Discuss
Whirlpool Motor Switch 8529896 installation instructions
 in
Washer Repair
Can anyone please provide me with the installation instructions for the 8529896 motor switch? Customer lost instructions and it looks
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Motor Switch 8529896 installation instructions
  #1 (permalink)
Old 08-20-2013, 03:55 PM
Junior Member
supertechsappliance is on a distinguished road
Default Whirlpool Motor Switch 8529896 installation instructions
Model Number: 11024992300   Brand: Kenmore   Age: 5 - 10 years
Can anyone please provide me with the installation instructions for the 8529896 motor switch? Customer lost instructions and it looks like some wiring needs to be changed for this part to work. Thanks!
Related Models
Kenmore 11024992300 AUTOMATIC WASHER
Kenmore 11024994300 AUTOMATIC WASHER
Kenmore 11024996300 AUTOMATIC WASHER
Kenmore 11025062500 WASHER
Kenmore 11025064500 WASHER
Kenmore 11025066500 WASHER
Kenmore 11025292500 WASHER
Kenmore 11025292501 WASHER
Kenmore 11025292502 RESIDENTIAL WASHER
Kenmore 11025292503 RESIDENTIAL WASHER
Kenmore 11025294500 WASHER
Kenmore 11025294501 WASHER
Kenmore 11025294502 RESIDENTIAL WASHER
Kenmore 11025294503 RESIDENTIAL WASHER
Kenmore 11025832400 RESIDENTIAL WASHER
Kenmore 11025842400 AUTOMATIC WASHER
Kenmore 11025844400 AUTOMATIC WASHER
Kenmore 11025852400 AUTOMATIC WASHER
Kenmore 11025854400 AUTOMATIC WASHER
Kenmore 11025862400 AUTOMATIC WASHER
Kenmore 11025864400 AUTOMATIC WASHER
Kenmore 11026002010 AUTOMATIC WASHER
Kenmore 11026002011 AUTOMATIC WASHER
Kenmore 11026012010 AUTOMATIC WASHER
Kenmore 11026012011 AUTOMATIC WASHER
Kenmore 11026051690 COMMERCIAL AUTOMATIC WASHER
Kenmore 11026058690 COMMERCIAL AUTOMATIC WASHER
Kenmore 11026071690 COMMERCIAL WASHER
Kenmore 11026071691 COMMERCIAL WASHER
Kenmore 11026152500 WASHER COMMERCIAL
Kenmore 11026292690 AUTOMATIC WASHER
Kenmore 11026292691 AUTOMATIC WASHER
Kenmore 11026292692 AUTOMATIC WASHER
Kenmore 11026292693 AUTOMATIC WASHER
Kenmore 11026292694 WASHER
Kenmore 11026292695 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11026294690 AUTOMATIC WASHER
Kenmore 11026294691 AUTOMATIC WASHER
Kenmore 11026294692 AUTOMATIC WASHER
Kenmore 11026294693 AUTOMATIC WASHER
Kenmore 11026294694 WASHER
Kenmore 11026294695 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11026322500 WASHER
Kenmore 11026322501 WASHER
Kenmore 11026322502 RESIDENTIAL WASHER
Kenmore 11026322503 RESIDENTIAL WASHER
Kenmore 11026332500 RESIDENTIAL WASHER
Kenmore 11026332501 WASHER
Kenmore 11026332502 RESIDENTIAL WASHER
Kenmore 11026332503 RESIDENTIAL WASHER
Kenmore 11026342500 RESIDENTIAL WASHER
Kenmore 11026342501 WASHER
Kenmore 11026342502 RESIDENTIAL WASHER
Kenmore 11026342503 RESIDENTIAL WASHER
Kenmore 11026422500 RESIDENTIAL WASHER
Kenmore 11026422501 WASHER
Kenmore 11026422502 RESIDENTIAL WASHER
Kenmore 11026422503 RESIDENTIAL WASHER
Kenmore 11026432500 WASHER
Kenmore 11026432501 WASHER
Kenmore 11026432502 RESIDENTIAL WASHER
Kenmore 11026432503 RESIDENTIAL WASHER
Kenmore 1102644182 RESIDENTIAL WASHER
Kenmore 11026442500 WASHER
Kenmore 11026442501 WASHER
Kenmore 11026442502 RESIDENTIAL WASHER
Kenmore 11026442503 RESIDENTIAL WASHER
