Discuss
Frigidaire FWS845GCS0 leaks
 in
Washer Repair
I have a Frigidaire FWS845GCS0 Gallery Washing machine. It was in storage for three years and recently we moved back
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Frigidaire FWS845GCS0 leaks
  #1 (permalink)
Old 08-07-2013, 07:31 PM
Junior Member
rgjoslin is on a distinguished road
Default Frigidaire FWS845GCS0 leaks
Model Number: FWS845GCS0   Brand: Frigidaire   Age: 5 - 10 years
I have a Frigidaire FWS845GCS0 Gallery Washing machine. It was in storage for three years and recently we moved back into our house and have begun using the machine again. There is a small slow water leak coming from the bottom of the machine.
To characterize the amount of leakage: For three loads of laundry, I sponge up about one pint of water. When the machine is done with a wash cycle, it drips steadily for a couple of hours and then stops. It will stay dry until the next use the machine.
I took the front panel off of the machine and can observe, while the machine runs, that the leak is coming from a while plastic “trough” designed to channel water. The “trough”, as I call it, molded into a white plastic assembly that sits on top of the motor between the pump and the motor. The pump motor assembly on this model Frigidaire is located in the lower right front of the machine. The pump is a direct drive style pump.
The leak stops at various times during a wash cycle. For troubleshooting purposes, this can be characterized as follows:
Fill – about ˝ way through the initial fill cycle the leak begins and is a slow drip about once per second
1st Wash cycle. As the machine transitions to the first wash cycle, (agitators cycles back and forth) there is initially a fast drip (almost like a burst)and then the leak stops and there is no dripping during the remainder of the 1st wash cycle.
1st Rinse/Spin. Again as the machine transitions there is a momentary fast drip and then it stops
2nd fill cycle – about ˝ way through the fill the leak starts and is steady maybe two drops per second.
2nd Wash cycle – Again as the machine transitions there is a brief fast leak and then it stops during the remainder of the wash (agitation).
2nd Rinse/spin. Brief leak during transition and then it stops.
At the conclusion of the entire wash cycle, the machine continues to leak. In fact the bulk of the leakage occurs over the next 2-3 hours. It presents a regular and steady drip – once per second-that ultimately tapers off and stops.
I suspect the pump itself or the pump “slinger” (black rubber gasket like part) or both.
Welcome the advice from the experts in troubleshooting this.
Thanks in Advance
R Joslin
Related Models
Frigidaire FWS845GCS0 Frg(v1) / 27 " Washer
Frigidaire FWS845GCS1 Frg(v0) / Washer
Frigidaire FWS845GCS2 Frg(v1) / Washer
Frigidaire FWS845GCS3 Frg(v1) / Washer
