Discuss
Kenmore 11022642100 spins only sometimes
 in
Washer Repair
Hi! I have a Kenmore washer. 11022642100. Sometimes it doesn't spin during the spin cycle. The motor is on (it
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore 11022642100 spins only sometimes
  #1 (permalink)
Old 09-04-2013, 12:29 PM
Junior Member
yellowjeepjeep is on a distinguished road
Default Kenmore 11022642100 spins only sometimes
Model Number: 11022642100   Brand: Kenmore   Age: More than 10 years
Hi!
I have a Kenmore washer. 11022642100. Sometimes it doesn't spin during the spin cycle. The motor is on (it sounds like it's spinning). If you jiggle the drum a little, it will then spin fine through the cycle. It's almost like the drum gets stuck.
Any advice?
Thanks!!
Related Models
Kenmore 11022642100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022652100 COMPACT WASHER
Kenmore 11022662100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022692100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022692101 AUTOMATIC WASHER
Kenmore 11022702100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022702101 AUTOMATIC WASHER
Kenmore 11022712100 WASHER
Kenmore 11022722100 WASHER
Kenmore 11022722101 WASHER
Kenmore 11022802100 WASHER
Kenmore 11022802101 AUTOMATIC WASHER
Kenmore 11022832100 WASHER
Kenmore 11022832101 AUTOMATIC WASHER
Kenmore 11022832102 AUTOMATIC WASHER
Kenmore 11022842100 WASHER
Kenmore 11022842101 AUTOMATIC WASHER
Kenmore 11022842102 AUTOMATIC WASHER
Kenmore 11022852100 WASHER
Kenmore 11022852101 AUTOMATIC WASHER
Kenmore 11022852102 AUTOMATIC WASHER
Kenmore 11022854100 WASHER
Kenmore 11022854101 AUTOMATIC WASHER
Kenmore 11022854102 AUTOMATIC WASHER
Kenmore 11022862100 WASHER
Kenmore 11022862101 AUTOMATIC WASHER
Kenmore 11022872100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022872101 AUTOMATIC WASHER
Kenmore 11022872102 AUTOMATIC WASHER
Kenmore 11022882100 WASHER
Kenmore 11022882101 AUTOMATIC WASHER
Kenmore 11022882102 AUTOMATIC WASHER
Kenmore 11022892100 WASHER
Kenmore 11022892101 AUTOMATIC WASHER
Kenmore 11022892102 AUTOMATIC WASHER
Kenmore 11022894100 WASHER
Kenmore 11022894101 AUTOMATIC WASHER
Kenmore 11022894102 AUTOMATIC WASHER
Kenmore 11022902100 WASHER
Kenmore 11022902101 AUTOMATIC WASHER
Kenmore 11022904100 WASHER
Kenmore 11022904101 AUTOMATIC WASHER
Kenmore 11022912100 WASHER
Kenmore 11022912101 AUTOMATIC WASHER
Kenmore 11022922100 WASHER
Kenmore 11022922101 AUTOMATIC WASHER
Kenmore 11022922102 AUTOMATIC WASHER
Kenmore 11022924100 WASHER
Kenmore 11022924101 AUTOMATIC WASHER
Kenmore 11022924102 AUTOMATIC WASHER
Kenmore 11022932100 WASHER
Kenmore 11022932101 AUTOMATIC WASHER
Kenmore 11022932102 AUTOMATIC WASHER
Kenmore 11022936100 WASHER
Kenmore 11022936101 AUTOMATIC WASHER
Kenmore 11022936102 AUTOMATIC WASHER
Kenmore 11022942100 WASHER
Kenmore 11022942101 AUTOMATIC WASHER
Kenmore 11022942102 AUTOMATIC WASHER
Kenmore 11022952100 WASHER
Kenmore 11022952101 AUTOMATIC WASHER
