Discuss
GE Washer Won't Agitate Or Spin
 in
Washer Repair
Hi everyone, I have a GE washer, Model WJRE5550K2WW that fills and drains, but has stopped agitating or spinning. In
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE Washer Won't Agitate Or Spin
  #1 (permalink)
Old 08-15-2013, 04:01 PM
Junior Member
Pat401 is on a distinguished road
Default GE Washer Won't Agitate Or Spin
Model Number: WJRE5550K2WW   Brand: GE   Age: 1 - 5 years
Hi everyone,
I have a GE washer, Model WJRE5550K2WW that fills and drains, but has stopped agitating or spinning. In the past, I have been able to reset it using the lid method, but no longer.
The tub spins freely, the shaft isn't broken, and the belt is good.
I tested the lid switch and the fuse, both OK. I have 120V between the white/red and the red/black wires on the left-hand plug.
From where I sit, it looks like a new motor is in order. Is there anything else I should check first?
Thanks in advance,
Pat
Related Models
General Electric WJRE5550K2WW WASHER
General Electric WJRE5550K3WW WASHER
General Electric WJRR4170E0CC Washer
General Electric WJRR4170E0WW Washer
General Electric WJRR4170E1CC Washer
General Electric WJRR4170E1WW Washer
General Electric WJRR4170E3CC Washer
General Electric WJRR4170E3WW Washer
General Electric WJRR4170E4CC Washer
General Electric WJRR4170E4WW Washer
General Electric WJRR4170E5CC Washer
General Electric WJRR4170E5WW Washer
General Electric WJRR4170E6CC Washer
General Electric WJRR4170E6WW Washer
General Electric WJRR4170G0WW Washer
General Electric WJRR4170G1WW WASHER
General Electric WJRR4170G2WW WASHER
General Electric WJRR4170G3WW WASHER
General Electric WJRR4170G4WW WASHER
General Electric WJRR4170G5WW WASHER
General Electric WJRR4170G6WW WASHER
General Electric WJSE3110A0AA Washer
General Electric WJSE3110A0CC Washer
General Electric WJSE3110A0WW Washer
General Electric WJSE3110A2CC Washer
General Electric WJSE3110A2WW Washer
General Electric WJSE4150B0CC Washer
General Electric WJSE4150B0WW Washer
General Electric WJSE4150B1CC Washer
General Electric WJSE4150B1WW Washer
General Electric WJSE4150B2CC Washer
General Electric WJSE4150B2WW Washer
General Electric WJSE4150B3CC Washer
General Electric WJSE4150B3WW Washer
General Electric WJSR1070A1AA Washer
General Electric WJSR1070A1CC Washer
General Electric WJSR1070A1WW Washer
General Electric WJSR1070A2AA Washer
General Electric WJSR1070A2WW Washer
General Electric WJSR2070B0CC Washer
General Electric WJSR2070B0WW Washer
General Electric WJSR2070B2CC Washer
General Electric WJSR2070B2WW Washer
General Electric WJSR2070B3CC Washer
General Electric WJSR2070B3WW Washer
General Electric WJSR2070B4CC Washer
General Electric WJSR2070B4WW Washer
General Electric WJSR2070B9WW WASHER
General Electric WJSR2070D0WW Washer
General Electric WJSR2070D1WW Washer
General Electric WJSR2070D2WW Washer
General Electric WJSR2070D3WW Washer
General Electric WJSR2070D5WW Washer
General Electric WJSR2070D6WW Washer
General Electric WJSR2080T2AA Washer
General Electric WJSR2080T2WB Washer
General Electric WJSR2080T2WW Washer
General Electric WJSR2080T3AA Washer
General Electric WJSR2080T3WB Washer
General Electric WJSR2080T3WW Washer
General Electric WJSR2080T5AA Washer
General Electric WJSR2080T5WB Washer
General Electric WJSR2080T5WW Washer
General Electric WJSR2080T6AA Washer
General Electric WJSR2080T6WB Washer
General Electric WJSR2080T6WW Washer
General Electric WJSR2080T8AA Washer
General Electric WJSR2080T8WB Washer
General Electric WJSR2080T8WW Washer
General Electric WJSR2080TAAA Washer
General Electric WJSR2080TAWB Washer
General Electric WJSR2080TAWW Washer
General Electric WJSR2080V1AA Washer
General Electric WJSR2080V1WW Washer
General Electric WJSR2080V2AA Washer
General Electric WJSR2080V2WW Washer
General Electric WJSR2080V3AA Washer
General Electric WJSR2080V3WW Washer
General Electric WJSR4160D0CC Washer
General Electric WJSR4160D0WW Washer
General Electric WJSR4160D2CC Washer
General Electric WJSR4160D2WW Washer
General Electric WJSR4160D5CC Washer
General Electric WJSR4160D5WW Washer
General Electric WJSR4160D6CC Washer
General Electric WJSR4160D6WW Washer
General Electric WJSR4160DACC Washer
