Discuss
Maytag Centennial will drain but won't spin
 in
Washer Repair
Hi, My maytag washer is having some problems. First, it won't spin in a cycle or on the drain and
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Centennial will drain but won't spin
  #1 (permalink)
Old 08-09-2013, 04:41 PM
Junior Member
Lost1echo is on a distinguished road
Default Maytag Centennial will drain but won't spin
Model Number: MVWC400XW2   Brand: Maytag   Age: 1 - 5 years
My maytag washer is having some problems. First, it won't spin in a cycle or on the drain and spin cycle. It will drain but the clothes are still soaked. It tries to spin (i hear and feel the motor start) but when I come back to check it the lid locked light is flashing. Also, when I run a cycle it stops in between each part of the cycle. I have to press the start button to pause and resume between each part of the cycle. Example:
Sensing...pause/start...wash...pause/start...rinse...pause/start...spin
Thank you for your time!
Related Models
Maytag MVWC450WW0 AUTOMATIC WASHER
Maytag MVWC500VW0 AUTOMATIC WASHER
Maytag MVWC500VW1 AUTOMATIC WASHER
Maytag MVWC5ESXW0 AUTOMATIC WASHER
Maytag MVWC6ESWW0 AUTOMATIC WASHER
Maytag MVWC6ESWW1 AUTOMATIC WASHER
Maytag MVWC700VJ0 AUTOMATIC WASHER
Maytag MVWC700VJ1 AUTOMATIC WASHER
Maytag MVWC700VW0 AUTOMATIC WASHER
Maytag MVWC700VW1 AUTOMATIC WASHER
Maytag MVWC7ESWW0 AUTOMATIC WASHER
Maytag MVWX500XL0 AUTOMATIC WASHER
Maytag MVWX500XW0 AUTOMATIC WASHER
Maytag MVWX550XW0 AUTOMATIC WASHER
Maytag MVWX600XW0 AUTOMATIC WASHER
Maytag MVWX700XL0 AUTOMATIC WASHER
Maytag MVWX700XW0 AUTOMATIC WASHER
Whirlpool MW1000XP0 Microwaves*
Whirlpool MW1000XP1 Microwaves*
Whirlpool MW1000XS0 MICROWAVE
Whirlpool MW1000XS1 Microwaves*
Whirlpool MW1000XW0 Microwaves*
 MW1030BA MWAVE- CNTRTP / STAND ALONE
 MW1030SB MWAVE- CNTRTP / STAND ALONE
 MW1030SB/XAA MWAVE- CNTRTP / STAND ALONE
 MW1030WA MWAVE- CNTRTP / STAND ALONE
 MW1040BC MWAVE- CNTRTP / STAND ALONE
 MW1040BC/XAA MWAVE- CNTRTP / STAND ALONE
 MW1040WC MWAVE- CNTRTP / STAND ALONE
 MW1040WC/XAA MWAVE- CNTRTP / STAND ALONE
 MW1080STA MWAVE- CNTRTP / STAND ALONE
 MW1135WB MWAVE- CNTRTP / STAND ALONE
 MW1135WB/XAA MWAVE- CNTRTP / STAND ALONE
 MW1150WA MWAVE- CNTRTP / STAND ALONE
Whirlpool MW1200XP0 Microwaves*
Whirlpool MW1200XP1 Microwaves*
Whirlpool MW1200XS0 Microwaves*
Whirlpool MW1200XS1 MICROWAVE
Whirlpool MW1200XW0 Microwaves*
Whirlpool MW120EXP0 Microwaves*
 MW1245BB MWAVE- CNTRTP / STAND ALONE
Whirlpool MW1500XP0 Microwaves*
Whirlpool MW1500XP1 Microwaves*
Whirlpool MW1500XS0 Microwaves*
Whirlpool MW1500XS1 Microwaves*
Whirlpool MW1500XW0 Microwaves*
Whirlpool MW1501XS1 Microwaves*
Whirlpool MW1501XW0 Microwaves*
Roper MW157 Microwave
Maytag MW29000TB0 LAUNDRY WORKSURFACE
Maytag MW29000TU0 LAUNDRY WORKSURFACE
Maytag MW29000TW0 LAUNDRY WORKSURFACE
Whirlpool MW3000XM0 Microwaves*
Whirlpool MW3000XM1 Microwaves*
Whirlpool MW3000XP0 Microwaves*
Whirlpool MW3000XP1 Microwaves*
Whirlpool MW3000XP2 Microwaves*
Whirlpool MW3200XM0 Microwave
Whirlpool MW3200XM1 Microwave
Whirlpool MW3200XP0 Microwave
Whirlpool MW3200XP1 Microwave
Whirlpool MW3200XP2 Microwave
Whirlpool MW3200XS0 Microwave
Whirlpool MW3200XW0 Microwave
