Discuss
Calypso stuck in rinse / spin cycle
 in
Washer Repair
Please help! I have a Kenmore Calypso washer (about 5 years old) 110.22082102. It recently began having problems when
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Calypso stuck in rinse / spin cycle
  #1 (permalink)
Old 02-09-2008, 04:59 PM
HGonz HGonz is offline
Junior Member
HGonz is on a distinguished road
Default Calypso stuck in rinse / spin cycle
Model Number: 110.22082102   Brand: Kenmore   Age: 1 - 5 years
Please help! I have a Kenmore Calypso washer (about 5 years old) 110.22082102. It recently began having problems when it reached the rinse/spin cycle. It would start to spin but then stop with a jolt, starts making a sucking sound like it is trying to drain more water, then begin to agitate for a 3-5 seconds, then stops and tries to start the spin cycle again. It continues indefinitely in this pattern and the timer has stopped counting down. The previous cycles all work well and it agitates and spins when it has to and the water filled and drained normally.
We had a serviceman come out and he ran it through a short cycle but it did not do it. He thought it was the water pump but was not sure and would then have to change the main motor. I decided to change the pump myself with a new one and there was no change! I then decided to change the main motor myself and I tested it by starting an extended spin cycle. It worked well (very quite now). However, when we did a full run, it started doing the same thing. The next morning my wife did a load and it worked well. The second load started with the same problem. Starting and stopping it did not make a difference. We have to let it sit for 1-2 hours to before doing just an extended spin to finish.
I found the Service Manual taped to the inside panel and ran the AUTOMATIC SERVICE DIAGNOSTICS and all ran well including the spin cycle. I then cleaned the back of the electrical panel with compressed air. I ran a full cycle and SAME PROBLEM! There is no smell of anything overheating as I am doing all with the front panel off. I am about $250 in the hole with this “fix” already.
HGonz
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-10-2008, 06:18 PM
okbobcats okbobcats is offline
Senior Expert
APP Volunteer
okbobcats is on a distinguished road
Default Basket
Check for something in between the basket and tub. also check to see if their is anything stuck under the wash plate.
  #3 (permalink)
Old 02-11-2008, 01:19 PM
Junior Member
Default No obstructions
Thanks. I did not see anything between basket and tub. I was reluctant to take the wash plate apart, but as best I can tell, there is nothing obstructing the plate as it turns freely by hand. I am beginning to think that it may be the MACHINE CONTROLLER or the MOTOR CONTROLER board. When we use it first thing in the morning or after it has been sitting for 1-2 hours, it will go through a full cycle fine. It is any load started after that when it gets stuck in the rinse/spin cycle. Lifting the lid or setting it to another setting makes no difference. It took both controllers apart and could not find any bad connections or rust on them. Does this make any sense? Thanks again.
HGonz
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch dishwasher stuck on rinse cycle JDDrake Dishwasher Repair 2 04-05-2008 11:10 AM
Whirlpool stuck in rinse cycle vegemom Dishwasher Repair 5 01-30-2008 11:09 AM
Washer won't spin in rinse cycle PIETOWN Washer Repair 1 01-28-2008 02:13 PM
Runs rinse cycle all the way through the spin cycle hebirdseye Washer Repair 1 01-20-2008 06:10 PM
GE Washer will not spin on rinse cycle mguy77 Washer Repair 1 01-15-2008 07:37 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
