Discuss
Kenmore Washer smelled like smoke
 in
Washer Repair
We bought our home 3 years ago and the washer and dryer came with it. The serial number is CT2921724,
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore Washer smelled like smoke
  #1 (permalink)
Old 08-27-2013, 07:53 AM
Junior Member
jbresset is on a distinguished road
Default Kenmore Washer smelled like smoke
Model Number: 110.27612600   Brand: Kenmore   Age: 5 - 10 years
We bought our home 3 years ago and the washer and dryer came with it. The serial number is CT2921724, so I'm guessing it was made in 2006? We had not had any issues before.
Two days ago, the unit stopped working after the fill cycle, so it wouldn't continue to agitation cycle. So I "bridged" the gray and white wires that were connected to the lid switch to test the lid switch. It worked, but only for a little bit of time.
At that point i smelled smoke and the unit stopped working again. I waited for a half hour and tried it again (I was trying to spin the clothes that were in there and expel the water.) More smoke smell.
After an hour, I removed the clothes and tried the spin cycle with only the water in the bin. This time it did spin, but slow. In fact it did not create enough force to drain the bin.
This morning I tried the spin cycle again (did not want a science experiment and was contemplating adding chlorine to the water. This time it began to spin with force the water was draining, when a loud "clicking" sound was coming from behind and low. I don't want to burn out the motor. What is your diagnosis?
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 08-27-2013, 09:05 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Yes, the washer was manufactured in July of 2006. When you say it stopped working after fill, was the washer totally quiet or was the motor humming? Motor is at lower middle/front of washer cabinet. Do you have to leave the jumper in to make it work or is the lid switch working? The washer should drain initially without spinning after a normal agitation cycle. If it isn't doing that, there is at least a problem with the gearcase. You may have something in the pump causing the noise and motor binding problem. I would remove the cabinet, jump out the lid switch, pull the pump off the back of the motor and see if it will spin properly. It's fine to run it with cabinet off. Make sure your lid switch jumper is 16 gauge wire and makes a tight fit with the connector pins. Full motor current goes through and you must have a good connection. If it is not the pump causing the clicking sound, post a video to youtube so I can hear/see whats going on.
Eric
  #3 (permalink)
Old 08-28-2013, 08:08 AM
Junior Member
Default
Quote:
Eric
The washer was totally quiet. The switch bracket was broken (by me) so i'll have to replace it. The washer would not drain at any point in the cycle. I pulled the pump of the motor and the unit spins properly. I cleared the drain hose and visually inspected the pump through the two tubes. I spun the gear with a screw driver and did not see anything, but there is some resistance. Should the gear in the pump spin freely? There was no clicking sound.
  #4 (permalink)
Old 08-28-2013, 08:26 AM
Junior Member
Default You tube video of clicking sound
I pulled the pump back off and the motor still made the clicking sounds. I posted a video on you tube named "kenmore washer APP.com"
  #5 (permalink)
Old 08-28-2013, 08:54 AM
Junior Member
Default
So I partially assembled and tried to run it through its cycles. It filled fine and began the agitation cycle fine. There are no clothes so it is lighter. But halfway through the agitation cycle I am beginning to smell the smoke again so I shut it down.
  #6 (permalink)
Old 08-28-2013, 09:10 AM
Junior Member
Default
I pushed the cycle forward to drain and it completely silent. No hum. No smell. No noise. Still full of water, not rinsing. Won't spin. Is it over heated from the agitation cycle?
  #7 (permalink)
Old 08-28-2013, 09:44 AM
Expert
APP Volunteer
Default
Check the connector at the motor. Unplug it and check for corrosion on the terminals or burned terminals/wires. Also check the plug at the timer. Search on youtube did not find your video. What is the link to the video??? Is the lid switch working or not???
Eric
  #8 (permalink)
Old 08-28-2013, 09:59 AM
Junior Member
Default
I broke the lid switch, so no. It has a jumper now (16 gauge.) I just posted a second you tube video. Both are titles Kenmore washer APP.com
  #9 (permalink)
Old 08-28-2013, 10:04 AM
Expert
APP Volunteer
Default
It does not come up when I search on that. Just copy and paste the link here so all I have to do is click on it.
  #10 (permalink)
Old 08-28-2013, 10:25 AM
Junior Member
Default
Quote:
Kenmore washer APP.com 2 - YouTube
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer smelled like burning blakemichael Washer Repair 2 08-19-2011 10:10 PM
washer smoke and smells like burnt alvaroenrique Washer Repair 3 08-26-2010 05:10 PM
Whirlpool washer making noise & smelled like something burning lindaben Washer Repair 2 08-19-2010 05:45 PM
washer shows smoke inside the drum Longsworth Washer Repair 7 05-25-2009 12:17 PM
Admrial Washer wont spin and smoke Shawn4455 Washer Repair 1 05-08-2009 05:48 PM
