Discuss
Washer belt keeps coming off of pulley.
 in
Washer Repair
Try to wash cloths and washer agitates and works until final spin. Won't spin belt comes off of the pulley
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer belt keeps coming off of pulley.
  #1 (permalink)
Old 07-31-2013, 06:40 PM
Junior Member
josh fatouros is on a distinguished road
Cool Washer belt keeps coming off of pulley.
Brand: Frigidaire   Age: 5 - 10 years
Try to wash cloths and washer agitates and works until final spin. Won't spin belt comes off of the pulley and motor. Why does this happen.
  #2 (permalink)
Old 08-03-2013, 03:57 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
If you will post a model number so we can see exactly what machine you have someone may be able to help you.
__________________
  #3 (permalink)
Old 08-03-2013, 04:53 PM
Junior Member
Default
The model number is gleh1642ds1
  #4 (permalink)
Old 08-03-2013, 04:58 PM
Senior Expert
APP Volunteer
Default
It is possible that the belt has stretched, but more likely the pulley is defective.
Try replacing both the belt and the pulley assembly and see if that does not solve the problem.
__________________
  #5 (permalink)
Old 08-03-2013, 05:03 PM
Junior Member
Default
When I install the belt. If I center it on the pulley it rides on the outer most edge of the motor pulley grooves.
  #6 (permalink)
Old 08-03-2013, 05:07 PM
Junior Member
Default
I can see if the belt stretched but how does the pulley go bad it's aluminum . Are there any bearings that allow the belt not to line up. Is there any adjustment on the motor to align the pulleys. Thanks for your help!
  #7 (permalink)
Old 08-03-2013, 05:18 PM
Senior Expert
APP Volunteer
Default
Yes to both points. Aluminum as you know can easily warp and it only takes a few mm of warp to throw it off and let the belt come off.
Here is a link to the service manual for your model.
http://www.emaservicetips.com/pdfs/4...tionWasher.pdf
You may have to replace the pulley on spec because the problem may be so small that it is not visible to the naked eye.
__________________
  #8 (permalink)
Old 08-03-2013, 05:24 PM
Junior Member
Default
Thanks for your help. I will look at the service manual. I will order a pulley and belt and hopefully that takes care of the problem. I have been scratching my head on this one, because the pulley looks just fine. Thanks for everything.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Belt comes off pulley. Pulley wobbles. Scott56 Washer Repair 1 05-03-2013 06:52 PM
amana washer wont spin,pump free ,replaced belt and pulley, agitates but makes terri hndy1331 Washer Repair 1 03-05-2012 02:33 PM
motor pulley for belt TITANICHISPANIC Dryer Repair 2 01-10-2012 03:10 AM
replace belt and pulley paulcard06 Dryer Repair 1 04-29-2011 01:05 AM
need pulley/belt diagram ziemblicki Dryer Repair 1 12-29-2009 05:53 PM
