Discuss
Washer blowing Fuse
 in
Washer Repair
I have a Maytag Washer m# LAT9400ABW that keeps blowing it's fuse. It's happening during the tub fill. I replaced
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer blowing Fuse
  #1 (permalink)
Old 09-13-2013, 10:08 AM
Junior Member
goodchoice is on a distinguished road
Question Washer blowing Fuse
Model Number: LAT9400ABW   Brand: Maytag   Age: More than 10 years
I have a Maytag Washer m# LAT9400ABW that keeps blowing it's fuse. It's happening during the tub fill. I replaced the 1amp fuse with a 2amp and it blew right away. I put a 3amp in just to try (says maximum 4amp) and it ran a load. the next load blew again during the fill. Im hoping that this is a pressure fill switch issue and not the timer but not exactly certain. Any help would be great appreciated. Thanks.
Related Models
Maytag LAT9400ABW WASHER-TOP LOADING
Maytag LAT9400AGL WASHER-TOP LOADING
Maytag LAT9400AGW WASHER-TOP LOADING
Maytag LAT9400DAL WASHER-TOP LOADING
Maytag LAT9400DAW WASHER-TOP LOADING
Maytag LAT9406AAE WASHER-TOP LOADING
Maytag LAT9406AAM WASHER-TOP LOADING
Maytag LAT9406ABE WASHER-TOP LOADING
Maytag LAT9416AAE WASHER-TOP LOADING
Maytag LAT9416AAM WASHER-TOP LOADING
Maytag LAT9416AAQ WASHER-TOP LOADING
Maytag LAT9420AAE WASHER-TOP LOADING
Maytag LAT9457AAE WASHER-TOP LOADING
Maytag LAT9457AAM WASHER-TOP LOADING
Maytag LAT9457AAQ WASHER-TOP LOADING
Maytag LAT9457BAE WASHER-TOP LOADING
Maytag LAT9520AAE WASHER-TOP LOADING
Maytag LAT9520AAQ WASHER-TOP LOADING
Maytag LAT9557AAE WASHER-TOP LOADING
Maytag LAT9557AAQ WASHER-TOP LOADING
Maytag LAT9593AAL WASHER-TOP LOADING
Maytag LAT9593AAW WASHER-TOP LOADING
Maytag LAT9593ABL WASHER-TOP LOADING
Maytag LAT9593ABW WASHER-TOP LOADING
Maytag LAT9600AAL WASHER-TOP LOADING
Maytag LAT9600AAW WASHER-TOP LOADING
Maytag LAT9600ABL WASHER-TOP LOADING
Maytag LAT9600ABW WASHER-TOP LOADING
Maytag LAT9604AAE WASHER-TOP LOADING
Maytag LAT9604AAL WASHER-TOP LOADING
Maytag LAT9604AAM WASHER-TOP LOADING
Maytag LAT9604ABE WASHER-TOP LOADING
Maytag LAT9605AAE WASHER-TOP LOADING
Maytag LAT9605AAM WASHER-TOP LOADING
Maytag LAT9606AAE WASHER-TOP LOADING
Maytag LAT9606AAM WASHER-TOP LOADING
Maytag LAT9606ABE WASHER-TOP LOADING
Maytag LAT9606ABM WASHER-TOP LOADING
Admiral LAT9606AGE WASHER-TOP LOADING
Admiral LAT9606BGE WASHER-TOP LOADING
Admiral LAT9606GGE WASHER-TOP LOADING
Maytag LAT9614AAE WASHER-TOP LOADING
Maytag LAT9614AAL WASHER-TOP LOADING
Maytag LAT9614AAM WASHER-TOP LOADING
Maytag LAT9615AAE WASHER-TOP LOADING
Maytag LAT9615AAM WASHER-TOP LOADING
Maytag LAT9616AAE WASHER-TOP LOADING
Maytag LAT9616AAM WASHER-TOP LOADING
Maytag LAT9634AAE WASHER-TOP LOADING
Maytag LAT9634AAL WASHER-TOP LOADING
Maytag LAT9634AAM WASHER-TOP LOADING
Maytag LAT9634ABE WASHER-TOP LOADING
Maytag LAT9635AAE WASHER-TOP LOADING
Maytag LAT9635AAM WASHER-TOP LOADING
Maytag LAT9700AAL WASHER-TOP LOADING
Maytag LAT9700AAW WASHER-TOP LOADING
Maytag LAT9700ABL WASHER-TOP LOADING
Maytag LAT9700ABW WASHER-TOP LOADING
Maytag LAT9700DAL WASHER-TOP LOADING
Maytag LAT9700DAW WASHER-TOP LOADING
Maytag LAT9704AAE WASHER-TOP LOADING
Maytag LAT9704AAL WASHER-TOP LOADING
Maytag LAT9704AAM WASHER-TOP LOADING
Maytag LAT9704ABE WASHER-TOP LOADING
Maytag LAT9704ABL WASHER-TOP LOADING
Maytag LAT9704ABM WASHER-TOP LOADING
Admiral LAT9704AGE WASHER-TOP LOADING
