Machine starts by itelf
Washer Repair
Replaced control panel W10189966.Same problem runs by itself random start ups runs test cycle C0-C9.Is main control display panel shorting
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Machine starts by itelf
  #1 (permalink)
Old 08-21-2013, 12:24 PM
Junior Member
garryr is on a distinguished road
Default Machine starts by itelf
Model Number: 11027062603   Brand: Kenmore   Age: 5 - 10 years
Replaced control panel W10189966.Same problem runs by itself random start ups runs test cycle C0-C9.Is main control display panel shorting out?
Related Models
Kenmore 11027062603 RESIDENTIAL WASHER
Kenmore 11027062604 RESIDENTIAL WASHER
Kenmore 11027072600 WASHER
Kenmore 11027072601 RESIDENTIAL WASHER
Kenmore 11027072602 RESIDENTIAL WASHER
Kenmore 11027072603 RESIDENTIAL WASHER
Kenmore 11027072604 RESIDENTIAL WASHER
Kenmore 11027082600 RESIDENTIAL WASHER
Kenmore 11027082601 RESIDENTIAL WASHER
Kenmore 11027082602 RESIDENTIAL WASHER
Kenmore 11027082603 WASHER
Kenmore 11027082604 RESIDENTIAL WASHER
Kenmore 11027082605 RESIDENTIAL WASHER
Kenmore 11027086601 RESIDENTIAL WASHER
Kenmore 11027086602 RESIDENTIAL WASHER
Kenmore 11027086603 RESIDENTIAL WASHER
Kenmore 11027086604 RESIDENTIAL WASHER
Kenmore 11027086605 RESIDENTIAL WASHER
Kenmore 11027087600 RESIDENTIAL WASHER
Kenmore 11027087601 RESIDENTIAL WASHER
Kenmore 11027087602 RESIDENTIAL WASHER
Kenmore 11027087603 RESIDENTIAL WASHER
Kenmore 11027087604 RESIDENTIAL WASHER
Kenmore 11027087605 RESIDENTIAL WASHER
Kenmore 11027092600 WASHER
Kenmore 11027092601 RESIDENTIAL WASHER
Kenmore 11027092602 RESIDENTIAL WASHER
Kenmore 11027092603 RESIDENTIAL WASHER
Kenmore 11027112600 WASHER
Kenmore 11027152600 AUTOMATIC WASHER
Kenmore 11027152601 RESIDENTIAL WASHER
Kenmore 11027152602 RESIDENTIAL WASHER
Kenmore 11027172600 WASHER
Kenmore 11027222600 RESIDENTIAL WASHERS
Kenmore 11027224600 RESIDENTIAL WASHERS
Kenmore 11027272600 WASHER
Kenmore 11027322600 RESIDENTIAL WASHERS
Kenmore 11027332600 RESIDENTIAL WASHERS
Kenmore 11027342600 RESIDENTIAL WASHERS
Kenmore 11027422600 RESIDENTIAL WASHERS
Kenmore 11027432600 RESIDENTIAL WASHERS
Kenmore 11027442600 RESIDENTIAL WASHER
Kenmore 11027522600 RESIDENTIAL WASHERS
Kenmore 11027532600 RESIDENTIAL WASHERS
Kenmore 11027542600 RESIDENTIAL WASHER
Kenmore 11027612600 RESIDENTIAL WASHERS
Kenmore 11027622790 AUTOMATIC WASHER
Kenmore 11027622791 AUTOMATIC WASHER
Kenmore 11027632600 RESIDENTIAL WASHERS
Kenmore 11027642600 RESIDENTIAL WASHERS
Kenmore 11027721600 RESIDENTIAL WASHER
Kenmore 11027731600 RESIDENTIAL WASHERS
Kenmore 11027741600 RESIDENTIAL WASHERS
Kenmore 11027751700 RESIDENTIAL WASHER
Kenmore 11027761700 RESIDENTIAL WASHER
Kenmore 11027782700 RESIDENTIAL WASHER
Kenmore 11027802690 AUTOMATIC WASHER
Kenmore 11027802691 AUTOMATIC WASHER
Kenmore 11027812690 AUTOMATIC WASHER
Kenmore 11027812691 AUTOMATIC WASHER
Kenmore 11027812692 AUTOMATIC WASHER
Kenmore 11027822790 AUTOMATIC WASHER
Kenmore 11027824790 AUTOMATIC WASHER
Kenmore 11027831600 RESIDENTIAL WASHER
Kenmore 11027841600 RESIDENTIAL WASHERS
