Discuss
washer makes high pitched noise and smell
 in
Washer Repair
Please Help. Yesterday our washer stopped spinning and would not drain. After some research I took it apart and checked
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer makes high pitched noise and smell
  #1 (permalink)
Old 09-04-2013, 02:16 PM
Junior Member
bsuderski is on a distinguished road
Default washer makes high pitched noise and smell
Model Number: LSQ8243H   Brand: Whirlpool   Age: 5 - 10 years
Please Help. Yesterday our washer stopped spinning and would not drain. After some research I took it apart and checked the clutch and the motor coupler. The clutch seemed ok. It was very hard to turn. The coupler was completely round in the center so I replaced it. Ran a test load and the washer worked. But, not it makes a high pitched sound and has a burning smell. any help is appreciated.
Related Models
Whirlpool LSQ8243HQ0 AUTOMATIC WASHER
Whirlpool LSQ8243HZ0 AUTOMATIC WASHER
Whirlpool LSQ8500JQ0 AUTOMATIC WASHER
Whirlpool LSQ8500JQ1 WASHER
Whirlpool LSQ8500JQ2 WASHER
Whirlpool LSQ8500JT0 AUTOMATIC WASHER
Whirlpool LSQ8500JT1 WASHER
Whirlpool LSQ8500JT2 WASHER
Whirlpool LSQ8500LQ0 AUTOMATIC WASHER
Whirlpool LSQ8510LQ0 AUTOMATIC WASHER
Whirlpool LSQ8511KQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ8511KT0 WASHER - DIRECT DRIVE
Whirlpool LSQ8512KQ0 WASHER
Whirlpool LSQ8512KT0 WASHER
Whirlpool LSQ8520JQ0 AUTOMATIC WASHER
Whirlpool LSQ8520JQ1 WASHER
Whirlpool LSQ8543JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ8543JQ1 WASHER
Whirlpool LSQ8543JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ8543JT1 WASHER
Whirlpool LSQ8543JZ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ8543JZ1 WASHER
Whirlpool LSQ9010KQ0 WASHER
Whirlpool LSQ9010KT0 WASHER
Whirlpool LSQ9010LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9010LG1 AUTOMATIC WASHER
Whirlpool LSQ9010LG2 AUTOMATIC WASHER
Whirlpool LSQ9010LG3 AUTOMATIC WASHER
Whirlpool LSQ9010LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9010LQ1 AUTOMATIC WASHER
Whirlpool LSQ9010LQ2 AUTOMATIC WASHER
Whirlpool LSQ9010LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9010LW1 AUTOMATIC WASHER
Whirlpool LSQ9010LW2 AUTOMATIC WASHER
Whirlpool LSQ9010LW3 AUTOMATIC WASHER
Whirlpool LSQ9010PG0 AUTOMATIC WASHER
Whirlpool LSQ9010PG1 AUTOMATIC WASHER
Whirlpool LSQ9010PG2 AUTOMATIC WASHER
Whirlpool LSQ9010PG3 AUTOMATIC WASHER
Whirlpool LSQ9010PG5 AUTOMATIC WASHER
Whirlpool LSQ9010PG6 AUTOMATIC WASHER
Whirlpool LSQ9010PW0 AUTOMATIC WASHER
Whirlpool LSQ9010PW1 AUTOMATIC WASHER
Whirlpool LSQ9010PW2 AUTOMATIC WASHER
Whirlpool LSQ9010PW3 AUTOMATIC WASHER
Whirlpool LSQ9010PW5 AUTOMATIC WASHER
Whirlpool LSQ9010PW6 AUTOMATIC WASHER
Whirlpool LSQ9030PQ0 AUTOMATIC WASHER
Whirlpool LSQ9030PQ1 AUTOMATIC WASHER
Whirlpool LSQ9030PQ2 AUTOMATIC WASHER
Whirlpool LSQ9030PQ4 AUTOMATIC WASHER
Whirlpool LSQ9030PQ5 AUTOMATIC WASHER
Whirlpool LSQ9110KQ0 WASHER
Whirlpool LSQ9110KQ1 WASHER
Whirlpool LSQ9110LG0 WASHER
Whirlpool LSQ9110LG1 AUTOMATIC WASHER
Whirlpool LSQ9110LW0 WASHER
Whirlpool LSQ9110LW1 AUTOMATIC WASHER
Whirlpool LSQ9110PW0 AUTOMATIC WASHER
Whirlpool LSQ9110PW1 AUTOMATIC WASHER
Whirlpool LSQ9110PW2 AUTOMATIC WASHER
Whirlpool LSQ9110PW3 AUTOMATIC WASHER
Whirlpool LSQ9110PW4 AUTOMATIC WASHER
Whirlpool LSQ9200KQ0 WASHER
Whirlpool LSQ9200KT0 WASHER
