Discuss
GE washer clutch grinding on clutch spring clip
 in
Washer Repair
Our GE WCSE3100 washer works, but makes loud grinding noises during agitation and the spin cycle. I took the washer
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE washer clutch grinding on clutch spring clip
  #1 (permalink)
Old 08-11-2013, 06:29 PM
Junior Member
fixler1 is on a distinguished road
Default GE washer clutch grinding on clutch spring clip
Model Number: WCSE3100   Brand: GE   Age: More than 10 years
Our GE WCSE3100 washer works, but makes loud grinding noises during agitation and the spin cycle. I took the washer apart and the clutch is grinding on the clutch spring clip. The clutch has been ground down very unevenly almost to the retaining clip on the clutch.
I've checked the drive block, the apron, suspension rods, and transmission pulley. They all seem fine.
I can replace the clutch and spring clip, but will that fix the clutch from grinding on the clutch spring clip?
Related Models
General Electric WCSE3100A0AA Washer
General Electric WCSE3100A0WW Washer
General Electric WCSE3100A1AA Washer
General Electric WCSE3100A1WW Washer
General Electric WCSE3100A2WW Washer
General Electric WCSE4160B0CC Washer
General Electric WCSE4160B0WW Washer
General Electric WCSE4160B1CC Washer
General Electric WCSE4160B1WW Washer
General Electric WCSE4160B2CC Washer
General Electric WCSE4160B2WW Washer
General Electric WCSE4160B3CC Washer
General Electric WCSE4160B3WW Washer
General Electric WCSE4230A0AA Washer
General Electric WCSE4230A0WW Washer
General Electric WCSE6270B0WW Washer
General Electric WCSE6270B1CC Washer
General Electric WCSE6270B1WW Washer
General Electric WCSE6270B2CC Washer
General Electric WCSE6270B2WW Washer
General Electric WCSE6270B3CC Washer
General Electric WCSE6270B3WW Washer
Frigidaire WCSFW0 Frg(v1) / Top Load Washer
Maytag WCSH7 WINE CELLAR / UNDER COUNTER REF
Frigidaire WCSLH1 Frg(v5) / 27 " Washer
Frigidaire WCSLL0 Frg(v4) / 27 " Washer
Frigidaire WCSLL1 Frg(v6) / 27 " Washer
Frigidaire WCSLW0 Frg(v3) / 27 " Washer
Frigidaire WCSLW1 Frg(v4) / 27 " Washer
General Electric WCSR2070T2AA Washer
General Electric WCSR2070T2WW Washer
General Electric WCSR2070T3AA Washer
General Electric WCSR2070T3WW Washer
General Electric WCSR2070T5AA Washer
General Electric WCSR2070T5WW Washer
General Electric WCSR2070T6AA Washer
General Electric WCSR2070T6WW Washer
General Electric WCSR2070T8AA Washer
General Electric WCSR2070T8WW Washer
General Electric WCSR2070TAAA Washer
General Electric WCSR2070TAWW Washer
General Electric WCSR2070TBAA Washer
General Electric WCSR2070TBWW Washer
General Electric WCSR2070TCAA Washer
General Electric WCSR2070TCWW Washer
General Electric WCSR2070TDAA Washer
General Electric WCSR2070TDWW Washer
General Electric WCSR2080B0CC Washer
General Electric WCSR2080B0WW Washer
General Electric WCSR2080B1CC Washer
General Electric WCSR2080B1WW Washer
General Electric WCSR2080B2CC Washer
General Electric WCSR2080B2WW Washer
General Electric WCSR2080B3CC Washer
General Electric WCSR2080B3WW Washer
General Electric WCSR2080B4CC Washer
General Electric WCSR2080B4WW Washer
General Electric WCSR2080B5CC Washer
General Electric WCSR2080B5WW Washer
General Electric WCSR2080B9WW WASHER
General Electric WCSR2090D0CC Washer
General Electric WCSR2090D0WW Washer
General Electric WCSR2090D1WW Washer
General Electric WCSR2090D2CC Washer
General Electric WCSR2090D2WW Washer
General Electric WCSR2090D3WW Washer
General Electric WCSR2090D4WW Washer
General Electric WCSR2090D5CC Washer
General Electric WCSR2090D5WW Washer
General Electric WCSR2090D6WW Washer
General Electric WCSR2090D7WW Washer
General Electric WCSR2090D8WW Washer
General Electric WCSR2090DACC Washer
General Electric WCSR2090DAWW Washer
General Electric WCSR2090DBCC Washer
General Electric WCSR2090DBWW Washer
General Electric WCSR2090DCCC Washer
General Electric WCSR2090DCWW Washer
General Electric WCSR2090DDCC Washer
General Electric WCSR2090DDWW Washer
General Electric WCSR2090DGCC Washer
General Electric WCSR2090DGWW Washer
General Electric WCSR2090G0CC Washer
General Electric WCSR2090G0WW Washer
General Electric WCSR2090G1CC Washer
General Electric WCSR2090G1WW Washer
General Electric WCSR2090G2CC Washer
General Electric WCSR2090G2WW Washer
General Electric WCSR2090G3CC WASHER
General Electric WCSR2090G3WW WASHER
General Electric WCSR2090G4CC WASHER
General Electric WCSR2090G4WW WASHER
General Electric WCSR2090G5CC WASHER
General Electric WCSR2090G5WW WASHER
General Electric WCSR2090G6CC WASHER
General Electric WCSR2090G6WW WASHER
General Electric WCSR2090G7CC WASHER
General Electric WCSR2090G7WW WASHER
