| » Whirlpool washer won't spin or drain |
Model Number: lsr6332kq1 Brand: Whirlpool Age: 5 - 10 years
I have replaced the door switch thinking it might be broke, but the machine still won't spin or drain. The cycle stops after agitation and nothing , no sound no movement. I ran the macine with the front off and the pump was forcing circulation into the outer part of the tub, I then took the pump off the drive and the circulation was not there. Could the drain hose be clogged or the drive motor not be working in reverse ?
Ads By Google Related Models Last edited by Jon B : 10-09-2009 at 08:41 AM. |
First, Make sure you connected the lid switch when you reassembled the machine. If the machine still agitates but does not spin and makes no noises that is the likely issue.
Next, With the washer turned on to the spin cycle you need to check for voltage between the blue and white wires at the motor. Do not try this if you are not familiar with using a volt meter, you can get electrocuted. If you do have 120 volts the motor is bad. If you do not have 120 volts check the blue and white wires at the timer, not having 120 volts means a bad timer. If there is voltage at the timer but not at the motor then there is a break in the wiring somewhere and is very hard to find. All this is assuming the machine was able to fill with water and made no noises or humming when you tried to use the spin cycle. Double check the power coming into the machine as well in case a breaker was tripped. If you have never used a volt meter before call a professional to avoid injury. |
| Display Modes | |
| whirlpool washer will not drain or spin | llbishop7@cs.com | Washer Repair | 3 | 08-17-2012 03:24 PM |
| Whirlpool washer won't drain or spin | KellaC32 | Washer Repair | 3 | 12-02-2009 10:37 AM |
| whirlpool duet washer will not drain and spin | bcanebres | Washer Repair | 0 | 11-25-2009 07:57 AM |
| whirlpool washer wont spin but will drain | charlissa | Washer Repair | 1 | 10-21-2009 04:03 AM |
| Whirlpool washer will not drain or spin. Is it the lid switch? | conramana | Washer Repair | 2 | 06-11-2009 08:55 PM |
