Worked OK the last time, this time, nothing. The washer has power because the front panel light comes on when timer is turned to one of the cycles. When we pull timer know out to start washer it does not fill & nothing happens. Turned timer to a spin cycle, still nothing happens. Haven't pulled anything apart yet but looking for suggestions on where to start looking. My guess is maybe lid switch or maybe timer. I thought about water valve, but I don't think that would affect spin. Any thoughts? Also, any tricks to get the control panel off - think there are a couple of screws you get to from the back of the washer, then what (any tricks). :) I know this is an oldie but we like it because it has lots of options and up to now has worked great. Thanks for any help.