General Electric WJSR4160DAWW Washer
General Electric WJSR4160DCCC Washer
General Electric WJSR4160DCWW Washer
General Electric WJSR4160G0WW Washer
General Electric WJSR4160G1WW WASHER
General Electric WJSR4160G2WW WASHER
General Electric WJSR4160G3WW WASHER
General Electric WJSR4160G4WW WASHER
General Electric WJSR4160G5WW WASHER
General Electric WJSR4160G6WW WASHER
General Electric WJXR2080T2AA Washer
General Electric WJXR2080T2WW Washer
General Electric WJXR2080T3AA Washer
General Electric WJXR2080T3WW Washer
General Electric WJXR2080T5AA Washer
General Electric WJXR2080T5WW Washer
General Electric WJXR2080T6AA Washer
General Electric WJXR2080T6WW Washer
General Electric WJXR2080T8AA Washer
General Electric WJXR2080T8WW Washer
General Electric WJXR2080TAAA Washer
General Electric WJXR2080TAWW Washer
General Electric WJXR2080V0AA Washer
General Electric WJXR2080V0WW Washer
Whirlpool WKP85800 30" ELECTRIC RANGE CERAN COOKTOP
General Electric WKRE5500K0WW WASHER
General Electric WKRE5550K0WW WASHER
General Electric WKRE6280D0WW Washer
General Electric WKRE6280D1WW Washer
General Electric WKRE6280DCWW Washer
General Electric WKSE5260E0WW Washer
General Electric WKSE5260E1WW Washer
General Electric WKSE5260E6WW Washer
  #2 (permalink)
Old 08-16-2013, 01:43 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Are you getting any error codes via the flashing light on the motor? You need to determine if it is the mode shifter, but if no error codes you may end up replacing the motor/inverter on spec. If you order from this site you can return the part if it is not needed or does not fix the problem.
__________________
  #3 (permalink)
Old 08-16-2013, 02:15 PM
Junior Member
Default
Thanks for the response!
Sorry, forgot to mention that.
No trouble codes - just the normal 1 on, 1 off flashing.
I did buy the motor through this site; hoping for the best!
Will follow up after I install, hopefully Monday.
  #4 (permalink)
Old 08-19-2013, 12:46 PM
Junior Member
Smile Great success!
I ordered a replacement motor at 8:30 pm Thursday, and it arrived Saturday morning. I wasn't expecting it until Monday!
Anyhoo, a quick motor change later (getting the belt back on was the hardest part) and I'm back in business. The washer works as good as new, and more importantly, my wife is happy!
  #5 (permalink)
Old 08-19-2013, 04:14 PM
Senior Expert
APP Volunteer
Default
Great, nice diagnosis on your part. Thanks for the update.
__________________
  #6 (permalink)
Old 12-22-2013, 01:22 PM
Junior Member
mwardo3 is on a distinguished road
Default
What does it mean if there are no lights flashing on the motor?
  #7 (permalink)
Old 12-22-2013, 01:33 PM
Senior Expert
APP Volunteer
Default
There is an in line fuse in the wiring to the right, if it is blown replace it and see if that does not fix the problem.
If it is not blown or this is no fuse (later models might not have one) then check the wiring for a break or lack of continuity. If it is ok you will probably need to replace the motor/inverter assembly. Given the cost think about if you want to replace the machine instead.
__________________
  #8 (permalink)
Old 12-31-2013, 07:02 AM
Junior Member
Default
I replaced the fuse and now it works great. I don't know why they don't list the fuse in the trouble shooting section.
  #9 (permalink)
Old 01-01-2014, 11:51 AM
Senior Expert
APP Volunteer
Default
GE is famous for this. Glad you got it fixed and that it was an easy solution.
Thanks for the update, Happy New Year
__________________
  #10 (permalink)
Old 01-27-2014, 11:51 AM
Junior Member
bobcat1971 is on a distinguished road
Default Fuse location
Where is the Fuse located?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer does not agitate or spin rags1 Washer Repair 1 05-04-2013 07:29 PM
GE washer won't spin/agitate pordlawk Oven Repair (including Ranges and Cooktops) 0 05-12-2012 08:54 PM
Kenmore Washer Won't Spin,Agitate,or Spin (Will Fill) cowboys#1 Washer Repair 8 01-13-2011 10:13 AM
Washer will agitate but not spin/spin slowly sainthooligan Washer Repair 11 07-24-2010 10:34 AM
washer won't agitate or spin out misssue Washer Repair 1 06-15-2009 10:34 AM
