Discuss
washer stuck on switch function
 in
Washer Repair
my estate washer function switch seems to have stopped advancing. It just sits and does what ever function is selected
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer stuck on switch function
  #1 (permalink)
Old 07-25-2013, 03:09 PM
Junior Member
calvanandlori@yahoo.com is on a distinguished road
Default washer stuck on switch function
Model Number: estate TAWX700PQ0   Brand: Estate   Age: 5 - 10 years
my estate washer function switch seems to have stopped advancing. It just sits and does what ever function is selected - forever. Is this problem the switch or something else?
Related Models
Amana ESU12HW FREEZER- VERTICAL
Amana ESU12JW FREEZER- VERTICAL
Amana ESU13 FREEZER- VERTICAL
Amana ESU13-A FREEZER- VERTICAL
Amana ESU13-AG FREEZER- VERTICAL
Amana ESU13-C FREEZER- VERTICAL
Amana ESU13-L FREEZER- VERTICAL
Amana ESU13B FREEZER- VERTICAL
Amana ESU13B-A FREEZER- VERTICAL
Amana ESU13B-C FREEZER- VERTICAL
Amana ESU13B-G FREEZER- VERTICAL
Amana ESU13B-L FREEZER- VERTICAL
Amana ESU13C FREEZER- VERTICAL
Amana ESU13C-A FREEZER- VERTICAL
Amana ESU13C-C FREEZER- VERTICAL
Amana ESU13C-G FREEZER- VERTICAL
Amana ESU13CL FREEZER- VERTICAL
Amana ESU13D FREEZER- VERTICAL
Amana ESU13DW FREEZER- VERTICAL
Amana ESU15 FREEZER- VERTICAL
Amana ESU15-A FREEZER- VERTICAL
Amana ESU15-AG FREEZER- VERTICAL
Amana ESU15-C FREEZER- VERTICAL
Amana ESU15-L FREEZER- VERTICAL
Amana ESU15B FREEZER- VERTICAL
Amana ESU15B-A FREEZER- VERTICAL
Amana ESU15B-C FREEZER- VERTICAL
Amana ESU15B-G FREEZER- VERTICAL
Amana ESU15B-L FREEZER- VERTICAL
Amana ESU15C FREEZER- VERTICAL
Amana ESU15C-A FREEZER- VERTICAL
Amana ESU15C-C FREEZER- VERTICAL
Amana ESU15C-G FREEZER- VERTICAL
Amana ESU15CL FREEZER- VERTICAL
Amana ESU15D FREEZER- VERTICAL
Amana ESU15DW FREEZER- VERTICAL
Amana ESU15HW FREEZER- VERTICAL
Amana ESU15JW FREEZER- VERTICAL
Amana ESU17 FREEZER- VERTICAL
Amana ESU17-A FREEZER- VERTICAL
Amana ESU17-AG FREEZER- VERTICAL
Amana ESU17-C FREEZER- VERTICAL
Amana ESU17-L FREEZER- VERTICAL
Amana ESU17B FREEZER- VERTICAL
Amana ESU17B-A FREEZER- VERTICAL
Amana ESU17B-C FREEZER- VERTICAL
Amana ESU17B-G FREEZER- VERTICAL
Amana ESU17B-L FREEZER- VERTICAL
Amana ESU17C FREEZER- VERTICAL
Amana ESU17C-A FREEZER- VERTICAL
Amana ESU17C-C FREEZER- VERTICAL
Amana ESU17C-G FREEZER- VERTICAL
Amana ESU17CL FREEZER- VERTICAL
Amana ESU17D FREEZER- VERTICAL
Amana ESU17DW FREEZER- VERTICAL
Amana ESU17HW FREEZER- VERTICAL
Amana ESU17JW FREEZER- VERTICAL
Amana ESU20HW FREEZER- VERTICAL
Amana ESU20JW FREEZER- VERTICAL
Amana ESU513 FREEZER- VERTICAL
Amana ESU513-A FREEZER- VERTICAL
Amana ESU513-AG FREEZER- VERTICAL
Amana ESU513-C FREEZER- VERTICAL
Amana ESU513-L FREEZER- VERTICAL
Amana ESU515 FREEZER- VERTICAL
Amana ESU515-A FREEZER- VERTICAL
Amana ESU515-AG FREEZER- VERTICAL
Amana ESU515-C FREEZER- VERTICAL
Amana ESU515-L FREEZER- VERTICAL
Amana ESU517 FREEZER- VERTICAL
Amana ESU517-A FREEZER- VERTICAL
Amana ESU517-AG FREEZER- VERTICAL
Amana ESU517-C FREEZER- VERTICAL
Amana ESU517-L FREEZER- VERTICAL
Amana ESUF14 FREEZER- VERTICAL
Amana ESUF14-A FREEZER- VERTICAL
Amana ESUF14-AG FREEZER- VERTICAL
Amana ESUF14-C FREEZER- VERTICAL
Amana ESUF14-L FREEZER- VERTICAL
Amana ESUF14B FREEZER- VERTICAL
Amana ESUF14B-A FREEZER- VERTICAL
