Discuss
Loose drum in Maytag front loader
 in
Washer Repair
We have a Maytag front loader in which the drum vibrates on the spin cycle so that it rubs on
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Loose drum in Maytag front loader
  #1 (permalink)
Old 02-09-2008, 11:41 PM
Lynton Lynton is offline
Junior Member
Lynton is on a distinguished road
Default Loose drum in Maytag front loader
Model Number: MAF 1200 AAW   Brand: Maytag   Age: 1 - 5 years
We have a Maytag front loader in which the drum vibrates on the spin cycle so that it rubs on the rubber seal and fills the drum with smoke.
Does anybody know what the problem might be?
Lynton
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-10-2008, 05:27 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
If it still shakes with no clothes in it and makes a noise in spin, you probably have bad bearings, or a busted spin basket spider support. Remove the back and pull off the belt and check the basket for bad bearings, if so, this is a major job to fix.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
frigidaire front loader charles schaus Washer Repair 0 02-08-2008 03:30 PM
problem with loose drum inside front loader Big G Washer Repair 1 12-18-2007 04:04 PM
Drum feels loose and rubs krg Dryer Repair 1 10-24-2007 05:12 AM
front loader not draining distress Washer Repair 1 09-14-2007 03:24 AM
Maytag Front loader door latch assembly bpcolll Washer Repair 4 08-29-2007 10:55 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
