Whirlpool duet Steam Washer still showing F20 error code. Pressure switch changed for new one. pump and hoses all cleaned (found 93cents in catch trap on bottom of washer) ran cycle with steam - everything worked for a while the error code F20. Same code as before among others What do I change or do now?
