Discuss
Kenmore washer leaving clothes soaking wet
 in
Washer Repair
Hello, My Kenmore washer has started leaving my clothes soaking wet after a wash cycle. When I take off the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore washer leaving clothes soaking wet
  #1 (permalink)
Old 08-26-2013, 02:25 PM
Junior Member
suds1421 is on a distinguished road
Default Kenmore washer leaving clothes soaking wet
Model Number: 41743042200   Brand: Kenmore   Age: 5 - 10 years
Hello,
My Kenmore washer has started leaving my clothes soaking wet after a wash cycle. When I take off the back panel the drain hose is nearly full of water all the way down to what I think is the coin catch.
From reading other threads it sounds to me like the pump is bad on the washer. I've found the pump on sears parts direct but I want to be sure it isn't something up.
The load isn't balancing when it's spinning, but I think that's because the clothes are so heavy, they are literally dripping with water and there is water in the bottom of the drum.
Thanks so much for the help! Jeff
Related Models
Kenmore 41743042200 SEARS/FRONTLOAD WASHER
Kenmore 41743042300 WASHER
Kenmore 41743052200 SEARS/FRONTLOAD WASHER
Kenmore 41743142200 SEARS/FRONTLOAD WASHER
Kenmore 41743142300 WASHER
Kenmore 41744042400 WASHER
Kenmore 41744052400 WASHER
Kenmore 41744052401 WASHER
Kenmore 41744052500 WASHER
Kenmore 41744072300 WASHER
Kenmore 41744082400 WASHER
Kenmore 41744082500 WASHER
Kenmore 41744092500 WASHER
Kenmore 41744102300 WASHER
Kenmore 41744102301 WASHER
Kenmore 41744130000 WASHER
Kenmore 41744131000 WASHER
Kenmore 41744132000 WASHER
Kenmore 41744142400 WASHER
Kenmore 41744152400 WASHER
Kenmore 41744152401 WASHER
Kenmore 41744152500 WASHER
Kenmore 41744252500 WASHER
Kenmore 41744252501 WASHER
Kenmore 41747102700 WASHER
Kenmore 41747102701 WASHER
Kenmore 41748102700 WASHER
Kenmore 41748102701 WASHER
Kenmore 41748106700 WASHER
Kenmore 41748112700 WASHER
Kenmore 41748112701 WASHER
Kenmore 41748116700 WASHER
Frigidaire 41749012890 Frg(v0) / Dryer
Frigidaire 41749022890 Frg(v0) / Dryer
Frigidaire 41759012890 Frg(v0) / Dryer
Kenmore 41759012890 GAS DRYER
Frigidaire 41759022890 Frg(v0) / Dryer
Kenmore 41759022890 GAS DRYER
Kenmore 41764182300 ELECTRIC DRYER
Kenmore 41769042990 KENMORE DRYER
Kenmore 41769042991 DRYER
Kenmore 41769052990 DRYER
Kenmore 41769052991 ELECTRIC DRYER
Kenmore 41774182300 GAS DRYER
Kenmore 41774182301 GAS DRYER
Kenmore 41779042990 DRYER
Kenmore 41779042991 DRYER
Kenmore 41779052990 DRYER
Kenmore 41779052991 DRYER
Kenmore 41780032990 DRYER
Kenmore 41780042990 DRYER
Kenmore 41780042991 DRYER
Kenmore 41780052990 DRYER
Kenmore 41780052991 DRYER
Kenmore 41780142000 DRYER
Kenmore 41780412700 DRYER
Kenmore 41781042000 DRYER
Kenmore 41781042001 DRYER
Kenmore 41781052000 ELECTRIC DRYER
Kenmore 41781052001 DRYER
Kenmore 41781100000 DRYER
Kenmore 41781101000 DRYER
Kenmore 41781102000 DRYER
Kenmore 41781142000 DRYER
Kenmore 41781142001 DRYER
Kenmore 41782042100 DRYER
Kenmore 41782042101 DRYER
Kenmore 41782042102 SEARS/DRYER
Kenmore 41782052100 DRYER
Kenmore 41782052101 DRYER
Kenmore 41782052102 DRYER
Kenmore 41782052103 SEARS/ELECTRIC DRYER
Kenmore 41782142100 DRYER
Kenmore 41782142101 DRYER