Whirlpool MW3500XM0 Microwaves*
Whirlpool MW3500XM1 Microwaves*
Whirlpool MW3500XP1 Microwaves*
Whirlpool MW3500XP2 Microwaves*
Whirlpool MW3500XP3 Microwaves*
Whirlpool MW3500XS0 Microwaves*
Whirlpool MW3500XW0 Microwaves*
Whirlpool MW3520XP1 Microwaves*
Whirlpool MW3520XP2 Microwaves*
Whirlpool MW3520XP3 Microwaves*
Whirlpool MW352EXP1 Microwaves*
Whirlpool MW3600XS0 Microwaves*
Whirlpool MW3600XW0 Microwaves*
Whirlpool MW3600XW1 Microwaves*
Whirlpool MW3601XS0 Microwaves*
Whirlpool MW3601XW0 Microwaves*
Whirlpool MW3601XW1 Microwaves*
Amana MW41 MWAVE- CNTRTP / STAND ALONE
Amana MW42 MWAVE- CNTRTP / STAND ALONE
Amana MW43 MWAVE- CNTRTP / STAND ALONE
Amana MW500.000 COMMERCIAL MICROWAVES
 MW5380W MWAVE- CNTRTP / STAND ALONE
Roper MW557 Microwave
Roper MW5571 Microwaves
 MW5592W MWAVE- CNTRTP / STAND ALONE
 MW5592W/XAA MWAVE- CNTRTP / STAND ALONE
Amana MW56 MWAVE- CNTRTP / STAND ALONE
Amana MW57 MWAVE- CNTRTP / STAND ALONE
Amana MW58 MWAVE- CNTRTP / STAND ALONE
Amana MW600.000 COMMERCIAL MICROWAVES
 MW640BA MWAVE- CNTRTP / STAND ALONE
 MW640WA MWAVE- CNTRTP / STAND ALONE
Amana MW700.000 COMMERCIAL MICROWAVES
Amana MW72 MWAVE- CNTRTP / STAND ALONE
 MW730BB MWAVE- CNTRTP / STAND ALONE
 MW735WB MWAVE- CNTRTP / STAND ALONE
 MW735WB/XAA MWAVE- CNTRTP / STAND ALONE
Whirlpool MW7400XW0 Microwaves*
Whirlpool MW7500XW0 Microwaves*
 MW7695GS MWAVE- CNTRTP / STAND ALONE
Whirlpool MW8100XL0 MICROWAVE
Whirlpool MW8100XL1 MICROWAVE
Whirlpool MW8100XL2 MICROWAVE
Whirlpool MW8100XP0 MICROWAVE
Whirlpool MW8100XR0 MICROWAVE
Whirlpool MW8200XL0 Microwaves*
Whirlpool MW8200XL1 Microwaves*
Whirlpool MW8200XL2 Microwaves*
Whirlpool MW8200XP0 Microwaves*
Whirlpool MW8200XR0 Microwaves*
  #2 (permalink)
Old 08-10-2013, 05:19 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Your timer may be the problem, this part here
Part number: AP4369560
If you buy from this site and it is not the problem you can return it.
__________________
  #3 (permalink)
Old 08-10-2013, 06:56 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
This washer does not have a mechanical timer. It is a Whirlpool belt drive VMW design with electronic control board.
Suggest you tilt the washer back and retrieve the tech manual from inside the cabinet and place it in service mode to check for error codes and run the troubleshooting tests. These washers are very problematic with various failures.
Eric
  #4 (permalink)
Old 08-27-2013, 12:20 AM
Junior Member
Default Did all the troubleshooting
Ok, so I retrieved the tech manual and went through the various tests.
The one and only fault code was F7E1 Basket Speed Sensor Fault which suggested going through test 3a.
I also did the manual test mode and checked all functions. The only problems I had were the Low Spin and High Spin. Both of which suggest running test 3a and 3b Drive System Shifter and Motor.
The first part of 3a is to remove The J16 connector and check resistance in pins 1 & 2. Now I wasn't sure if i was checking the plug on the harness or the blade pins on the control board so i checked both. The blade pins read 006 ohms and the plug on the harnes would momentarily read anywhere from 800 - 1957 and then read 1. The requirement was to read between 2k and 3.5k.
