Discuss
GE front load washer will not complete spin cycle
 in
Washer Repair
My GE front load washer 'paused' with 15 minutes remaining while washing a load of towels. I started the load
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE front load washer will not complete spin cycle
  #1 (permalink)
Old 08-21-2013, 12:35 PM
Junior Member
Jadielyn is on a distinguished road
Default GE front load washer will not complete spin cycle
Brand: GE   Age: 1 - 5 years
My GE front load washer 'paused' with 15 minutes remaining while washing a load of towels. I started the load before leaving the house and this is where it was when I returned. I pushed 'start' and it started and then 'paused' again. I think maybe the load was unbalanced sometime during the cycle and was unable to balance itself and it created the problem. I removed part of the load and did a 'drain and spin' cycle only. It was successful. I put in another load (not towels) and the washer filled and then stopped, but the time continued counting down. I emptied the washer and we ran the test cycles. The only error code was E31 and we checked the drain--nothing was in it. We continued through the tests until we got to t06. The washer filled fine, but would not drain. We concluded the water pump was bad and we replaced it. I started another load and it got to the spin cycle and it will spin for about a minute, stops, adds time, spins again, stops, adds time, etc. until I stop it. It will not go into fast spin mode. We did the test run again and we have no error codes and it successfully completes t06 with the new water pump. Any suggestions on what to do? Thank you.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Front load washer won't spin water out of clothes on last spin cycle Tracey Finley Washer Repair 1 06-28-2011 05:10 PM
Front load washer will not spin on final cycle teachout Washer Repair 1 04-16-2010 05:34 PM
Frigidaire Front load will not complete cycle srtlt Washer Repair 1 10-23-2009 09:54 AM
Frigidaire front load will not complete spin cycle Jim Engel Washer Repair 5 01-09-2009 06:58 PM
Front load washer doesn't go into spin cycle tburrows Washer Repair 1 11-19-2008 03:14 PM