Admiral LAT9704BGE WASHER-TOP LOADING
Maytag LAT9704DAL WASHER-TOP LOADING
Maytag LAT9704DAM WASHER-TOP LOADING
Admiral LAT9704GGE WASHER-TOP LOADING
Maytag LAT9706AAE WASHER-TOP LOADING
Maytag LAT9706AAM WASHER-TOP LOADING
Maytag LAT9706AAQ WASHER-TOP LOADING
Maytag LAT9706ABE WASHER-TOP LOADING
Maytag LAT9714AAE WASHER-TOP LOADING
Maytag LAT9714AAL WASHER-TOP LOADING
Maytag LAT9714AAM WASHER-TOP LOADING
Maytag LAT9734AAE WASHER-TOP LOADING
Maytag LAT9734AAL WASHER-TOP LOADING
Maytag LAT9734AAM WASHER-TOP LOADING
Maytag LAT9734ABE WASHER-TOP LOADING
Maytag LAT9757AAE WASHER-TOP LOADING
Maytag LAT9757AAM WASHER-TOP LOADING
Maytag LAT9766AAE WASHER-TOP LOADING
Maytag LAT9800AAL WASHER-TOP LOADING
Maytag LAT9800AAW WASHER-TOP LOADING
Maytag LAT9800ABL WASHER-TOP LOADING
Maytag LAT9800ABW WASHER-TOP LOADING
Maytag LAT9800AGL WASHER-TOP LOADING
Maytag LAT9800AGW WASHER-TOP LOADING
Maytag LAT9804AAE WASHER-TOP LOADING
Maytag LAT9804AAL WASHER-TOP LOADING
Maytag LAT9804AAM WASHER-TOP LOADING
Maytag LAT9804ABE WASHER-TOP LOADING
Maytag LAT9806AAE WASHER-TOP LOADING
Maytag LAT9806AAM WASHER-TOP LOADING
Maytag LAT9806ABE WASHER-TOP LOADING
Admiral LAT9806AGE WASHER-TOP LOADING
Admiral LAT9806AKM WASHER-TOP LOADING
Admiral LAT9806AKQ WASHER-TOP LOADING
Admiral LAT9806BGE WASHER-TOP LOADING
Admiral LAT9806DAM WASHER-TOP LOADING
Admiral LAT9806DAQ WASHER-TOP LOADING
Admiral LAT9806GGE WASHER-TOP LOADING
Maytag LAT9824AAE WASHER-TOP LOADING
Maytag LAT9824AAL WASHER-TOP LOADING
Maytag LAT9824AAM WASHER-TOP LOADING
Maytag LAT9824ABE WASHER-TOP LOADING
Maytag LAT9824ABL WASHER-TOP LOADING
Maytag LAT9824ABM WASHER-TOP LOADING
Admiral LAT9824AGE WASHER-TOP LOADING
Admiral LAT9824AKM WASHER-TOP LOADING
Admiral LAT9824BGE WASHER-TOP LOADING
Admiral LAT9824DAM WASHER-TOP LOADING
Admiral LAT9824GGE WASHER-TOP LOADING
Maytag LAT9900AAL WASHER-TOP LOADING
Maytag LAT9900AAW WASHER-TOP LOADING
Maytag LAT9900ABL WASHER-TOP LOADING
Maytag LAT9900ABW WASHER-TOP LOADING
  #2 (permalink)
Old 09-13-2013, 01:47 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
It's not the pressure switch nor likely the timer. Does it matter if you select hot versus cold? Could be a problem with the check switch which is part of the lid switch. The lid switch has a main switch and a check switch. The fuse circuit is designed to blow the fuse if the main switch sticks closed when you open the lid, thus rendering the washer unusable until you repair the lid switch. Yours is blowing during fill with lid closed but still could be a bad check switch. Disconnect the white wire from the lid switch. If it works fine now without blowing the fuse, the lid switch is bad. If it continues to blow, then there's a problem with the water valve circuit. I do not have the exact wiring diagram for your washer, can you provide a clear photo of it?
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag LSE7804ACM Washer Blowing Fuse leadfoot Washer Repair 1 02-09-2012 06:00 PM
Dryer overheat blowing thermal fuse heater box, not vent fuse try2repairguy Dryer Repair 2 11-10-2011 08:27 AM
fuse keeps blowing! painter37 Microwave Repair 1 03-26-2010 09:19 AM
Washer won't work with lid switch in place. Keeps blowing fuse. Larry J Washer Repair 3 09-15-2009 09:37 PM
Fuse inside washer keeps blowing lukedog Washer Repair 1 04-22-2009 03:30 PM