Frigidaire FWS845GCS4 Frg(v0) / Washer
Frigidaire FWS845GCT0 Frg(v2) / 27 " Washer
Frigidaire FWS845GCT2 Frg(v2) / Washer
Frigidaire FWS845GCT3 Frg(v2) / Washer
Frigidaire FWS845GFS0 Frg(v1) / Washer
Frigidaire FWS845GFS1 Frg(v1) / Washer
Frigidaire FWS845GFS2 Frg(v0) / Free Standing Washer
Frigidaire FWS845GFT0 Frg(v2) / Washer
Frigidaire FWS845GFT1 Frg(v2) / Washer
Frigidaire FWS850RHS0 Frg/washer
Frigidaire FWS875GHS0 Frg(v0) / Washer
Frigidaire FWS900FHS0 Frg(v0) / Washer
Frigidaire FWS933FS0 Frigidaire/washer
Frigidaire FWS933FS1 WASHER
Frigidaire FWS933FS2 WASHER
Frigidaire FWS933FS3 WASHER
Frigidaire FWS950RHS0 Frg(v0) / Washer
Frigidaire FWS975GHS0 Frg(v1) / Washer
Frigidaire FWS975GHT0 Frg(v2) / Washer
Frigidaire FWSB34RGS0 Frg(v0) / Washer
Frigidaire FWSB34RGS1 Washer - Fwsb34rgs1 - Frigidaire
Frigidaire FWSB55RGS0 Frg(v0) / Free Standing Washer
Frigidaire FWSB55RGS1 Washer - Frigidaire
Frigidaire FWSB5700DS0 Frigidaire/washer
Frigidaire FWSB6600ES0 Frigidaire/washer
Frigidaire FWSB6600ES1 Frigidaire/washer
Frigidaire FWSB6600FS0 Frigidaire/washer
Frigidaire FWSB6600FS1 WASHER
Frigidaire FWSB67RGS0 Washer - Frigidaire - Best Buy
Frigidaire FWSB67RGS2 Washer - Frig/best Buy
Frigidaire FWSB7800DS0 Frigidaire/washer
Frigidaire FWSC235RFS3 Washer - Fwsc235rfs3
Frigidaire FWSC34RGS1 Washer - Fwsc34rgs1
Frigidaire FWT425RHS0 Frg(v0) / Front Load Washer
Frigidaire FWT445GC WASHER
Frigidaire FWT445GCS0 Frg(v0) / Washer
Frigidaire FWT445GE WASHER
Frigidaire FWT445GES0 Frg(v0) / Washer
Frigidaire FWT445GES1 Frg(v0) / Washer
Frigidaire FWT445GES2 Frg(v0) / Washer
Frigidaire FWT449GFS0 Frg(v0) / Washer
Frigidaire FWT449GFS1 Frg(v0) / Front Load Washer
Frigidaire FWT449GFS2 Frg(v0) / Free Standing Washer
Frigidaire FWT645RHS0 Frtld Wshr - Frigidaire
Frigidaire FWT645RHS1 Frg(v0) / Front Load Washer
Frigidaire FWT647GHS0 Frg(v0) / Front Load Washer
Frigidaire FWT647GHS1 Frtld Wshr - Frigidaire
Frigidaire FWT648GHS0 Frg/washer
Frigidaire FWT867GHQ0 Frg/washer
Frigidaire FWT867GHS0 Frg/washer
Frigidaire FWTB59RGS0 Frg(v0) / Front Load Washer
Frigidaire FWTB69RGS0 Frg(v0) / Front Load Washer
Frigidaire FWTB8200DS0 Frigidaire/washer
Frigidaire FWTBB30DS0 Frigidaire/washer
Frigidaire FWTR425RHS0 Frg(v0) / Front Load Washer
Frigidaire FWTR445RFS0 Frg(v0) / Washer
Frigidaire FWTR445RFS1 Frg/washer
Frigidaire FWTR445RFS2 Frg(v0) / Front Load Washer
Frigidaire FWTR549GG Frg(v0) / Free Standing Washer
Frigidaire FWTR549GGS0 Frg/washer
Frigidaire FWTR549GS0
Frigidaire FWTR645RHS0 Frtld Wshr - Frigidaire
Frigidaire FWTR645RHS1 Frg(v0) / Front Load Washer
Frigidaire FWTR647GHS0 Frg(v0) / Washer
Frigidaire FWTR647GHS1 Frtld Wshr - Frigidaire
Frigidaire FWTR865RHQ0 Frg(v1) / Front Load Washer
Frigidaire FWTR865RHS0 Frg(v2) / Front Load Washer
Frigidaire FWTR867GHQ0 Frg(v1) / Front Load Washer
