Discuss
Roper washer wont spin and wont empty
 in
Washer Repair
Our washer will not spin and only hums when it gets to spin cycle.. It will fill up with water
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Roper washer wont spin and wont empty
  #1 (permalink)
Old 10-10-2009, 08:20 AM
Junior Member
jgirl14572 is on a distinguished road
Default Roper washer wont spin and wont empty
Brand: Roper   Age: 1 - 5 years
Our washer will not spin and only hums when it gets to spin cycle.. It will fill up with water but wont empty... I think I over loaded it one day and then I smelled something hot.. Like a burning belt. But it seems this washer doesnt have a belt.. Please help
  #2 (permalink)
Old 10-10-2009, 08:33 AM
Junior Member
Default
Quote:
The coupling looks fine.. the drum wont turn.. any ideas
  #3 (permalink)
Old 10-11-2009, 07:54 AM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
I am assumng that the machine agitates fine, then stops when it tries to drain and go into the spin cycle after thew wash cycle.
If it will not empty this means the pump is not turning. The most likely cause is that something is jammed in there, so take off the pump and see if it is causing the problem. Check all the drain hoses and make sure nothing is obstructing them.
If that does not fix it, post back and we will come up some other ideas.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
roper washer wont work on spin cycle bugdude007 Washer Repair 1 05-31-2009 11:10 AM
pins good on empty load. wont spin with cloths in howard65 Washer Repair 0 03-21-2009 03:31 PM
roper wont spin ardyne Washer Repair 4 03-02-2009 05:35 PM
roper washer wont fill cwhite Washer Repair 1 02-03-2009 01:53 PM
Roper washer wont drain Kford Washer Repair 4 11-18-2008 10:03 AM
