Discuss
Maytag Atlantis Top Load Washer
 in
Washer Repair
Fills with water like normal but won't advance and continue. Never had any problems with this unit. Related Models Maytag
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Atlantis Top Load Washer
  #1 (permalink)
Old 08-18-2013, 04:16 PM
Junior Member
almostgetitbob is on a distinguished road
Default Maytag Atlantis Top Load Washer
Model Number: MAV8551AWW   Brand: Maytag   Age: 5 - 10 years
Related Models
Maytag MAV8551AWW WASHER, ATLANTIS
Maytag MAV8557AWQ WASHER, ATLANTIS
Maytag MAV8557AWW WASHER, ATLANTIS
Maytag MAV8600AWQ WASHER, ATLANTIS
Maytag MAV8600AWW WASHER, ATLANTIS
Maytag MAV8601AWQ WASHER, ATLANTIS
Maytag MAV8601AWW WASHER, ATLANTIS
Maytag MAV8757AWQ WASHER, ATLANTIS
Maytag MAV8757AWW WASHER, ATLANTIS
Maytag MAV9501EWQ WASHER, ATLANTIS
Maytag MAV9501EWW WASHER, ATLANTIS
Maytag MAV9504EWQ WASHER, ATLANTIS
Maytag MAV9504EWW WASHER, ATLANTIS
Maytag MAV9557EWQ WASHER, ATLANTIS
Maytag MAV9557EWW WASHER, ATLANTIS
Maytag MAV9600EWQ WASHER, ATLANTIS
Maytag MAV9600EWW WASHER, ATLANTIS
Maytag MAV9657EWQ WASHER, ATLANTIS
Maytag MAV9657EWW WASHER, ATLANTIS
Maytag MAV9750AGW WASHER, ATLANTIS
Maytag MAV9750AWQ WASHER, ATLANTIS
Maytag MAV9750AWW WASHER, ATLANTIS
Maytag MAVT236AWW WASHER-TOP LOADING
Maytag MAVT346AWW WASHER-TOP LOADING
Maytag MAVT446AWW WASHER-TOP LOADING
Maytag MAVT546EWW WASHER-TOP LOADING
Maytag MAVT634AWW WASHER, ATLANTIS
Maytag MAVT734EWW WASHER, ATLANTIS
Maytag MAVT754EWW WASHER, ATLANTIS
Maytag MAVT834AWQ WASHER, ATLANTIS
Maytag MAVT834AWW WASHER, ATLANTIS
Whirlpool MB1110SLQ MICROWAVE OVEN 1.1 CUBIC FOOT
Admiral MB1927PEHB REF - MAYTAG INT'L BOT MOUNT
Admiral MB1927PEHW REF - MAYTAG INT'L BOT MOUNT
Admiral MB2216PUAW REF - BOTTOM MOUNTS
Maytag MB2216PUAW11 REFRIGERATOR
Maytag MB2216PUAW2 REFRIGERATOR
Admiral MB2227PEHB REF - MAYTAG INT'L BOT MOUNT
Admiral MB2227PEHW REF - MAYTAG INT'L BOT MOUNT
Thermador MB245 MICROWAVE
General Electric MB536BB1 Electric range
Whirlpool MB7120XYB0 Microwaves*
Whirlpool MB7120XYB1 Microwaves*
General Electric MB757WB1 Electric range
Maytag MBB1952GRQ REF - BOTTOM MOUNTS
Maytag MBB1952GRW REF - BOTTOM MOUNTS
Maytag MBB1952HEB REF - BOTTOM MOUNTS
Maytag MBB1952HEB1 REFRIGERATOR
Maytag MBB1952HEB10 REFRIGERATOR
Maytag MBB1952HEQ REF - BOTTOM MOUNTS
Maytag MBB1952HEW REF - BOTTOM MOUNTS
Maytag MBB1952HEW14 REFRIGERATOR
Maytag MBB1952HEW5 REFRIGERATOR
Maytag MBB1953WEB0 REFRIGERATOR
Maytag MBB1953WEB1 REFRIGERATOR
Maytag MBB1953WEB2 REFRIGERATOR
Maytag MBB1953WEW0 REFRIGERATOR
Maytag MBB1953WEW1 REFRIGERATOR
Maytag MBB1953WEW2 REFRIGERATOR
Maytag MBB1953XEB0 REFRIGERATOR
Maytag MBB1953XEW0 REFRIGERATOR
Maytag MBB1954GEB REF - BOTTOM MOUNTS
Maytag MBB1954GEQ REF - BOTTOM MOUNTS
Maytag MBB1954GES REF - BOTTOM MOUNTS
Maytag MBB1954GEW REF - BOTTOM MOUNTS
Maytag MBB1954HEW REF - BOTTOM MOUNTS
Maytag MBB1956GEB REF - BOTTOM MOUNTS
Maytag MBB1956GEQ REF - BOTTOM MOUNTS
Maytag MBB1956GES REF - BOTTOM MOUNTS
Maytag MBB1956GEW REF - BOTTOM MOUNTS
