I have a Whirlpool Duet sport washer that will not power up since I moved the unit during moving to my new house. I've checked the breaker and all is well. I've read to unplug the power cord then listen for a click from the CCU. I hear a click but its very faint. Also I was wondering how to check the door switch. Any help will be appreciated.
i did find the way to check the door switch and everything seems to be working normally. Also if I hold the " End of cycle" signal button for 3 seconds I do get the red light on the display panel.
I replaced the CCU and it is still without power. Where do I go from here? Any help will be greatly appreciated. Thank you.
