Discuss
Won't spin
 in
Washer Repair
The washer will pump all the water out, but won't spin without me manually rotating the basket until it won't
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Won't spin
  #1 (permalink)
Old 08-14-2013, 08:01 AM
Junior Member
Beezy is on a distinguished road
Default Won't spin
Brand: Estate   Age: 1 - 5 years
The washer will pump all the water out, but won't spin without me manually rotating the basket until it won't manually rotate any more. How can I tell if it's the clutch, the washer drive block or something else?
  #2 (permalink)
Old 08-14-2013, 08:13 AM
Junior Member
Default
One more clue...it doesn't have as much trouble "getting going" spinning with a light load as it does if there are towels or jeans in there.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
LOW-SPIN DURING SPIN CYCLE of MayTag Neptune Dryer/Washer stack mrdhoffman Washer Repair 1 08-30-2011 06:45 PM
loud noise on spin cycle,the faster the spin gets the louder the winnig gets Edward Loeb Washer Repair 3 02-02-2011 07:30 AM
motor, belt & trans pully spin, no agitation/spin cycle slavens Washer Repair 2 05-08-2010 04:10 PM
Replaced clutch (fixed wet clothes after spin) makes a noise when it starts spin??? mikeal21 Washer Repair 1 03-01-2010 06:21 PM
Frigidare front load washer will not spin durning final spin cyle binky8992 Washer Repair 2 08-19-2009 06:29 PM