So I followed both paths ( correct values and out of range). The out of range path stated to check the connections to the shifter. They were good. Next step was to check for continuity of all pins in the plug at the shifter assembly. All checked good. Finally, if there was continuity in all pins then the shifter assembly needed to be replaced.
Incase I messed up the resistance readings I followed the correct values path as well. Next step was to check for 120VAC from pins 1&2 at the control board for the J16 connector. Voltage was good. Following along, the next step was to check the shifter switch DC voltage at pins 1&3 on the control board for the J2 plug. It is supposed to read +5 VDC when in SPIN and 0 VDC when in AGITATE. My reading never changed from +5 VDC. No voltage switch leads back to checking the lower harness connections and continuity, which was good. This then recommends replacing the shifter assembly.
Just incase, I also checked the Optical Sensor. I checked pins 3 and 4 on the control board for the J2 plug for +13 VDC. Reading was good so the next step was to activate the Tachometer Verification Mode. There was no reading in the mode which once again leads to the lower harness/ check continuity/ replace shifter assembly sequence.
So I guess I need to replace the Shifter Assembly. Can one of the experts please direct me to the correct part to buy? I can't seem to find it when I look up my model number. Also I know a couple other people are having the same issues, hopefully my explanation helps them (if an expert wants to double check what I've done if they can that would be awesome).
Thanks for the help and your time.
  #5 (permalink)
Old 08-27-2013, 02:27 AM
Junior Member
katrinajohnson is on a distinguished road
Default
Able to book online at little notice (same day or next day), with a 2 hr time window that was rewarded. Got the reception electronically through out email. The only ground I 'm not throwing 5 stars is that I have not been able to informant a repair yet : the diagnosing was that my washer was totaled.
  #6 (permalink)
Old 08-27-2013, 07:10 AM
Expert
APP Volunteer
Default
This is a very high failure item in these washers.
Whirlpool W10006355 Actuator - AppliancePartsPros.com
Eric
  #7 (permalink)
Old 08-27-2013, 08:59 AM
Junior Member
Default
Thank you very much Eric!
  #8 (permalink)
Old 05-27-2014, 05:24 PM
Junior Member
xskier is on a distinguished road
Default
My maytag centennial mvwc400xv0 is about 37 months old and stopped spinning during a wash cycle. It did work on drain and spin for a few times, but quit spinning all together. On the advice of this forum I troubleshoot with the shift actuator in mind. In the manual test mode it wouldn't spin, so I checked the resistance at the 1 and 2 pins on the actuator. It was nearly a closed circuit instead of the 2k-3.5k ohms specified. I bought w10006355 from the local appliance shop for $62, installed it, and just completed a full wash rinse and spin cycle. NICE!
Thanks for the great forum.
  #9 (permalink)
Old 05-27-2014, 05:41 PM
Senior Expert
APP Volunteer
Default
Appreciate it, glad you got it fixed and thanks for the info
__________________
  #10 (permalink)
Old 01-11-2015, 10:08 AM
Junior Member
natehoel is on a distinguished road
Default maytag centennial may not be spinning.
hi I have a Maytag centennial commercial series washer that when you wash it will wash everything down to the ending spin cycle I went down to check on it and the spin light was just flashing check the Towels inside because the lid lock was unlocked and the Towels were soaked at this time I switched the washer to drain and spin and the washer finished the job I had towels in the load so I am unsure if the towels made the washer unbalanced that this proceeded down, of not spending.
My model number is : MVWC200XW1C11822156
I'm trying a small clothes wash to see if that it finishes the job with things that will make the washer unbalanced.
I also had the washer on large setting in heavy duty mode don't know if that is the issue so now I'm trying regular wash medium cycle to see if anything changes
any insight would be greatly appreciated
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Centennial Washer Will Not Spin mrpour Washer Repair 28 08-09-2016 07:07 PM
Maytag Centennial drains but no spin rtagz Washer Repair 1 05-31-2013 03:45 PM
Maytag Centennial Washer screeches on spin cycle Greg355 Washer Repair 0 04-28-2013 10:05 AM
Maytag Centennial (Top Load) Spin Noise headusher Washer Repair 1 06-01-2012 01:14 PM
Maytag Centennial refills after spin AnnaD Washer Repair 0 10-12-2011 04:13 PM
