The dispenser lever gets jammed when the dispenser cycles through IV and back to I. The lever bends up and jams the motor causing a rickety sound as the motor cannot cycle though properly. I have to use my finger to flick it back to the normal position to correct this.
How do i replace this white plastic lever? On the Sears part diagram it is part number 9. about 2.75 inches long.
