Discuss
Maytag Tub Seal Replacement
 in
Washer Repair
I'm having difficulty removing the main hub assembly to get to the point where I can put the new seals
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Tub Seal Replacement
  #1 (permalink)
Old 08-20-2013, 01:14 PM
Junior Member
Bradfurt13 is on a distinguished road
Default Maytag Tub Seal Replacement
Model Number: MAV6000AWW   Brand: Maytag   Age: 5 - 10 years
I'm having difficulty removing the main hub assembly to get to the point where I can put the new seals in. I have removed the inner hub but this does not appear to use the spanner wrench type removal.
I'm at a standstill as to how to remove this.
See attached pictures.
Thanks, Brad
Related Models
Maytag MAV6000AWW WASHER, ATLANTIS
Maytag MAV6057AWQ WASHER, ATLANTIS
Maytag MAV6057AWW WASHER, ATLANTIS
Maytag MAV6200AWQ WASHER, ATLANTIS
Maytag MAV6200AWW WASHER, ATLANTIS
Maytag MAV6250AWQ WASHER, ATLANTIS
Maytag MAV6250AWW WASHER, ATLANTIS
Maytag MAV6257AWQ WASHER, ATLANTIS
Maytag MAV6257AWW WASHER, ATLANTIS
Maytag MAV6260AWW WASHER, ATLANTIS
Admiral MAV6300AGW WASHER-TOP LOADING
Maytag MAV6300AWQ WASHER, ATLANTIS
Maytag MAV6300AWW WASHER, ATLANTIS
Admiral MAV6300BGW WASHER-TOP LOADING
Admiral MAV6300CGW WASHER-TOP LOADING
Maytag MAV6357AWW WASHER, ATLANTIS
Maytag MAV6358AWW WASHER, ATLANTIS
Maytag MAV6451AGW WASHER, ATLANTIS
Maytag MAV6451AWQ WASHER, ATLANTIS
Maytag MAV6451AWW WASHER, ATLANTIS
Maytag MAV6457AWW WASHER, ATLANTIS
Maytag MAV6458AWW WASHER, ATLANTIS
Maytag MAV6548AWQ WASHER, ATLANTIS
Maytag MAV6548AWW WASHER, ATLANTIS
Maytag MAV6601AWQ WASHER, ATLANTIS
Maytag MAV6601AWW WASHER, ATLANTIS
Maytag MAV6650AWW WASHER, ATLANTIS
Maytag MAV7000AWQ WASHER, ATLANTIS
Maytag MAV7000AWW WASHER, ATLANTIS
Maytag MAV7057AWQ WASHER, ATLANTIS
Maytag MAV7057AWW WASHER, ATLANTIS
Maytag MAV7200AWQ WASHER, ATLANTIS
Maytag MAV7200AWW WASHER, ATLANTIS
Maytag MAV7257AWQ WASHER, ATLANTIS
Maytag MAV7257AWW WASHER, ATLANTIS
Maytag MAV7258AWQ WASHER, ATLANTIS
Maytag MAV7258AWW WASHER, ATLANTIS
Maytag MAV7260AWW WASHER, ATLANTIS
Maytag MAV7260BWW WASHER, ATLANTIS
Maytag MAV7357AWQ WASHER, ATLANTIS
Maytag MAV7357AWW WASHER, ATLANTIS
Maytag MAV7358AWQ WASHER, ATLANTIS
Maytag MAV7358AWW WASHER, ATLANTIS
Maytag MAV7450AWQ WASHER, ATLANTIS
Maytag MAV7450AWW WASHER, ATLANTIS
Maytag MAV7501EWW WASHER, ATLANTIS
Maytag MAV7504EWW WASHER, ATLANTIS
Maytag MAV7550AWQ WASHER, ATLANTIS
Maytag MAV7550AWW WASHER, ATLANTIS
Maytag MAV7551AWQ WASHER, ATLANTIS
Maytag MAV7551AWW WASHER, ATLANTIS
Maytag MAV7557EWQ WASHER, ATLANTIS
Maytag MAV7557EWW WASHER, ATLANTIS
Maytag MAV7580EWQ WASHER, ATLANTIS
Maytag MAV7580EWW WASHER, ATLANTIS
Admiral MAV7600ACQ WASHER-TOP LOADING
Admiral MAV7600AGW WASHER-TOP LOADING
Maytag MAV7600AWQ WASHER, ATLANTIS
Maytag MAV7600AWW WASHER, ATLANTIS
Admiral MAV7600BGW WASHER-TOP LOADING
Admiral MAV7600CGW WASHER-TOP LOADING
Maytag MAV7650AWQ WASHER, ATLANTIS
Maytag MAV7650AWW WASHER, ATLANTIS
Maytag MAV7657EWQ WASHER, ATLANTIS
Maytag MAV7657EWW WASHER, ATLANTIS
Maytag MAV7700AWQ WASHER, ATLANTIS
Maytag MAV7700AWW WASHER, ATLANTIS
Admiral MAV7750AGW WASHER-TOP LOADING
Admiral MAV7750BGW WASHER-TOP LOADING
Admiral MAV7750CGW WASHER-TOP LOADING
Maytag MAV7757AWQ WASHER, ATLANTIS
Maytag MAV7757AWW WASHER, ATLANTIS
Maytag MAV8000AWQ WASHER, ATLANTIS
Maytag MAV8000AWW WASHER, ATLANTIS
Maytag MAV8057AWQ WASHER, ATLANTIS
Maytag MAV8057AWW WASHER, ATLANTIS
Maytag MAV8260AWQ WASHER, ATLANTIS
Maytag MAV8260AWW WASHER, ATLANTIS
Maytag MAV8500AWQ WASHER, ATLANTIS
Maytag MAV8500AWW WASHER, ATLANTIS
Maytag MAV8551AWQ WASHER, ATLANTIS
Maytag MAV8551AWW WASHER, ATLANTIS
Maytag MAV8557AWQ WASHER, ATLANTIS
Maytag MAV8557AWW WASHER, ATLANTIS
Maytag MAV8600AWQ WASHER, ATLANTIS
Maytag MAV8600AWW WASHER, ATLANTIS