Kenmore 1102644722 RESIDENTIAL WASHER
Kenmore 11026622690 WASHER
Kenmore 11026622691 AUTOMATIC WASHER
Kenmore 11026632500 WASHER
Kenmore 11026632501 WASHER
Kenmore 11026632502 WASHER
Kenmore 11026632503 RESIDENTIAL WASHER
Kenmore 11026642500 WASHER
Kenmore 11026642501 washer
Kenmore 11026642502 WASHER
Kenmore 11026642503 RESIDENTIAL WASHER
Kenmore 11026652500 WASHER
Kenmore 11026652501 WASHER
Kenmore 11026652502 WASHER
Kenmore 11026652503 RESIDENTIAL WASHER
Kenmore 11026682503 RESIDENTIAL WASHER
Kenmore 11026692503 RESIDENTIAL WASHER
Kenmore 11026702690 AUTOMATIC WASHER
Kenmore 11026702691 AUTOMATIC WASHER
Kenmore 11026702692 AUTOMATIC WASHER
Kenmore 11026702693 AUTOMATIC WASHER
Kenmore 11026702694 AUTOMATIC WASHER
Kenmore 11026712690 WASHER
Kenmore 11026712691 AUTOMATIC WASHER
Kenmore 11026712692 AUTOMATIC WASHER
Kenmore 11026712693 AUTOMATIC WASHER
Kenmore 11026722690 WASHER
Kenmore 11026722691 AUTOMATIC WASHER
Kenmore 11026722692 AUTOMATIC WASHER
Kenmore 11026722693 AUTOMATIC WASHER
Kenmore 11026732500 WASHER
Kenmore 11026732501 WASHER
Kenmore 11026732502 WASHER
Kenmore 11026732503 RESIDENTIAL WASHER
Kenmore 11026742500 WASHER
Kenmore 11026742501 WASHER
Kenmore 11026742502 WASHER
Kenmore 11026742503 RESIDENTIAL WASHER
Kenmore 11026752500 WASHER
Kenmore 11026752501 WASHER
Kenmore 11026752502 WASHER
Kenmore 11026752503 RESIDENTIAL WASHER
Kenmore 11026791690 AUTOMATIC WASHER
Kenmore 11026791691 AUTOMATIC WASHER
Kenmore 11026801690 AUTOMATIC WASHER
Kenmore 11026801691 AUTOMATIC WASHER
Kenmore 11026801692 AUTOMATIC WASHER
Kenmore 11026808690 WASHER
Kenmore 11026808691 AUTOMATIC WASHER
Kenmore 11026808692 AUTOMATIC WASHER
Kenmore 11026809690 AUTOMATIC WASHER
Kenmore 11026812690 WASHER
Kenmore 11026812691 AUTOMATIC WASHER
  #2 (permalink)
Old 08-20-2013, 06:02 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
No wiring should need to be changed. Switch is a direct replacement for the old one. Connect motor wiring same as old switch and plug wire harness in and you should be good to go.
Eric
  #3 (permalink)
Old 08-21-2013, 07:05 AM
Expert
APP Volunteer
Default
This is the old style motor that does not have the 2-wire pigtail connection. You need to swap the wht/vio and yel wires from motor and you will need to cut the wht/orn wire and install quick disconnect connectors on them separately. I do see the old style switch available on e bay if you want to go that route.
Actually, you don't have to "swap" any wires. Place the motor wires onto the new switch exactly as they are from the old switch except for the wht/orn wire. Now, the wht/vio wire from the motor will be on the terminal labled Y on the switch and the yel wire from motor will be on the terminal labeled W.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
installation instructions numba1 Dryer Repair 0 08-30-2011 05:46 PM
whirlpool refrigerator installation instructions for ap4369390 filter housing topcat1 Refrigerator & Freezer Repair 0 08-17-2011 03:20 PM
installation instructions mariew19 Dishwasher Repair 0 01-27-2011 06:21 AM
Installation Instructions appart Washer Repair 0 11-16-2010 04:31 PM
Whirlpool Duet Shipping Bolt Installation Instructions? maxshiff Washer Repair 6 04-08-2009 07:24 AM
