Discuss
End of cylce signal not working
 in
Washer Repair
The end of cycle signal does not work on my Roper washing machine. Does anyone have any ideas to fix
Appliance Repair Forum > Appliance Repair Help > Washer Repair » End of cylce signal not working
  #1 (permalink)
Old 08-07-2013, 06:37 AM
Junior Member
DFinagin is on a distinguished road
Default End of cylce signal not working
Model Number: 4640YQ1   Brand: Roper   Age: Less than 1 year
The end of cycle signal does not work on my Roper washing machine. Does anyone have any ideas to fix the problem?
Related Models
Frigidaire 46458-OA FREEZER
Frigidaire 46467A FREEZER
Frigidaire 46467A-7 FREEZER
Amana 465.000 MWAVE - FAMILY SIZE (60 HZ)
Frigidaire 46567A FREEZER
Frigidaire 46567A-7 FREEZER
Frigidaire 46656B UPRIGHT FREEZER
Frigidaire 46656B-7 FREEZER
Frigidaire 46657-7A FREEZER
Frigidaire 46657A-7 FREEZER
Frigidaire 46658A FREEZER
Frigidaire 46658B FREEZER
Frigidaire 46658C UPRIGHT FREEZER
Frigidaire 46659-0C UPRIGHT FREEZER
Frigidaire 46659A UPRIGHT FREEZER
Frigidaire 46659B UPRIGHT FREEZER
Frigidaire 46851-0A FREEZER
Frigidaire 46851-0B FREEZER
Frigidaire 46856B FREEZER
Frigidaire 46856B-7 FREEZER
Frigidaire 46857-7A FREEZER
Frigidaire 46857A FREEZER
Frigidaire 46858-A FREEZER
Frigidaire 47-2151-00-01 Tap(v1) / 27 " Electric Dryer
Frigidaire 47-2151-00-02 Tap(v1) / 27 " Electric Dryer
Frigidaire 47-2151-23-01 Tap(v2) / 27 " Electric Dryer
Frigidaire 47-2151-23-02 Tap(v2) / 27 " Electric Dryer
Frigidaire 47-2251-00-01 Tap(v3) / 27 " Electric Dryer
Frigidaire 47-2251-00-02 Tap(v3) / 27 " Electric Dryer
Frigidaire 47-2251-00-04 Tap(v1) / 27 " Electric Dryer
Frigidaire 47-2251-00-05 Tap(v1) / 27 " Electric Dryer
Frigidaire 47-2251-23-01 Tap(v4) / 27 " Electric Dryer
Frigidaire 47-2251-23-02 Tap(v4) / 27 " Electric Dryer
Frigidaire 47-2251-23-04 Tap(v2) / 27 " Electric Dryer
Frigidaire 47-2251-23-05 Tap(v2) / 27 " Electric Dryer
Frigidaire 47-2351-00-01 Tap(v1) / 27 " Electric Dryer
Frigidaire 47-2351-23-01 Tap(v2) / 27 " Electric Dryer
Frigidaire 47-2451-00-01 Tap(v5) / 27 " Electric Dryer
Frigidaire 47-2451-00-03 Tap(v3) / 27 " Electric Dryer
Frigidaire 47-2451-00-04 Tap(v3) / 27 " Electric Dryer
Frigidaire 47-2451-23-01 Tap(v6) / 27 " Electric Dryer
Frigidaire 47-2451-23-03 Tap(v4) / 27 " Electric Dryer
Frigidaire 47-2451-23-04 Tap(v4) / 27 " Electric Dryer
Frigidaire 47-2551-00-01 Tap(v3) / 27 " Electric Dryer
Frigidaire 47-2551-00-03 Tap(v1) / 27 " Electric Dryer
Frigidaire 47-2551-00-04 Tap(v1) / 27 " Electric Dryer
Frigidaire 47-2551-23-01 Tap(v4) / 27 " Electric Dryer
Frigidaire 47-2551-23-03 Tap(v2) / 27 " Electric Dryer
Frigidaire 47-2551-23-04 Tap(v2) / 27 " Electric Dryer
Frigidaire 47-2707-00-01 Tap(v2)
Frigidaire 47-2707-23-01 Tap(v1)
Frigidaire 47-2751-00-01 Tap(v1) / 27 " Electric Dryer
Frigidaire 47-2751-23-01 Tap(v2) / 27 " Electric Dryer
Frigidaire 47-2828-00-01 Tap(v1) / Electric Dryer
Frigidaire 47-2828-00-03 Tap(v3) / Electric Dryer
Frigidaire 47-2828-00-04 Tap(v3) / 27 " Electric Dryer
Frigidaire 47-2828-23-01 Tap(v2) / Electric Dryer
Frigidaire 47-2828-23-02 Tap(v2) / Electric Dryer
Frigidaire 47-2828-23-03 Tap(v4) / Electric Dryer
Frigidaire 47-2828-23-04 Tap(v4) / 27 " Electric Dryer
Frigidaire 47-2848-00-01 Tap(v3) / Electric Dryer
Frigidaire 47-2848-00-02 Tap(v1) / Electric Dryer
Frigidaire 47-2848-00-03 Tap(v1) / Electric Dryer
Frigidaire 47-2848-00-04 Tap(v1) / 27 " Electric Dryer
Frigidaire 47-2848-23-01 Tap(v4) / Electric Dryer
Frigidaire 47-2848-23-03 Tap(v2) / Electric Dryer
