Discuss
Maytag MAH8700A not draining water.
 in
Washer Repair
Hello, I have a Maytag MAH8700A that I am having problems with. Originally it was believed to have had a
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag MAH8700A not draining water.
  #1 (permalink)
Old 09-03-2013, 01:55 AM
Junior Member
vcand is on a distinguished road
Question Maytag MAH8700A not draining water.
Model Number: MAH8700A   Brand: -brand-   Age: 5 - 10 years
Hello,
Originally it was believed to have had a bad motor because the spin cycle was not observed, I proved this false. Now I believe it to be tied to the pump somehow, here is why.
I downloaded the Technical Information manual for this model and did all the troubleshooting, results are as follows.
Quick Spin Test:
Works!
Component Testing:
ALL components test properly (with the exception that this unit does not have a MEMS Sensor).
Curious thing though, to test the Drain Pump it says: "During drain check voltage at Pin #1 of CN5 and Pin #6 of CN10". I did that and at ALL times it has 120vac running through it. So no matter if I put it into drain mode (via Output Test of the drain cycle) or not, it still tested 120vac.
Output test:
Everything worked EXCEPT for the Drain Pump. When I pressed the selector to turn the pump on/off, nothing happened (bear in mind 120vac was found no matter which state this was in in the previous test). My brother believes that when I do the "Pump" test the door should lock then drain, but neither happens on this test, and I cannot confirm whether the door is supposed to lock.
Input Test:
Everything worked.
Quick Service Cycle:
Hot water - worked
Cold water - worked
Bleach - worked
Softner - worked
Cold water on until water level detected - worked
Tumble clockwise for 5 seconds - worked
NOTHING HAPPENS AT THIS POINT, it just sits there until I advance to the next cycle, which returns "PASSED".
Door Switch:
It seemed like everything worked when I check the connections and continuity.
Troubleshooting:
Under troubleshooting "Tub will not drain", it says one thing to check is "120vac at the pump". Well, I connected my meter to both pins of the pump and then the harness and got nothing. With the meter connected and doing the Output Test of "Drain", when I press the button to turn it off/on all I get out of the meter is a little jump of power (ie. it jumps to .1v and then back to 0).
Clogged Pump:
I pulled it all apart and cleaned both lines out and also disassembled the pump, it was all clean and clear.
Pump Test:
I connected the pump to 120vac and it pumped away, so it works.
Conclusion:
It seems almost as if "something" should be happening as a prelude to the pump that isn't; whether it be some sort of sensor or switch or relay, it seems to be skipping this and therefore not draining, I suppose. It is not the pump as there has been a few times when I put it into "Drain Only" mode that the pump comes on for 1 to 2 seconds, but that only happened twice during my all day of troubleshooting and testing.
Anyone have any ideas? Any other tests I should run?
I appreciate your help, thanks!
Related Models
Maytag MAH8700AWM WASHER- HORIZONTAL AXIS
Maytag MAH8700AWW WASHER- HORIZONTAL AXIS
Maytag MAH9700AWM WASHER- HORIZONTAL AXIS
Maytag MAH9700AWQ WASHER- HORIZONTAL AXIS
Maytag MAH9700AWW WASHER- HORIZONTAL AXIS
Frigidaire MAL123P1A1 Wwh(v1) / Room Air Conditioner
Maytag MAL1800AXM MISC / ACCESSORY
Maytag MAL1800AXQ MISC / ACCESSORY
Maytag MAL1800AXW MISC / ACCESSORY
Maytag MAL2000AXQ MISC / ACCESSORY
Maytag MAL2000AXW MISC / ACCESSORY
Frigidaire MAS183P2A1 Wwh(v1) / Room Air Conditioner
Maytag MAT10CSAAL MANUAL, PARTS (WASHER)
Maytag MAT10CSAAW MANUAL, PARTS (WASHER)
Maytag MAT10CSAGL MANUAL, PARTS (WASHER)
Maytag MAT10CSAGW MANUAL, PARTS (WASHER)
Maytag MAT10CSEGL MANUAL, PARTS (WASHER)
Maytag MAT10CSEGW MANUAL, PARTS (WASHER)
Maytag MAT10DAAAL MANUAL, PARTS (WASHER)
Maytag MAT10DAAAW MANUAL, PARTS (WASHER)
Maytag MAT10DAABL MANUAL, PARTS (WASHER)
Maytag MAT10DAABW MANUAL, PARTS (WASHER)
Maytag MAT10PDAAL MANUAL, PARTS (WASHER)
Maytag MAT10PDAAW MANUAL, PARTS (WASHER)
Maytag MAT10PDABL MANUAL, PARTS (WASHER)
Maytag MAT10PDABW MANUAL, PARTS (WASHER)
Maytag MAT10PDEGW MAYTAG LAUNDRY (COMM.EXPORT) (WASHER)
Maytag MAT10PSAAL MANUAL, PARTS (WASHER)
Maytag MAT10PSAAW MANUAL, PARTS (WASHER)
Maytag MAT10PSAGL MANUAL, PARTS (WASHER)
Maytag MAT10PSAGW MANUAL, PARTS (WASHER)
Maytag MAT11CSBKL MANUAL, PARTS (WASHER)
Maytag MAT11MNAAW MANUAL, PARTS (WASHER)
Maytag MAT11MNAGW MANUAL, PARTS (WASHER)
Maytag MAT11MNEGW MANUAL, PARTS (WASHER)
Maytag MAT11PDAAL MAYTAG LAUNDRY (WASHER)