Kenmore 11027852790 AUTOMATIC WASHER
Kenmore 11027852791 AUTOMATIC WASHER
Kenmore 11027862790 AUTOMATIC WASHER
Kenmore 11027871600 RESIDENTIAL WASHERS
Kenmore 11027872600 RESIDENTIAL WASHERS
Kenmore 11027874600 RESIDENTIAL WASHERS
Kenmore 11027892790 AUTOMATIC WASHER
Kenmore 11027892791 AUTOMATIC WASHER
Kenmore 11027894790 AUTOMATIC WASHER
Kenmore 11027894791 AUTOMATIC WASHER
Kenmore 11027902790 AUTOMATIC WASHER
Kenmore 11027982790 AUTOMATIC WASHER
Kenmore 11028002010 AUTOMATIC WASHER
Kenmore 11028002011 AUTOMATIC WASHER
Kenmore 11028012010 AUTOMATIC WASHER
Kenmore 11028012011 AUTOMATIC WASHER
Kenmore 11028032700 RESIDENTIAL WASHER
Kenmore 11028032701 RESIDENTIAL WASHER
Kenmore 11028042700 RESIDENTIAL WASHER
Kenmore 11028042701 WASHER
Kenmore 11028062800 RESIDENTIAL WASHER
Kenmore 11028072800 RESIDENTIAL WASHER
Kenmore 11028081700 WASHER
Kenmore 11028082700 RESIDENTIAL WASHER
Kenmore 11028087700 RESIDENTIAL WASHER
Kenmore 11028091700 WASHER
Kenmore 11028092700 RESIDENTIAL WASHER
Kenmore 11028097700 WASHER
Kenmore 11028222700 RESIDENTIAL WASHER
Kenmore 11028222701 WASHER
Kenmore 11028299890 AUTOMATIC WASHER
Kenmore 11028322700 RESIDENTIAL WASHER
Kenmore 11028332700 RESIDENTIAL WASHER
Kenmore 11028352700 RESIDENTIAL WASHER
Kenmore 11028362700 RESIDENTIAL WASHER
Kenmore 11028372700 RESIDENTIAL WASHER
Kenmore 11028422700 RESIDENTIAL WASHER
Kenmore 11028432700 RESIDENTIAL WASHER
Kenmore 11028522700 RESIDENTIAL WASHER
Kenmore 11028522701 RESIDENTIAL WASHER
Kenmore 11028532700 RESIDENTIAL WASHER
Kenmore 11028532701 RESIDENTIAL WASHER
Kenmore 11028622700 RESIDENTIAL WASHER
Kenmore 11028622701 RESIDENTIAL WASHER
Kenmore 11028632700 RESIDENTIAL WASHER
Kenmore 11028632701 RESIDENTIAL WASHER
Kenmore 11028692700 RESIDENTIAL WASHER
Kenmore 11028692701 RESIDENTIAL WASHER
Kenmore 1102870090 AUTOMATIC WASHER
Kenmore 11028722700 RESIDENTIAL WASHER
Kenmore 11028732700 RESIDENTIAL WASHER
Kenmore 11028752700 RESIDENTIAL WASHER
Kenmore 11028762700 RESIDENTIAL WASHER
Kenmore 11028782700 RESIDENTIAL WASHER
Kenmore 11028802890 AUTOMATIC WASHER
  #2 (permalink)
Old 08-22-2013, 04:57 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
That would be my guess too, but with this model I don't think it is worth throwing money at it. The newer versions are substanially better.
If you want to try replacing the other electronic module and buy from this site you can return the part if it does not fix things.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE TRITON XL water starts into machine but never washes NC dishwasherprob Dishwasher Repair 1 03-22-2012 07:29 PM
Washing Machine Immediately Starts To Spin jhood Washer Repair 1 10-22-2010 07:40 AM
closing dishwasher door starts machine without start being pressed ronmer Dishwasher Repair 0 05-07-2010 11:09 AM
Wash machine starts on different segment of wash cycle than what we set it to rbarnes18 Washer Repair 1 01-01-2010 07:03 AM
Starts to pump during wash then shuts down, starts, stops real quidk sirgalagit Dishwasher Repair 1 10-03-2007 08:23 PM