Kenmore 11022952102 AUTOMATIC WASHER
Kenmore 11022954100 WASHER
Kenmore 11022954101 AUTOMATIC WASHER
Kenmore 11022954102 AUTOMATIC WASHER
Kenmore 11022956100 WASHER
Kenmore 11022956101 RESIDENTIAL WASHER
Kenmore 11022956102 AUTOMATIC WASHER
Kenmore 11022972100 WASHER
Kenmore 11022972101 WASHER
Kenmore 11022972102 WASHER
Kenmore 11022972103 AUTOMATIC WASHER
Kenmore 11022974100 WASHER
Kenmore 11022974101 WASHER
Kenmore 11022974102 WASHER
Kenmore 11022974103 AUTOMATIC WASHER
Kenmore 11022982100 WASHER
Kenmore 11022982101 WASHER
Kenmore 11022982102 WASHER
Kenmore 11022982103 AUTOMATIC WASHER
Kenmore 11022992100 WASHER
Kenmore 11022992101 WASHER
Kenmore 11022992102 AUTOMATIC WASHER
Kenmore 11022992103 AUTOMATIC WASHER
Kenmore 11022994100 WASHER
Kenmore 11022994101 WASHER
Kenmore 11022994102 AUTOMATIC WASHER
Kenmore 11022994103 AUTOMATIC WASHER
Kenmore 11022996100 WASHER
Kenmore 11022996101 WASHER
Kenmore 11022996102 AUTOMATIC WASHER
Kenmore 11022996103 AUTOMATIC WASHER
Kenmore 11023012100 AUTOMATIC WASHER
Kenmore 11023012101 AUTOMATIC WASHER
Kenmore 11023012102 AUTOMATIC WASHER
Kenmore 11023014100 AUTOMATIC WASHER
Kenmore 11023014101 AUTOMATIC WASHER
Kenmore 11023014102 AUTOMATIC WASHER
Kenmore 11023022100 AUTOMATIC WASHER
Kenmore 11023022101 AUTOMATIC WASHER
Kenmore 11023022102 AUTOMATIC WASHER
Kenmore 11023024100 AUTOMATIC WASHER
Kenmore 11023024101 AUTOMATIC WASHER
Kenmore 11023024102 AUTOMATIC WASHER
Kenmore 11023032100 WASHER
Kenmore 11023032101 AUTOMATIC WASHER
Kenmore 11023032102 AUTOMATIC WASHER
Kenmore 11023034100 WASHER
Kenmore 11023034101 AUTOMATIC WASHER
Kenmore 11023034102 AUTOMATIC WASHER
Kenmore 11023036100 WASHER
Kenmore 11023036101 AUTOMATIC WASHER
Kenmore 11023036102 AUTOMATIC WASHER
Kenmore 11023652200 AUTOMATIC WASHER
Kenmore 11023662200 AUTOMATIC WASHER
Kenmore 11023692200 AUTOMATIC WASHER
Kenmore 11023712200 AUTOMATIC WASHER
Kenmore 11023722200 AUTOMATIC WASHER
Kenmore 11023732200 AUTOMATIC WASHER
Kenmore 11023812100 AUTOMATIC WASHER
  #2 (permalink)
Old 09-04-2013, 07:16 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
Pull the drum out and check for clothing underneath drum.............if not clothing check for loose or broken pieces inside...........Then look under the unit for the gearcase leaking oil, Then check motor coupling for damage......Also test the lid switch for continuity or damage. Here's some youtube video's to help check there site for additional video's to troubleshoot.
washer sometimes spins - YouTube
washer motor coupling - YouTube
washer lid switch - YouTube
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore only spins in Delicates mgfish Washer Repair 0 02-04-2013 03:02 PM
Kenmore Washer Spins...Sometimes billnlucy Washer Repair 5 10-05-2010 07:38 PM
Kenmore 600 Washer sometimes spins zeemaster62 Washer Repair 2 10-03-2010 11:43 AM
Kenmore Spins Intermittently Philn Washer Repair 5 01-26-2009 06:40 AM
Kenmore spins slowly DaniB Washer Repair 1 02-04-2008 06:05 PM