Whirlpool LSQ9200LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9200LQ1 AUTOMATIC WASHER
Whirlpool LSQ9200LQ2 AUTOMATIC WASHER
Whirlpool LSQ9200LQ3 AUTOMATIC WASHER
Whirlpool LSQ9200LT0 WASHER - DIRECT DRIVE
Whirlpool LSQ9200LT1 AUTOMATIC WASHER
Whirlpool LSQ9200LT2 AUTOMATIC WASHER
Whirlpool LSQ9200LT3 AUTOMATIC WASHER
Whirlpool LSQ9200PQ0 AUTOMATIC WASHER
Whirlpool LSQ9200PQ1 AUTOMATIC WASHER
Whirlpool LSQ9200PQ3 AUTOMATIC WASHER
Whirlpool LSQ9200PQ4 AUTOMATIC WASHER
Whirlpool LSQ9200PT0 AUTOMATIC WASHER
Whirlpool LSQ9200PT1 AUTOMATIC WASHER
Whirlpool LSQ9200PT3 AUTOMATIC WASHER
Whirlpool LSQ9200PT4 AUTOMATIC WASHER
Whirlpool LSQ9210HQ0 AUTOMATIC WASHER
Whirlpool LSQ9210HZ0 AUTOMATIC WASHER
Whirlpool LSQ9211KQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9211KQ1 WASHER - DIRECT DRIVE
Whirlpool LSQ9211KT0 WASHER - DIRECT DRIVE
Whirlpool LSQ9211KT1 WASHER - DIRECT DRIVE
Whirlpool LSQ9244EQ0 AUTOMATIC WASHER
Whirlpool LSQ9244EZ0 AUTOMATIC WASHER
Whirlpool LSQ9264HQ0 AUTOMATIC WASHER
Whirlpool LSQ9264HZ0 AUTOMATIC WASHER
Whirlpool LSQ9500LQ0 WASHER
Whirlpool LSQ9500LT0 WASHER
Whirlpool LSQ9510JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9510JQ1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9510LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9510LT0 WASHER - DIRECT DRIVE
Whirlpool LSQ9520LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9520LT0 WASHER - DIRECT DRIVE
Whirlpool LSQ9544KQ0 WASHER
Whirlpool LSQ9544KT0 WASHER
Whirlpool LSQ9549LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9549LG1 AUTOMATIC WASHER
Whirlpool LSQ9549LG2 AUTOMATIC WASHER
Whirlpool LSQ9549LG3 AUTOMATIC WASHER
Whirlpool LSQ9549LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9549LQ1 AUTOMATIC WASHER
Whirlpool LSQ9549LQ2 AUTOMATIC WASHER
Whirlpool LSQ9549LQ3 AUTOMATIC WASHER
Whirlpool LSQ9549LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9549LW1 AUTOMATIC WASHER
Whirlpool LSQ9549LW2 AUTOMATIC WASHER
Whirlpool LSQ9549LW3 AUTOMATIC WASHER
Whirlpool LSQ9549PG0 AUTOMATIC WASHER
Whirlpool LSQ9549PG1 AUTOMATIC WASHER
Whirlpool LSQ9549PG2 AUTOMATIC WASHER
Whirlpool LSQ9549PG3 AUTOMATIC WASHER
Whirlpool LSQ9549PG5 AUTOMATIC WASHER
Whirlpool LSQ9549PG6 AUTOMATIC WASHER
Whirlpool LSQ9549PW0 AUTOMATIC WASHER
  #2 (permalink)
Old 09-04-2013, 04:37 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
You didn't get the coupler halves on far enough. They must be flush with the end of the shafts. Use a socket and hammer to tap them on.
Eric
  #3 (permalink)
Old 09-04-2013, 06:10 PM
Junior Member
Default
Thank you for the reply. After I posted this I found a similar post which said the same thing. Did it and is working just fine now. I really appreciate this forum.
Brian
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
squeeking noise when spinning, like a high pitched drill noise norjen13 Washer Repair 0 06-05-2011 04:30 PM
New GE fridge gts21scxass makes horrible high pitched whining noise fridge noob Refrigerator & Freezer Repair 34 09-08-2010 12:40 PM
High pitched noise Whirlpool top load washer veralynn Washer Repair 1 02-27-2010 05:33 PM
washer makes a high pitched squeal when spinning ljmacneill Washer Repair 1 08-21-2009 04:36 AM
Maytag Washer making a high pitched noise in all cycles Daryl5775 Washer Repair 1 05-24-2009 02:10 PM