Frigidaire 47-2848-23-04 Tap(v2) / 27 " Electric Dryer
Hoover 473.85920400 EXTR-W/FIX & ROT BRUSH,TEMPEST
Hoover 473.85930400 EXTR-W/FIX & ROT BRUSH,TEMPEST
General Electric 4742990 RADIANT MODULE
Jenn-Air 4755 RANGE- F/S STD DDRAFT ELE
Jenn-Air 4760 RANGE- F/S STD DDRAFT ELE
Jenn-Air 4770 RANGE- F/S STD DDRAFT ELE
Jenn-Air 4775 RANGE- F/S STD DDRAFT ELE
Jenn-Air 4790 RANGE- F/S STD DDRAFT ELE
Jenn-Air 4800 RANGE- F/S STD DDRAFT ELE
Jenn-Air 4800N RANGE- F/S STD DDRAFT ELE
Jenn-Air 4800S RANGE- F/S STD DDRAFT ELE
Frigidaire 4803A ELECTRIC RANGE
Frigidaire 48044 ELECTRIC RANGE
Frigidaire 480440A ELECTRIC RANGE
Frigidaire 480440D ELECTRIC RANGE
Frigidaire 480440E ELECTRIC RANGE
Frigidaire 480440F ELECTRIC RANGE
Frigidaire 480447A ELECTRIC RANGE
Frigidaire 480447D ELECTRIC RANGE
Frigidaire 480447E ELECTRIC RANGE
Frigidaire 480447F ELECTRIC RANGE
Frigidaire 4809A ELECTRIC RANGE
Frigidaire 4809B ELECTRIC RANGE
Frigidaire 4811 ELECTRIC RANGE
Frigidaire 4813-80B ELECTRIC RANGE
Frigidaire 4813A ELECTRIC RANGE
Frigidaire 4819A ELECTRIC RANGE
Frigidaire 4820A ELECTRIC RANGE
Frigidaire 4821-80A ELECTRIC RANGE
Frigidaire 4821A ELECTRIC RANGE
Frigidaire 4822A ELECTRIC RANGE
Frigidaire 4823A ELECTRIC RANGE
Frigidaire 4829A ELECTRIC RANGE
General Electric 4832990 RADIANT MODULE
Frigidaire 4833A ELECTRIC RANGE
Frigidaire 4839A ELECTRIC RANGE
Frigidaire 484240A ELECTRIC RANGE
General Electric 4842990 RADIANT MODULE
Frigidaire 48436 ELECTRIC RANGE
Frigidaire 484360A ELECTRIC RANGE
Frigidaire 484360B ELECTRIC RANGE
Frigidaire 484360D ELECTRIC RANGE
Frigidaire 484367A ELECTRIC RANGE
Frigidaire 484367B ELECTRIC RANGE
Frigidaire 484367D ELECTRIC RANGE
Frigidaire 4843A ELECTRIC RANGE
Frigidaire 484440A ELECTRIC RANGE
Frigidaire 484440C ELECTRIC RANGE
Frigidaire 484440D ELECTRIC RANGE
Frigidaire 484447C ELECTRIC RANGE
Frigidaire 484447D ELECTRIC RANGE
Frigidaire 484560A ELECTRIC RANGE
Frigidaire 484560B ELECTRIC RANGE
  #2 (permalink)
Old 08-07-2013, 07:36 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Did it ever work? I see that this washer has a cycle complete indicator and the specifications say that it does have an end of cycle signal. If it used to work but doesn't now, I would unplug the machine for a couple minutes and plug back in. If that doesn't fix it, tilt the machine back and look for the tech sheet inside the cabinet. Go into service mode and do the calibration function. If that doesn't fix it, you may have a faulty control board. Is it still under warranty?
Eric
  #3 (permalink)
Old 08-07-2013, 08:17 AM
Junior Member
Default
No it never has worked. All other parts/features work great. I will try the calibration function - thanks.
  #4 (permalink)
Old 08-07-2013, 09:18 AM
Expert
APP Volunteer
Default
Are you talking about the visual indicator lamp or an audible alarm? Maybe it just doesn't have the audible feature if that's what you mean.
Eric
  #5 (permalink)
Old 08-07-2013, 10:34 AM
Junior Member
Default
I think you are right - only a visual indicator nothing audible.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Won't cylce when turning temp control bnentrup Refrigerator & Freezer Repair 3 11-20-2012 09:30 AM
Humming during drain cylce kurtms60 Washer Repair 1 07-12-2011 06:41 PM
Washer isn't draining during spin cylce rvso Washer Repair 1 02-19-2010 07:50 AM
Maytag washer stopped at rinse cylce landrew Washer Repair 0 09-07-2009 12:45 PM
Wahser Overfills on Rinse Cylce ThomasR Washer Repair 0 06-23-2008 09:31 AM