Kenmore 41782142102 SEARS/ELECTRIC DRYER
Kenmore 41783042200 SEARS/DRYER
Kenmore 41783042201 SEARS/ELECTRIC DRYER
Kenmore 41783042300 DRYER
Kenmore 41783052200 SEARS/DRYER
Kenmore 41783052201 SEARS/DRYER
Kenmore 41783142200 SEARS/DRYER
Kenmore 41783142201 SEARS/ELECTRIC DRYER
Kenmore 41783142300 DRYER
Kenmore 41784042500 DRYER
Kenmore 41784052500 DRYER
Kenmore 41784072300 DRYER
Kenmore 41784082500 DRYER
Kenmore 41784092500 DRYER
Kenmore 41784130000 DRYER
Kenmore 41784131000 DRYER
Kenmore 41784132000 DRYER
Kenmore 41784152500 DRYER
Kenmore 41784252500 DRYER
Kenmore 41784988100 AUTOMATIC WASHER
Kenmore 41784988800 AUTOMATIC WASHER
Kenmore 41787042700 DRYER
Kenmore 41788042700 DRYER
Kenmore 41788052700 DRYER
Kenmore 41788056700 DRYER
Kenmore 41788076700 DRYER
Kenmore 41788988100 ELECTRIC DRYER
Kenmore 41788988800 ELECTRIC DRYER
Kenmore 41788989100 GAS DRYER
Kenmore 41788989800 GAS DRYER
Kenmore 41789090100 WASHER DRYER COMBINATION
Kenmore 41789090110 COMBINATION WASHER-DRYER
Kenmore 41789090200 WASHER DRYER COMBINATION
Kenmore 41789090210 COMBINATION WASHER-DRYER
Kenmore 41789090400 WASHER DRYER COMBINATION
Kenmore 41789090410 COMBINATION WASHER-DRYER
Kenmore 41789090600 WASHER DRYER COMBINATION
Kenmore 41789090610 COMBINATION WASHER-DRYER
Kenmore 41789090800 WASHER DRYER COMBINATION
Kenmore 41789090810 COMBINATION WASHER-DRYER
Kenmore 41789190100 COMBINATION WASHER/DRYER
Kenmore 41789190110 COMBINATION WASHER/DRYER
Kenmore 41789190120 COMBINATION WASHER/DRYER
Kenmore 41789190600 COMBINATION WASHER/DRYER
Kenmore 41789190610 COMBINATION WASHER/DRYER
Kenmore 41789190620 COMBINATION WASHER/DRYER
  #2 (permalink)
Old 08-26-2013, 03:10 PM
Junior Member
Default
Update: The drain hose was full of water from the elbow that goes into the wall to the pump. I took off the drain hose and the coin catch. The coin catch and the washer tub both had brown sludge in them like they weren't draining. They weren't plugged, but did have a small amount of it in there.
I ran the pump for a second to verify it was spinning and it was but I have no way of knowing if it is pumping effectively.
I will say that the pump was growling much louder than I would have expected a pump to sound.
Is there any way to verify the pump is bad?
Thanks, Jeff
  #3 (permalink)
Old 08-26-2013, 09:06 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
Ohm check the motor but if it's working it's working they either work or are dead, check the incoming voltage make sure it's 120v if it's not you have a main control board or wiring issue..........If you got 120v and it's working make sure the drain pump area and the exiting hose from the drum is throughly cleaned.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE large capacity clothes washer leaves clothes soaking wet gbtribe Washer Repair 0 12-14-2010 09:01 PM
Spin cycle leaving clothes soaking wet ctrauthwein@hotmail.com Washer Repair 1 03-16-2010 07:20 PM
Spin cycle leaving clothes soaking wet Bamaman31 Washer Repair 4 11-01-2009 06:07 AM
MAYTAG NEPTUNE FRONT LOAD WASHER, Clothes come out soaking wet debbielf Washer Repair 3 09-01-2009 06:13 AM
Washing Machine is leaving clothes smelling like mildew and leaving detergent on them Redskinsrhonda Washer Repair 1 09-19-2007 04:57 AM
