i have tried to reset this washer after it flashed a 6 blinking error code and after i reset it it now blink constantly without a pause and motor will not start or spin
Groups: Expert
is there any other test that i need to do to make sure before i replace the motor/inverter just to make sure this is the problem before i do this replacement?
Groups: Expert
Check the lid switch. With washer timer in on position and in spin mode, check for 120vac on motor inverter rightmost connector at red wire and blue wire (high speed spin) red wire and white wire (low speed spin), use white/red wire of leftmost connector for meter neutral. Can you manually rotate tub freely?
Eric
