Washer seems to miss final spin cycle and also leaving a 4"-6" pool of water behind! Please help:confused:
This is actually a Frigidaire front loader built by Electrolux and sold under the GE label.
Your symptoms are indicative of a failure of the speed control board or the door lock assembly. But it may also be the result of blockage in the pump or drain hoses. Clean them out and see if that doesn't fix your problem.
