The machine is about 13 months old. When set to wash the water flows and then stop. it does not spin. Went in diagnostic mode and went through each cycle and they work individually. There are no obstructions with the hoses and there is sufficient power to the machine and the lid switch engages and the lid is locked. Any suggestions?
Thanks a lot, Danila
Groups: Expert
Did you physically remove the pump and check inside it for obstruction? If so, try doing the calibration function in service mode.
Eric
Originally Posted by: fairbank56 Did you physically remove the pump and check inside it for obstruction? If so, try doing the calibration function in service mode.
Eric I did not remove the pump or check for obstructions. I was able to go into diag mode, fill it and then pump it out. The odd thing is I also have the Kenmore version of this machine doing pretty much the same thing. Do you have any info on doing the calibration function? Is it just for the pump or are there other calibrations? Is there a way of disabling all the silly "sensing" that it does?
Groups: Expert
There have been issues with pump obstructions causing the machine to not function properly. It may still pump out fine in service mode but pump motor current is monitored by the control board and something in there can cause problems. Sorry to say, but these machines are junk. Many many problems with them. Calibration is required if certain parts are replaced but I would try it anyway. It's in your manual. There is only one calibration function which takes 2-4 minutes to complete. So, your machine locks the lid, fills and then just stops? No error codes? No flashing indicators? Check for error codes in service mode.
Eric
Groups: Expert
I would check the water level pressure switch behind the control panel. I see that your model uses one of these vs a control board pressure sensor as is used on most of these machines. I do not have the tech sheet for your model so you will need to check the diagram for testing it.
Forget that, if it stops filling, the pressure switch is working.
Eric