Maytag MAT11PDAAW MAYTAG LAUNDRY (WASHER)
Maytag MAT11PDABL MAYTAG LAUNDRY (WASHER)
Maytag MAT11PDABW MAYTAG LAUNDRY (WASHER)
Maytag MAT12CSAAL MANUAL, PARTS (WASHER)
Maytag MAT12CSAAQ MANUAL, PARTS (WASHER)
Maytag MAT12CSAAW MANUAL, PARTS (WASHER)
Maytag MAT12CSAGW MANUAL, PARTS (WASHER)
Maytag MAT12CSAKL MANUAL, PARTS (WASHER)
Maytag MAT12CSAKQ MANUAL, PARTS (WASHER)
Maytag MAT12CSDAQ MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12CSDAW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12CSDGW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12CSEGW MANUAL, PARTS (WASHER)
Maytag MAT12CSFWQ COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12CSFWW COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12CSLGW MAYTAG COMMERCIAL WASHER (WASHER)
Maytag MAT12CSLWQ MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12CSLWW MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12PDAAL MANUAL, PARTS (WASHER)
Maytag MAT12PDAAW MANUAL, PARTS (WASHER)
Maytag MAT12PDABL MANUAL, PARTS (WASHER)
Maytag MAT12PDABW MANUAL, PARTS (WASHER)
Maytag MAT12PDAGW MANUAL, PARTS (WASHER)
Maytag MAT12PDBAL MANUAL, PARTS (WASHER)
Maytag MAT12PDBAQ MANUAL, PARTS (WASHER)
Maytag MAT12PDBAW MANUAL, PARTS (WASHER)
Maytag MAT12PDBBL MANUAL, PARTS (WASHER)
Maytag MAT12PDBBQ WASHER-TOP LOADING
Maytag MAT12PDBBW MANUAL, PARTS (WASHER)
Maytag MAT12PDCBL MAYTAG LAUNDRY (WASHER)
Maytag MAT12PDCBQ MAYTAG LAUNDRY (WASHER)
Maytag MAT12PDCBW MAYTAG LAUNDRY (WASHER)
Maytag MAT12PDDAQ MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PDDAW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PDDBW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PDDGW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PDEGW MANUAL, PARTS (WASHER)
Maytag MAT12PDLAQ MAYTAG LAUNDRY (WASHER)
Maytag MAT12PDLAW MAYTAG LAUNDRY (WASHER)
Maytag MAT12PDLGW COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12PDSAW MANUAL,PARTS (WASHER)
Maytag MAT12PRAAW MANUAL, PARTS (WASHER)
Maytag MAT12PRAEW MANUAL, PARTS (WASHER)
Maytag MAT12PRBAW MANUAL, PARTS (WASHER)
Maytag MAT12PRDAW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PRSAW MANUAL, PARTS (WASHER)
Maytag MAT12PSAAW MANUAL, PARTS (WASHER)
Maytag MAT12PSAGW MANUAL, PARTS (WASHER)
Maytag MAT12PSBAW MANUAL, PARTS (WASHER)
Maytag MAT12PSDAW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PSLWQ MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12PSLWW MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT13MNAAW MANUAL, PARTS (WASHER)
Maytag MAT13MNAGW MANUAL, PARTS (WASHER)
Maytag MAT13MNDAW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT13MNDGW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT13MNEGW MANUAL, PARTS (WASHER)
Maytag MAT13PDAAW MANUAL, PARTS (WASHER)
Maytag MAT13PDBAW MANUAL, PARTS (WASHER)
Maytag MAT13PNAEW MAYTAG LAUNDRY (WASHER)
Maytag MAT13PNDEW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT13PRBWW MAYTAG LAUNDRY (WASHER)
Maytag MAT14CSAGW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT14CSAWW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT14CSBGW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT14PDAWW0 COMMERCIAL AUTOMATIC WASHER
Whirlpool MAT14PDAXW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT14PRAWW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT15MNAGW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT15MNAWW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT15MNBGW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT23PCAAG MANUAL, PARTS (WASHER)
Maytag MAT23PCAAL MANUAL, PARTS (WASHER)
Maytag MAT23PCAAW MANUAL, PARTS (WASHER)
Maytag MAT23PCABG MANUAL, PARTS (WASHER)
Maytag MAT23PCABL MANUAL, PARTS (WASHER)
Maytag MAT23PCABW MANUAL, PARTS (WASHER)
Maytag MAT25CSAAG MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT25CSAAL MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT25CSAAW MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT25CSAGG MAYTAG LAUNDRY (EXPORT) (WASHER)
Maytag MAT25CSAGL MAYTAG LAUNDRY (EXPORT) (WASHER)
Maytag MAT25CSAGW MAYTAG LAUNDRY (EXPORT) (WASHER)
Maytag MAT25CSBIL MAYTAG COMMERCIAL LAUNDRY (WASHER)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag washer on large load fills 3/4 fullon water and then starts draining back ou g buffb Washer Repair 7 07-17-2013 09:23 PM
Maytag not draining all the way mikeaz19 Washer Repair 2 04-19-2012 03:30 PM
Maytag MAH8700A spin cycle issues uncre8ve Washer Repair 3 02-22-2009 07:20 AM
maytag draining problem rob6583 Washer Repair 0 06-12-2008 07:05 AM
maytag D/W not draining cooter Dishwasher Repair 1 05-27-2008 08:22 PM