Frigidaire FWTR867GHS0 Frg(v2) / Front Load Washer
Frigidaire FWX133RBS0 Frg(v2) / 27 " Washer
Frigidaire FWX133RBS1 Frg(v1) / 27 " Washer
Frigidaire FWX133RBS2 Frg(v1) / Washer
Frigidaire FWX133RBS3 Frg(v1) / Washer
Frigidaire FWX221AS0 Washer - Frigidaire
Frigidaire FWX221AS1 Washer - Frigidaire
Frigidaire FWX221AS2 Frigidaire/washer
Frigidaire FWX223LBS0 Frg(v1) / 27 " Washer
Frigidaire FWX223LBS1 Frg(v0) / 27 " Washer
Frigidaire FWX223LBS2 Frg(v2) / Washer
Frigidaire FWX223LBS3 Frg(v2) / Washer
Frigidaire FWX223LBS4 Frg(v0) / Washer
Frigidaire FWX223LBS5 Frg(v0) / Washer
Frigidaire FWX223LBS6 Frg/washer
Frigidaire FWX223LBS7 Frg(v0) / Free Standing Washer
Frigidaire FWX223LBS8 Frg/washer
Frigidaire FWX225RHS0 Frg(v0) / Washer
Frigidaire FWX225RHS1 Frg/washer
Frigidaire FWX233MRES0 Frg(v0) / Refrigerator
Frigidaire FWX233NBS0 Frg(v1) / 27 " Washer
Frigidaire FWX233NBS1 Frg(v2) / 27 " Washer
Frigidaire FWX233NBS2 Frg(v1) / Washer
Frigidaire FWX233NBS3 Frg(v0) / Washer
Frigidaire FWX233RES0 Frg(v0) / Washer
Frigidaire FWX233RES1 Frg(v0) / Washer
Frigidaire FWX233RES2 Frg(v0) / Washer
Frigidaire FWX233RES3 Frg(v0) / Washer
Frigidaire FWX233RES4 Frg(v0) / Washer
Frigidaire FWX233RES5 Frg(v0) / Washer
Frigidaire FWX233RES6 Frg/washer
Frigidaire FWX233RES7 Washer - Frigidaire
Frigidaire FWX233RET0 Frg(v0) / Free Standing Washer
Frigidaire FWX233RET1 Frg/washer
Frigidaire FWX414RGS0 Frg(v0) / Free Standing Washer
Frigidaire FWX414RGS1 Washer - Frigidaire
Frigidaire FWX433RBS0 Frg(v1) / 27 " Washer
Frigidaire FWX433RBS1 Frg(v1) / 27 " Washer
Frigidaire FWX433RBS2 Frg(v3) / Washer
Frigidaire FWX433RBS3 Frg(v1) / Washer
Frigidaire FWX433RBS4 Frg(v1) / Washer
Frigidaire FWX433RBS5 Frg(v1) / Washer
Frigidaire FWX433RBT0 Frg(v2) / 27 " Washer
Frigidaire FWX433RBT1 Frg(v2) / 27 " Washer
Frigidaire FWX433RBT2 Frg(v4) / Washer
Frigidaire FWX433RBT4 Frg(v2) / Washer
Frigidaire FWX433RBT5 Frg(v2) / Washer
Frigidaire FWX435RHS0 Frg(v0) / Washer
  #2 (permalink)
Old 12-24-2016, 06:30 AM
Junior Member
Trojan82 is on a distinguished road
Default
Hey, it seems like since the washer set up for such a period of time, the water hoses attached to the water pump may have cracked (due to dry rotting). It may be something that you need to look into. It would be very cost effective and probably easy to fix.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire freezer leaks water mwross Refrigerator & Freezer Repair 1 02-25-2013 04:03 PM
Frigidaire Leaks From Top of Splash Tub JohnnyRock Washer Repair 3 11-27-2012 02:46 PM
Frigidaire 700 Series Leaks Underneath?? anthony303 Dishwasher Repair 0 12-25-2010 03:52 PM
Frigidaire leaks at water valve Swordfish5150 Refrigerator & Freezer Repair 0 08-02-2010 10:15 PM
Frigidaire still leaks txaggie075 Washer Repair 9 06-28-2009 06:41 AM
