Sixb412
#1 Posted : Sunday, August 4, 2013 3:02:59 PM(UTC)
Sixb412
This will be the 4th time I will be replacing the actuator in this washer! I have no idea why this part keeps breaking down. It works good for a few months then it conks out again. Same freaking error code every time! I was told these parts are sensitive and that the slightest hint of water or moisture can cause this part to go bad. Has anyone had to replace this part more than once for this brand and model of washer? I'm very annoyed by this and do not want to have to replace it again. Whirlpool did nothing except state I should purchase a warranty and that there machine is not defective. I am planning to raise the washer this time around to try and avoid any future issues, with a pallet from home depot that I will cover with a plastic tarp like sheet. Any thoughts would be appreciated.
fairbank56
#2 Posted : Sunday, August 4, 2013 4:29:39 PM(UTC)
fairbank56
Groups: Expert
I can tell you that the shift actuator is a very high failure item on these washers. Many tech's carry spares all the time and don't even bother with doing diagnostic's tests. It's easy to replace so they just swap them out and most times the problem is fixed. These machines are junk. There are many failures including shifters, lid locks, broken wires, loose connections, bad capacitors, faulty control boards, bad transmissions...etc. Wiring breaks are very common at wire tie-down points. Check the wiring harness under there where the wire ties are. An intermittent connection may cause the shifter to fail. The shifter has electronics in it as it not only shifts the splutch between agitate and spin but also has the rpm sensor to detect basket speed. Whirlpool should at least own up to the shifter probem but apparently, once out of warranty, your out of luck.
Eric
Sixb412
#3 Posted : Monday, August 5, 2013 6:14:04 AM(UTC)
Sixb412
That's "great" to know. I've only had the washer for 3 years and so many calls to get it repaired since. I have seen the technician make an easy switch each time he's done it. 15 mins tops. I'm sure there are instructions on this site as to how to do so without screwing it up myself. I'm just not sure if I'll have all the tools. Thanks for input, it is appreciated.
fairbank56
#4 Posted : Monday, August 5, 2013 6:40:00 AM(UTC)
fairbank56
Groups: Expert
All you need is a 5/16 nut driver and a phillips screwdriver. Very simple to replace. See video.
Shift Actuator - Washer Repair (Whirlpool # W10006355 Replacement Part) - YouTube
Eric
Sixb412
#5 Posted : Thursday, August 8, 2013 9:06:12 AM(UTC)
Sixb412
Much thanks Eric!
Whirlpool Cabrio WTW6300SW1 (Washer Repair)
by Fieldsafo 2/12/2024 4:00:47 PM(UTC)
Whirlpool Cabrio Drum Mounting Hub replacement options (Washer Repair)
by Guest 5/8/2023 6:48:34 AM(UTC)
Whirlpool Cabrio - passes diags but wont initiate a cycle (Washer Repair)
by Jack Jolly 2/13/2023 9:20:45 AM(UTC)
Whirlpool Cabrio electric dryer model WED5800BW0 (Dryer Repair)
by thorning 9/26/2022 12:44:56 PM(UTC)
Whirlpool Cabrio washer water pressure too high in detergent dispenser (Washer Repair)
by dwprog 8/10/2022 11:52:58 AM(UTC)
Whirlpool Cabrio washer TWT8600 will not spin at the end of cycle (Washer Repair)
by ADK522JNRS 6/1/2022 5:53:35 AM(UTC)
Whirlpool Cabrio WTW6600SW2 drum will not balance (Washer Repair)
by Guest 5/28/2022 7:45:19 AM(UTC)
Whirlpool Cabrio Washer Stops Intermittently (Dishwasher Repair)
by Amadago76 4/1/2022 9:57:02 AM(UTC)
Whirlpool Cabrio (WTW6800WW1) (Washer Repair)
by jkernsjr 1/13/2022 1:01:50 PM(UTC)
Whirlpool CabrioWTW5800BC0 (Dryer Repair)
by Juiceboi01 12/19/2021 8:09:03 PM(UTC)
Whirlpool Cabrio Washing Machine replaced transmission (Washer Repair)
by reggiebliss 8/26/2021 7:31:39 PM(UTC)
Whirlpool cabrio won't spin out (Washer Repair)
by Guest 7/28/2021 7:22:56 AM(UTC)
Whirlpool Cabrio Washer banging noise at the spin cycle (Washer Repair)
by Guest 5/13/2021 2:33:38 PM(UTC)
Whirlpool cabrio washer won’t final spin (Washer Repair)
by Guest 3/20/2021 8:31:43 PM(UTC)
Whirlpool Cabrio MVWC400XW making horrible high pitched grinding noise (Washer Repair)
by kwale 3/6/2021 1:11:38 PM(UTC)
