Kenmore Model 110 Rattling Noise
Washer Repair
My top load washer is making a loud rattling sound when agitating and/or spinning. It fills and drains just fine.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore Model 110 Rattling Noise
  #1 (permalink)
Old 09-04-2013, 12:03 PM
Junior Member
DrFeelgood is on a distinguished road
Default Kenmore Model 110 Rattling Noise
Model Number: 110.82781800   Brand: Kenmore   Age: More than 10 years
My top load washer is making a loud rattling sound when agitating and/or spinning. It fills and drains just fine. It washes and spins okay, but spun clothes are slightly more damp than before. There is no noise when draining--just the happy hum of the motor and pump (new pump last year)--until the drum gets to about half speed.
I took the cabinet apart and inspected what little I know about. I pulled up on the inner tub and there's just a little play but nothing I would call excessive (not that I would know any better). I tugged and pushed on all the mechanical connections under the drum to feel for looseness or broken parts, but everything appears to be intact and solid. I manually rotated the drum and agitator--thinking it might be a bearing--but both rotate free and smooth without any noise. I took the agitator off and visually inspected the drive block and spanner nut. Everything looks tight and normal. I wanted to disassemble it further, but I don't have the spanner wrench for the tub nut.
I think I'm on to checking the transmission, but have no idea where or how to start. Is there a way to diagnose this problem that y'all could walk me through?
Related Models
Hoover 1100
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11012202100 WASHER
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 09-04-2013, 06:04 PM
Senior Member
HumboldtRepairMan is on a distinguished road
First off you don't need a spanner tool you can use a heavy duty punch with a single jack hammer to get it off also.....Check the gearcase and see if it's leaking oil of any sort under the unit....check the motor coupling wear, check the clutch and brake tube..check the springs around the milkstool and base make sure one's not fallen off or broken.....make sure your units perfectly level and on a good solid surface, subfloors aren't great foundations on some homes...Here's your parts and some video's to help you
Parts for Kenmore Washer 11082781800 - AppliancePartsPros.com
washer rattling noise - YouTube
top loader washer teardown - YouTube
  #3 (permalink)
Old 09-04-2013, 10:41 PM
Junior Member
Thanks for the tips. Since my first post I've pulled the motor and gearcase. Both appear to be fine. The gearcase had a couple drops of oil from the vent on top but the rest of it is sound. I operated the drive in both directions and the shaft/clutch turn the ways their supposed to. There's no grit or noise.
With the gearcase off I inspected the brake and clutch. Everything is in good condition and working properly. The isolator in the motor coupling is a bit worn, but nothing is cracked or failing. I cleaned and reassembled everything to test: the tub filled and the agitator still made the grinding/rattling noise. This time, however, it wouldn't spin or drain.
So I took it all apart again to find that in pulling the motor I must've broken one of the electrical terminals, so now I've got to replace that part before I can do any further testing. But I've pulled each of the primary assemblies save the drum, and all seem to be fine. I'm well and truly stumped.
And just to highlight the day, I managed to break a small leak into the hot water stop valve (at a badly corroded FIP joint) when I was disconnecting the supply hose. Seems about right for how my projects usually go.
  #4 (permalink)
Old 09-07-2013, 10:21 PM
Junior Member
Today I repaired that busted electrical terminal and replaced the motor coupling with a brand new one (thanks for the amazing fast shipping, APPro). With the motor and gearcase out and apart I manually rotated the input shafts on each one to see if I could feel any problems. Each component rotated smoothly. I put the new coupling on and clipped the motor back to the gearcase bracket then put a wrench on the pump-side motor shaft to turn them together. Bingo! It's gritty and sticking four or five times per turn.
Has anyone run in to this before where each part seems fine on its own but when mated they turn pretty rough by hand?
  #5 (permalink)
Old 09-24-2013, 09:43 PM
Junior Member
Well, for posterity's sake I'll update:
I found a used machine with compatible parts nearby for cheap, so I brought it home and started swapping stuff out. Turns out it was the motor on the old machine. It was making that terrible "clackety-clackety" noise during agitation and spin. It got really bad really fast in the "new" machine.
So I took my newer parts (pump, motor coupling, misc clips) off the old machine and put them in the "new" machine. Voila. Back to doing laundry.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer Rattling noise feanor387 Refrigerator & Freezer Repair 1 09-11-2010 12:23 AM
No Heat and Rattling Noise pak21 Dryer Repair 1 06-13-2009 04:51 PM
Rattling Noise jadendy Dryer Repair 2 04-27-2009 01:55 AM
GE ARTICA rattling noise Kwing Lee Refrigerator & Freezer Repair 2 04-25-2008 12:40 AM
Kenmore series 70, model 110 makes clunking noise? washerTed Washer Repair 1 11-18-2007 04:36 PM
