Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   Kenmore 70 series stops before final spin cycle (http://forum.appliancepartspros.com/washer-repair/53485-kenmore-70-series-stops-before-final-spin-cycle.html)
jakeclifford 10-10-2009 01:44 PM
My washer stops the cycle before the last spin cycle. I opened it up, checked with my ohm meter that the door switch is functioning and checked to see if the motor coupling needs replacing. All parts check out. Pumped the water out and reset it. Watch as it filled, agitated, went through the first spin cycle, drained, rinsed, agitated again. Then it stopped with the water still in it.
Any Clues to what is going on?
sidfink43 10-11-2009 11:42 AM
It sounds like you may have an intermittent problem with the lid switch. The next time it stops by pass the lid switch and if that starts it up, replace the lid switch. Here is a site that will take you through the process.
Kenmore top loader blues (SublimeMasterJW's Appliance Advice)
If this is not the problem see if the problem exists for all cycles. Ultimately you may need a timer but check the lid switch first.
