
Default Pump or timer
Model Number: MAH3000AWW   Brand: Maytag   Age: More than 10 years
I replaced the bearings, belt and wax motor. my problem now is when it gets to the drain and spin 1 the timer seems to stop it also shows 124.9 volts to the pump, but there is no pump action, if you manually spin the dial around and if it catches the pump will run and it will spin, it next goes through the next fill and tumble cycle, but when it gets to the first drain and spin2 it again stops and you manually have to spin the dial again and when it catches it will continue to the second drain and spin2 and from there on it will work properly.
I will be grateful for any help as satated before when it goes into the drain and spin1 and drain and spin2 it reads 124.9 volts in the pump but it's not operating
Read more: timer or pump
http://forum.appliancepartspros.com
Related Models
Maytag MAH3000AWW WASHER- HORIZONTAL AXIS
Admiral MAH3000BGW WASHER- HORIZONTAL AXIS
Maytag MAH4000AWQ WASHER- HORIZONTAL AXIS
Maytag MAH4000AWW WASHER- HORIZONTAL AXIS
Maytag MAH4000BWQ WASHER- HORIZONTAL AXIS
Maytag MAH4000BWW WASHER- HORIZONTAL AXIS
Maytag MAH5500AWQ WASHER- HORIZONTAL AXIS
Maytag MAH5500AWW WASHER- HORIZONTAL AXIS
Maytag MAH5500BWQ WASHER- HORIZONTAL AXIS
Maytag MAH5500BWW WASHER- HORIZONTAL AXIS
Maytag MAH55FLBWQ WASHER- HORIZONTAL AXIS
Maytag MAH55FLBWW WASHER- HORIZONTAL AXIS
Maytag MAH6500AWQ WASHER- HORIZONTAL AXIS
Maytag MAH6500AWW WASHER- HORIZONTAL AXIS
Maytag MAH6700AWM WASHER- HORIZONTAL AXIS
Maytag MAH6700AWW WASHER- HORIZONTAL AXIS
Maytag MAH7500AWQ WASHER- HORIZONTAL AXIS
Maytag MAH7500AWW WASHER- HORIZONTAL AXIS
Admiral MAH7550AAW WASHER- HORIZONTAL AXIS
Admiral MAH7550AGW WASHER- HORIZONTAL AXIS
Maytag MAH8700AWM WASHER- HORIZONTAL AXIS
Maytag MAH8700AWW WASHER- HORIZONTAL AXIS
Maytag MAH9700AWM WASHER- HORIZONTAL AXIS
Maytag MAH9700AWQ WASHER- HORIZONTAL AXIS
Maytag MAH9700AWW WASHER- HORIZONTAL AXIS
Frigidaire MAL123P1A1 Wwh(v1) / Room Air Conditioner
Maytag MAL1800AXM MISC / ACCESSORY
Maytag MAL1800AXQ MISC / ACCESSORY
Maytag MAL1800AXW MISC / ACCESSORY
Maytag MAL2000AXQ MISC / ACCESSORY
Maytag MAL2000AXW MISC / ACCESSORY
Frigidaire MAS183P2A1 Wwh(v1) / Room Air Conditioner
Maytag MAT10CSAAL MANUAL, PARTS (WASHER)
Maytag MAT10CSAAW MANUAL, PARTS (WASHER)
Maytag MAT10CSAGL MANUAL, PARTS (WASHER)
Maytag MAT10CSAGW MANUAL, PARTS (WASHER)
Maytag MAT10CSEGL MANUAL, PARTS (WASHER)
Maytag MAT10CSEGW MANUAL, PARTS (WASHER)
Maytag MAT10DAAAL MANUAL, PARTS (WASHER)
Maytag MAT10DAAAW MANUAL, PARTS (WASHER)
Maytag MAT10DAABL MANUAL, PARTS (WASHER)
Maytag MAT10DAABW MANUAL, PARTS (WASHER)
Maytag MAT10PDAAL MANUAL, PARTS (WASHER)
Maytag MAT10PDAAW MANUAL, PARTS (WASHER)
Maytag MAT10PDABL MANUAL, PARTS (WASHER)
Maytag MAT10PDABW MANUAL, PARTS (WASHER)
Maytag MAT10PDEGW MAYTAG LAUNDRY (COMM.EXPORT) (WASHER)
Maytag MAT10PSAAL MANUAL, PARTS (WASHER)
Maytag MAT10PSAAW MANUAL, PARTS (WASHER)
Maytag MAT10PSAGL MANUAL, PARTS (WASHER)
Maytag MAT10PSAGW MANUAL, PARTS (WASHER)
Maytag MAT11CSBKL MANUAL, PARTS (WASHER)
Maytag MAT11MNAAW MANUAL, PARTS (WASHER)
Maytag MAT11MNAGW MANUAL, PARTS (WASHER)
Maytag MAT11MNEGW MANUAL, PARTS (WASHER)
Maytag MAT11PDAAL MAYTAG LAUNDRY (WASHER)
Maytag MAT11PDAAW MAYTAG LAUNDRY (WASHER)
Maytag MAT11PDABL MAYTAG LAUNDRY (WASHER)
Maytag MAT11PDABW MAYTAG LAUNDRY (WASHER)
Maytag MAT12CSAAL MANUAL, PARTS (WASHER)