General Electric WCSR2090G8CC WASHER
General Electric WCSR2090G8WW WASHER
General Electric WCSR2090G9CC WASHER
General Electric WCSR2090G9WW WASHER
General Electric WCSR411078AA WASHER
General Electric WCSR4110T6AA Washer
General Electric WCSR4110T6WW Washer
General Electric WCSR4110T8AA Washer
General Electric WCSR4110T8WW Washer
General Electric WCSR4110TAAA Washer
General Electric WCSR4110TAWW Washer
General Electric WCSR4110TBAA Washer
General Electric WCSR4110TBWW Washer
General Electric WCSR4110TCAA Washer
General Electric WCSR4110TCWW Washer
General Electric WCSR4170D0CC Washer
General Electric WCSR4170D0WW Washer
General Electric WCSR4170D5CC Washer
General Electric WCSR4170D5WW Washer
General Electric WCSR4170D6CC Washer
General Electric WCSR4170D6WW Washer
  #2 (permalink)
Old 08-11-2013, 06:33 PM
Junior Member
Default
  #3 (permalink)
Old 08-11-2013, 07:16 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
The only way you can have relative motion between the clutch and spring clip is if the motor shaft drive pin is missing. You need to remove the clutch from the motor shaft to check the pin. It is a roll pin and is not a normal replacement part as far as I know. You will have to find a suitable substitute. The pin drives the clutch so there should never be any relative motion between the clutch and spring clip.
Eric
  #4 (permalink)
Old 08-11-2013, 08:14 PM
Junior Member
Default
Thanks, Eric! The roll pin seems to fit the clutch ok. Here's a pic of the clutch and the roll pin. (I put a white sheet of paper on the floor of the washer so you can see the metal dust.)
Here's a pic of the clutch. You can see how worn the top of the clutch is where it meets the spring clip.
Here's a video so you can hear the washer noises.
http://www.youtube.com/watch?v=HtBn4...ature=youtu.be
  #5 (permalink)
Old 08-11-2013, 09:18 PM
Expert
APP Volunteer
Default
Take the clutch apart so you can examine it. Here's a couple pic's of one I have on the bench. The motor shaft roll pin fits into the recess in the clutch and the spring clip fits over the end of the motor shaft so the clutch and spring clip should be rotating in unison. The only way the clip can wear the clutch is if the roll pin is not engaged or the clutch is broken. Never seen that before.
Eric
  #6 (permalink)
Old 08-12-2013, 12:02 AM
Junior Member
Default
Those pics were very helpful! Thank you again.
The roll pin engages the clutch. So I checked the inside of my clutch. It's very worn. You can see in the pic that the bottom and sides have been ground down. Could the unevenness of the clutch cause the clutch to grind on the clutch spring clip?
I have replaced the roll pin a couple times because the original roll pin broke. I first tried an OEM part, but it was 1.75" long, and wouldn't fit the clutch. So I used a 3/16"x1" roll pin, which is slightly smaller than the hole in the motor shaft and it moved around a little. I think the small size of the roll pin caused the unusual wearing inside of the clutch. When I fixed the washer another time, I couldn't find the roll pin and replaced it with a 1/4"x1" roll pin. This size of roll pin fits snugly inside the motor shaft.
So I probably just need a new clutch?
  #7 (permalink)
Old 08-12-2013, 06:24 AM
Expert
APP Volunteer
Default
Yes, I'd say you definitely need a new clutch. The question is, why is your roll pin breaking? Does the washer spin and agitate ok? Is it easy to rotate the motor pulley by hand in either direction? Spin direction will be a little more difficult but still relatively easy. Use two hands in spin direction to keep the brake disengaged. If it's real stiff, you have other issues.
Eric
  #8 (permalink)
Old 08-12-2013, 11:06 AM
Junior Member
Default
Not sure what caused the roll pin to break, but it's only happened once. The motor pulley rotates easily in both directions. I'll put in a new clutch, which will arrive in a week. I'll give you an update then.
Thanks again, Eric!
  #9 (permalink)
Old 09-02-2013, 09:30 AM
Junior Member
Default
The washer is fixed! I had to use a different sized roll pin (5/32 x 3/4), but everything is working and the washer is very quiet now. Thanks so much, Eric!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Clutch clip falls off bjlpjs1234 Washer Repair 5 08-11-2013 06:34 PM
where does the clutch clip go? tameralcmmt Washer Repair 1 11-11-2010 09:39 AM
replacing a retaining clip for clutch on hotpoint washer johnice Washer Repair 1 03-13-2009 04:24 AM
How do you remove clip on clutch totalc Washer Repair 0 02-28-2009 11:22 AM
clutch clip Glinda Washer Repair 1 02-19-2009 03:46 AM