Maytag MAV8601AWQ WASHER, ATLANTIS
Maytag MAV8601AWW WASHER, ATLANTIS
Maytag MAV8757AWQ WASHER, ATLANTIS
Maytag MAV8757AWW WASHER, ATLANTIS
Maytag MAV9501EWQ WASHER, ATLANTIS
Maytag MAV9501EWW WASHER, ATLANTIS
Maytag MAV9504EWQ WASHER, ATLANTIS
Maytag MAV9504EWW WASHER, ATLANTIS
Maytag MAV9557EWQ WASHER, ATLANTIS
Maytag MAV9557EWW WASHER, ATLANTIS
Maytag MAV9600EWQ WASHER, ATLANTIS
Maytag MAV9600EWW WASHER, ATLANTIS
Maytag MAV9657EWQ WASHER, ATLANTIS
Maytag MAV9657EWW WASHER, ATLANTIS
Maytag MAV9750AGW WASHER, ATLANTIS
Maytag MAV9750AWQ WASHER, ATLANTIS
Maytag MAV9750AWW WASHER, ATLANTIS
Maytag MAVT236AWW WASHER-TOP LOADING
Maytag MAVT346AWW WASHER-TOP LOADING
Maytag MAVT446AWW WASHER-TOP LOADING
Maytag MAVT546EWW WASHER-TOP LOADING
Maytag MAVT634AWW WASHER, ATLANTIS
Maytag MAVT734EWW WASHER, ATLANTIS
Maytag MAVT754EWW WASHER, ATLANTIS
Maytag MAVT834AWQ WASHER, ATLANTIS
Maytag MAVT834AWW WASHER, ATLANTIS
Whirlpool MB1110SLQ MICROWAVE OVEN 1.1 CUBIC FOOT
Admiral MB1927PEHB REF - MAYTAG INT'L BOT MOUNT
Admiral MB1927PEHW REF - MAYTAG INT'L BOT MOUNT
Admiral MB2216PUAW REF - BOTTOM MOUNTS
Maytag MB2216PUAW11 REFRIGERATOR
Maytag MB2216PUAW2 REFRIGERATOR
Admiral MB2227PEHB REF - MAYTAG INT'L BOT MOUNT
Admiral MB2227PEHW REF - MAYTAG INT'L BOT MOUNT
Last edited by Bradfurt13 : 08-21-2013 at 07:04 PM. Reason: See new attachéd picture, is there a lock washer or something that needs to be removed?
  #2 (permalink)
Old 08-21-2013, 09:12 AM
Junior Member
Default
Anyone have any ideas? We are almost out of clothes
  #3 (permalink)
Old 08-22-2013, 06:08 AM
Junior Member
Default
See new picture, Is there a metal lock washer to remove? There is no set screw which is what I was expecting...
This does not have slots for a spanner wrench..I've turned it and that does not seem to loosen it.
  #4 (permalink)
Old 08-22-2013, 07:19 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
You need the spanner wrench and seal nut tool. Spanner wrench available elsewhere, #35-2968 You may need to block transmission from turning.
Pro TJ22002898 Seal Nut Tool - AppliancePartsPros.com
  #5 (permalink)
Old 08-22-2013, 10:10 AM
Junior Member
Default
Thank you.
Do I need to remove the white gear for the agitator first or does it come off as a unit?
- Brad
  #6 (permalink)
Old 08-22-2013, 11:18 AM
Expert
APP Volunteer
Default
The white part is the seal nut, it must be removed first. It does not drive the agitator, that is driven by the splines on the agitator shaft.
Eric
  #7 (permalink)
Old 08-22-2013, 11:53 AM
Junior Member
Default
Is there any good way to get this off without buying a $60 tool?
Are they both reverse threaded?
  #8 (permalink)
Old 08-22-2013, 12:06 PM
Expert
APP Volunteer
Default
Spanner wrench and hammer is the way we normally do it. They are not reverse thread.
Eric
  #9 (permalink)
Old 08-22-2013, 12:26 PM
Junior Member
Default
Well that explains why I turned it clockwise a little bit yesterday and didn't loosen
  #10 (permalink)
Old 08-23-2013, 08:46 AM
Junior Member
Default
Thanks for your help, the main problem was that I thought they were reverse threads.
I got everything off using a standard pipe wrench vs. buying a spanner wrench and seal nut tool for $75.
I appreciate the help.
- Brad
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag atlantis tub seal replacement kactussjack Washer Repair 1 04-03-2012 03:51 AM
Maytag Neptune Lip Seal Replacement Helix27 Washer Repair 1 02-16-2011 04:37 PM
Maytag Admiral Front Seal Replacement thekMeades5 Dryer Repair 5 03-26-2010 02:20 PM
Maytag Washer Tub Seal and Bearing Replacement Paully Washer Repair 1 01-09-2010 03:49 AM
Maytag top freezer door seal replacement cookie87 Refrigerator & Freezer Repair 4 09-04-2009 01:56 PM
