Discuss
need help if its the timer
 in
Washer Repair
hi can someone help me . my washer it keeps filling with water even if the switch for the level
Appliance Repair Forum > Appliance Repair Help > Washer Repair » need help if its the timer
  #1 (permalink)
Old 08-17-2013, 02:16 PM
Junior Member
kingsnana is on a distinguished road
Default need help if its the timer
Model Number: spacemaker   Brand: GE   Age: 5 - 10 years
hi can someone help me . my washer it keeps filling with water even if the switch for the level of water is on low and wont stop . when I manually move the knob for the washer to go through the cycles the cycle for emptying the water and the spin cycle works . and I just noticed that when I opened the top with the machine in spin it opened and it never did that before it always locked .
Related Models
Amana SPD22NL REF - SXS/I&W
Amana SPD22NW REF - SXS/I&W
Amana SPD22Q2E REF - SXS/I&W
Amana SPD22Q2L REF - SXS/I&W
Amana SPD22Q2W REF - SXS/I&W
Amana SPD25AE REF - SXS/I&W
Amana SPD25AL REF - SXS/I&W
Amana SPD25AW REF - SXS/I&W
Amana SPD25QA3E REF - SXS/I&W
Amana SPD25QA3L REF - SXS/I&W
Amana SPD25QA3W REF - SXS/I&W
Amana SPD25TE REF - SXS/I&W
Amana SPD25TL REF - SXS/I&W
Amana SPD25TW REF - SXS/I&W
Amana SPD26VL REF - SXS/I&W
Amana SPD26VW REF - SXS/I&W
Amana SPD27Q2E REF - SXS/I&W
Amana SPD27Q2L REF - SXS/I&W
Amana SPD27Q2W REF - SXS/I&W
Hardwick SPG8441RTA719DZ WALLOVEN-STD DBL OVEN GAS
Hardwick SPG8441RTW719DZ WALLOVEN-STD DBL OVEN GAS
Amana SPN22G REF - SXS/I&W
Amana SPN22G-A REF - SXS/I&W
Amana SPN22G-AG REF - SXS/I&W
Amana SPN22G-C REF - SXS/I&W
Amana SPN22N REF - SXS/I&W
Amana SPN22N-A REF - SXS/I&W
Amana SPN22N-AG REF - SXS/I&W
Amana SPN22N-C REF - SXS/I&W
Amana SQ22NBL REF - SXS/I&W
Amana SQ22NBW REF - SXS/I&W
Amana SQD20NL REF - SXS/I&W
Amana SQD20NW REF - SXS/I&W
Amana SQD22NBL REF - SXS/I&W
Amana SQD22NBW REF - SXS/I&W
Amana SQD22NL REF - SXS/I&W
Amana SQD22NW REF - SXS/I&W
Amana SQD23VL REF - SXS/I&W
Amana SQD23VW REF - SXS/I&W
Amana SQD25MB2L REF - SXS/I&W
Amana SQD25MB2W REF - SXS/I&W
Amana SQD25MB3E REF - SXS/I&W
Amana SQD25MB3L REF - SXS/I&W
Amana SQD25MB3W REF - SXS/I&W
Amana SQD25MB4E REF - SXS/I&W
Amana SQD25MB4L REF - SXS/I&W
Amana SQD25MB4W REF - SXS/I&W
Amana SQD25MBG REF - SXS/I&W
Amana SQD25MBL REF - SXS/I&W
Amana SQD25MBW REF - SXS/I&W
Amana SQD25N2L REF - SXS/I&W
Amana SQD25N2W REF - SXS/I&W
Amana SQD25NB2L REF - SXS/I&W
Amana SQD25NB2W REF - SXS/I&W
Amana SQD25NBE REF - SXS/I&W
Amana SQD25NBL REF - SXS/I&W
Amana SQD25NBW REF - SXS/I&W
Amana SQD25NL REF - SXS/I&W
Amana SQD25NW REF - SXS/I&W
Amana SQD25TL REF - SXS/I&W
Amana SQD25TW REF - SXS/I&W
Amana SQD25VL REF - SXS/I&W
Amana SQD25VW REF - SXS/I&W
Amana SQD26VE REF - SXS/I&W
Amana SQD26VL REF - SXS/I&W
Amana SQD26VW REF - SXS/I&W
Amana SR-19 REF - SXS/I&W
Amana SR-522E REF - SXS/I&W
Amana SR-522E-A REF - SXS/I&W
Amana SR-522E-C REF - SXS/I&W
Amana SR-522E-G REF - SXS/I&W
Amana SR-522E-L REF - SXS/I&W
Amana SR17A REF - SXS/I&W
Amana SR17A-A REF - SXS/I&W
Amana SR17A-AG REF - SXS/I&W
Amana SR17A-C REF - SXS/I&W
Amana SR17F REF - SXS/I&W
Amana SR17G REF - SXS/I&W
Amana SR17G-1 REF - SXS/I&W
  #2 (permalink)
Old 08-17-2013, 04:27 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
First off you need a model number to help..........And what you gave is a model of a microwave.
As far as your washer goes are you using HE soap if it's an HE unit? Check the pressure switch and water level switch. Sounds like you possibly have a bad door lock as well. Go to youtube and watch video's about your problem
  #3 (permalink)
Old 08-17-2013, 04:46 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Well, there is a GE spacemaker stacked washer/dryer but we do need the specific model number.
  #4 (permalink)
Old 08-17-2013, 05:15 PM
Junior Member
Default
Quote:
it is a stackable like you said where do I find the model number I cant find the book for it right now
  #5 (permalink)
Old 08-17-2013, 06:06 PM
Expert
APP Volunteer
Default
Check under the washer lid or dryer door.
  #6 (permalink)
Old 08-17-2013, 06:59 PM
Junior Member
Default
ok I found the book lol its a GE spacemaker model number WSM2780DAWWW
  #7 (permalink)
Old 08-17-2013, 08:04 PM
Expert
APP Volunteer
Default
Remove washer front panel and with tub empty of water, disconnect pressure hose from outer tub connection. Check for gunk in this tube and in tub where hose connects. Clean out any gunk found. Follow hose up to where it connects to pressure switch behind control panel. Look for any kinks, cracks or holes. Blow into hose and you should hear the pressure switch click. Reconnect hose at tub connection and disconnect hose at pressure switch. Blow through hose to make sure it's clear. When washer is filling with water, it creates air pressure in this hose which activates a diaphram in the switch to turn the water valve off when proper level is reached. If you see water going up into the hose, there is a leak somewhere, possibly a bad diaphram in the switch. If hose is clear and you find no leaks in the hose, replace the pressure switch.
GE WH12X10083 Switch Water Level - AppliancePartsPros.com
Eric
  #8 (permalink)
Old 08-22-2013, 11:47 PM
Junior Member
Default
hey Eric thank you soooo much for all your help I had to wait for my husband to come back he was out of state . and I now have my washing machine back it was the hose it broke from the bottom . have a good one
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE hydrowave wbsr3140g0ww top load: Timer knob and timer not in sync katwoman Washer Repair 2 04-19-2013 02:13 PM
Washer timer motor in timer assembly marinekilz Washer Repair 2 10-31-2011 06:14 PM
Maytag washer, timer good till rinse-no spin,drain orstop/timer keeps clicking freely partsparts Washer Repair 3 08-23-2010 01:50 AM
Kenmore Dryer Timer not advancing in Auto Dry or Timer Mode but it does heat and dry dspeidel Dryer Repair 6 08-25-2009 02:23 PM
GE Top Loader--Problem with Timer Knob or Timer crmothorpe Washer Repair 3 04-27-2009 06:08 AM
