When you hit the cycle you want lights up everything works except when you go to push the start button nothing!! Replaced the interface still nothing! what should we try next??
Please help I need a washer
So no error codes or nothing pops up? does it triple beep or anything? Check all your connections at your main board and other boards along the top of the dryer and try it again.
Originally Posted by: HumboldtRepairMan So no error codes or nothing pops up? does it triple beep or anything? Check all your connections at your main board and other boards along the top of the dryer and try it again.[/quote
No error codes at all when you hold the start button it usually locks the door and we are getting nothing its the washer not the dyer?? we have checked all the connections.