Maytag MBB1956HEB REF - BOTTOM MOUNTS
Maytag MBB1956HEB14 REFRIGERATOR
Maytag MBB1956HEQ REF - BOTTOM MOUNTS
Maytag MBB1956HES REF - BOTTOM MOUNTS
Maytag MBB1956HEW REF - BOTTOM MOUNTS
Maytag MBB1956HEW14 REFRIGERATOR
Maytag MBB1957VEB1 REFRIGERATOR
Maytag MBB1957VEB10 REFRIGERATOR
Maytag MBB1957VEB2 REFRIGERATOR
Maytag MBB1957VEW1 REFRIGERATOR
Maytag MBB1957VEW10 REFRIGERATOR
Maytag MBB1957VEW2 REFRIGERATOR
Maytag MBB1957WEB0 REFRIGERATOR
Maytag MBB1957WEB1 REFRIGERATOR
Maytag MBB1957WEW0 REFRIGERATOR
Maytag MBB1957WEW1 REFRIGERATOR
Maytag MBB2254GEB REF - BOTTOM MOUNTS
Maytag MBB2254GEQ REF - BOTTOM MOUNTS
Maytag MBB2254GES REF - BOTTOM MOUNTS
Maytag MBB2254GEW REF - BOTTOM MOUNTS
Maytag MBB2256GEB REF - BOTTOM MOUNTS
Maytag MBB2256GEQ REF - BOTTOM MOUNTS
Maytag MBB2256GES REF - BOTTOM MOUNTS
Maytag MBB2256GEW REF - BOTTOM MOUNTS
Maytag MBCM24FWBS00 WINE CELLAR
Maytag MBF1952VEW1 REFRIGERATOR
Maytag MBF1956HEB REF - BOTTOM MOUNTS
Maytag MBF1956HEQ REF - BOTTOM MOUNTS
Maytag MBF1956HES REF - BOTTOM MOUNTS
Maytag MBF1956HEW REF - BOTTOM MOUNTS
Maytag MBF1956KEB REF - BOTTOM MOUNTS
Maytag MBF1956KEB11 REFRIGERATOR
Maytag MBF1956KEB2 REFRIGERATOR
Maytag MBF1956KEB3 REFRIGERATOR
Maytag MBF1956KEB4 REFRIGERATOR
Maytag MBF1956KEQ REF - BOTTOM MOUNTS
Maytag MBF1956KEQ11 REFRIGERATOR
Maytag MBF1956KEQ2 REFRIGERATOR
Maytag MBF1956KEQ3 REFRIGERATOR
Maytag MBF1956KEQ4 REFRIGERATOR
Maytag MBF1956KEW REF - BOTTOM MOUNTS
Maytag MBF1956KEW11 REFRIGERATOR
Maytag MBF1956KEW2 REFRIGERATOR
Maytag MBF1956KEW3 REFRIGERATOR
Maytag MBF1956KEW4 REFRIGERATOR
Maytag MBF1958WEB0 REFRIGERATOR
Maytag MBF1958WEB1 REFRIGERATOR
Maytag MBF1958WES0 REFRIGERATOR
Maytag MBF1958WES1 REFRIGERATOR
Maytag MBF1958WES2 REFRIGERATOR
  #2 (permalink)
Old 08-18-2013, 04:28 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
Do you hear the motor running like it's trying to move? If so pop off the front and check to make sure your belt is on and that you have tension on the belt by adjusting motor accordingly to do so. Here's some schematics to help you break it down and parts to identify problem.
01-Base parts for Maytag MAV8551AWW - AppliancePartsPros.com
02-Cabinet parts for Maytag MAV8551AWW - AppliancePartsPros.com
  #3 (permalink)
Old 08-18-2013, 05:28 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Belt access is from underneath machine, not inside front panel. If no noise from motor and timer does not advance and it won't drain/spin, probably have a bad lid switch. If it does drain/spin, may be faulty water level pressure switch.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Atlantis MAV8551 Top Load Washer gephrat Washer Repair 0 09-21-2012 11:27 AM
Maytag Atlantis top load will not fill tdo61 Washer Repair 8 03-19-2012 09:37 AM
maytag atlantis top load washing machine CHUD Washer Repair 1 11-07-2010 05:56 AM
Maytag Atlantis Washer fetz Washer Repair 1 12-15-2009 06:36 PM
Maytag Atlantis Washer rmom3003 Washer Repair 3 07-30-2009 06:09 PM
