Discuss
Flashing lights on Whirlpool duet washer
 in
Washer Repair
Originally saw an F then H signal but now lights are continuously flashing on my Whirlpool Duet wash machine. Also,
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Flashing lights on Whirlpool duet washer
  #1 (permalink)
Old 09-12-2013, 04:58 PM
Junior Member
chaucee is on a distinguished road
Default Flashing lights on Whirlpool duet washer
Brand: Whirlpool   Age: 1 - 5 years
Originally saw an F then H signal but now lights are continuously flashing on my Whirlpool Duet wash machine. Also, door doesn't open. Did remove bottom panel and unlatch the door. After replugging and shutting door, lights are still flashing. Clothes are very, very wet and have not drained. Any solutions? Don't know how to see your answers
  #2 (permalink)
Old 09-12-2013, 07:47 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
FH is basically saying there's not enough water coming into the unit or the pressure switch or connections aren't working properly.
Press PAUSE/CANCEL twice to clear the display.
Potential Causes
• If there is no water in the unit:
• Make sure that both valves at the water source(s) are turned on all the way.
• Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
• Verify inlet valve operation
• If there is water in the unit:
• Verify Drain pump operation
• Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
• Verify there is not a siphon problem
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
• Check all hoses for possible leaks
• Verify pressure switch operation
• Verify flow meter operation
• Verify CCU operation
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Duet Washer STUCK - lights flashing, door locked, won't complete cycle ERINC Washer Repair 1 06-07-2013 04:12 PM
whirlpool Duet washer control panel lights flicker then stop lsilva813 Washer Repair 3 08-01-2012 05:56 AM
Whirlpool Duet Washer flashing FH Jacobh Washer Repair 3 09-17-2010 07:37 PM
Duet Flashing Lights, No workie robmints Washer Repair 1 08-07-2008 05:33 PM
Lights flashing on whirlpool Face Dishwasher Repair 0 03-11-2008 09:42 AM