Maytag MAT12CSAAQ MANUAL, PARTS (WASHER)
Maytag MAT12CSAAW MANUAL, PARTS (WASHER)
Maytag MAT12CSAGW MANUAL, PARTS (WASHER)
Maytag MAT12CSAKL MANUAL, PARTS (WASHER)
Maytag MAT12CSAKQ MANUAL, PARTS (WASHER)
Maytag MAT12CSDAQ MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12CSDAW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12CSDGW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12CSEGW MANUAL, PARTS (WASHER)
Maytag MAT12CSFWQ COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12CSFWW COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12CSLGW MAYTAG COMMERCIAL WASHER (WASHER)
Maytag MAT12CSLWQ MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12CSLWW MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12PDAAL MANUAL, PARTS (WASHER)
Maytag MAT12PDAAW MANUAL, PARTS (WASHER)
Maytag MAT12PDABL MANUAL, PARTS (WASHER)
Maytag MAT12PDABW MANUAL, PARTS (WASHER)
Maytag MAT12PDAGW MANUAL, PARTS (WASHER)
Maytag MAT12PDBAL MANUAL, PARTS (WASHER)
Maytag MAT12PDBAQ MANUAL, PARTS (WASHER)
Maytag MAT12PDBAW MANUAL, PARTS (WASHER)
Maytag MAT12PDBBL MANUAL, PARTS (WASHER)
Maytag MAT12PDBBQ WASHER-TOP LOADING
Maytag MAT12PDBBW MANUAL, PARTS (WASHER)
Maytag MAT12PDCBL MAYTAG LAUNDRY (WASHER)
Maytag MAT12PDCBQ MAYTAG LAUNDRY (WASHER)
Maytag MAT12PDCBW MAYTAG LAUNDRY (WASHER)
Maytag MAT12PDDAQ MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PDDAW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PDDBW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PDDGW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PDEGW MANUAL, PARTS (WASHER)
Maytag MAT12PDLAQ MAYTAG LAUNDRY (WASHER)
Maytag MAT12PDLAW MAYTAG LAUNDRY (WASHER)
Maytag MAT12PDLGW COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12PDSAW MANUAL,PARTS (WASHER)
Maytag MAT12PRAAW MANUAL, PARTS (WASHER)
Maytag MAT12PRAEW MANUAL, PARTS (WASHER)
Maytag MAT12PRBAW MANUAL, PARTS (WASHER)
Maytag MAT12PRDAW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PRSAW MANUAL, PARTS (WASHER)
Maytag MAT12PSAAW MANUAL, PARTS (WASHER)
Maytag MAT12PSAGW MANUAL, PARTS (WASHER)
Maytag MAT12PSBAW MANUAL, PARTS (WASHER)
Maytag MAT12PSDAW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PSLWQ MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12PSLWW MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT13MNAAW MANUAL, PARTS (WASHER)
Maytag MAT13MNAGW MANUAL, PARTS (WASHER)
Maytag MAT13MNDAW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT13MNDGW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT13MNEGW MANUAL, PARTS (WASHER)
Maytag MAT13PDAAW MANUAL, PARTS (WASHER)
Maytag MAT13PDBAW MANUAL, PARTS (WASHER)
Maytag MAT13PNAEW MAYTAG LAUNDRY (WASHER)
Maytag MAT13PNDEW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT13PRBWW MAYTAG LAUNDRY (WASHER)
Maytag MAT14CSAGW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT14CSAWW0 COMMERCIAL AUTOMATIC WASHER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
timer or pump Doug51 Washer Repair 0 09-17-2013 01:52 PM
washer pump / washer timer jwm423 Washer Repair 1 07-26-2010 02:31 PM
new pump and new timer mikey995102002@yahoo.com Washer Repair 1 03-29-2010 01:34 PM
Timer quits advancing and makes electrical chatter noise before pump and spin cycle ScottyB Washer Repair 2 02-17-2010 12:45 PM
Drain pump replaced, now timer stops after wash and will not rinse BeardedDan Washer Repair 1 06-13-2008 11:05 AM