Amana ESUF14B-AG FREEZER- VERTICAL
Amana ESUF14B-C FREEZER- VERTICAL
Amana ESUF14B-L FREEZER- VERTICAL
Amana ESUF14C FREEZER- VERTICAL
Amana ESUF14C-A FREEZER- VERTICAL
Amana ESUF14C-C FREEZER- VERTICAL
Amana ESUF14C-G FREEZER- VERTICAL
Amana ESUF14C-L FREEZER- VERTICAL
Amana ESUF15HW FREEZER- VERTICAL
Amana ESUF15JW FREEZER- VERTICAL
Amana ESUF16 FREEZER- VERTICAL
Amana ESUF16-A FREEZER- VERTICAL
Amana ESUF16-AG FREEZER- VERTICAL
Amana ESUF16-C FREEZER- VERTICAL
Amana ESUF16-L FREEZER- VERTICAL
Amana ESUF16B FREEZER- VERTICAL
Amana ESUF16B-A FREEZER- VERTICAL
Amana ESUF16B-AG FREEZER- VERTICAL
Amana ESUF16B-C FREEZER- VERTICAL
Amana ESUF16B-L FREEZER- VERTICAL
Amana ESUF16C FREEZER- VERTICAL
Amana ESUF16C-A FREEZER- VERTICAL
  #2 (permalink)
Old 07-25-2013, 03:12 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
Check to make sure you're getting 120v to the unit first off...........Then try different cycles throughout the dial..........you either probably have a cycle on your timer that's burned out or the timer itself is more then likely burned out......Check all the connections in the back of the timer as well make sure they are firm.............good luck
  #3 (permalink)
Old 07-25-2013, 03:31 PM
Junior Member
Default thank you
seems stuck in all cycles. New times 130 bucks. still cheaper than a new washer. Thanks
  #4 (permalink)
Old 07-26-2013, 05:29 AM
Junior Member
Default how to remove it now?
I followed the directions to remove the "Knob" but the disc under the know won't come off. So I can't get the timer off. I take it HumboldtRepairMan is in California? Too bad.
  #5 (permalink)
Old 07-26-2013, 05:40 AM
Senior Member
Default
Yep northern California where the redwoods meet the beach and i have a house on the beach actually. Anyways go to sears parts website and they will show you a breakdown of how your machine comes apart.......be patient and you'll figure it out it's very simple.......
  #6 (permalink)
Old 07-26-2013, 05:47 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
The timer disc should just pull off. You may need to use a couple small screwdrivers to evenly pry it loose.
This forum is not staffed. We are volunteer techs who check in periodically to help people out. We are not sitting at a computer waiting for people posting their questions. There are online paid services for that.
Eric
  #7 (permalink)
Old 07-26-2013, 06:47 AM
Junior Member
Default
Thanks. They also have the cheapest part at 88$. I love the internet!
  #8 (permalink)
Old 07-26-2013, 11:30 AM
Junior Member
Default
You were right! And I did all the work. $156.48 to get the KNOWN correct part local TODAY, some research and helpful hints and I'm back in business. Good job!
  #9 (permalink)
Old 07-26-2013, 11:31 AM
Junior Member
Default
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Logic Board?? Switch stuck?? Tedje Washer Repair 5 12-03-2012 11:15 AM
Proper Range/Function Switch Settings on DMM WaltnCampSwampy Dryer Repair 3 12-09-2010 05:17 AM
Burner Stuck on High...which switch? gta289 Oven Repair (including Ranges and Cooktops) 0 10-15-2010 07:01 AM
temperature level switch function? spaldini101 Dryer Repair 0 03-26-2010 10:51 AM
Bosch Dishwasher On/Off Switch Stuck Martinlady Dishwasher Repair 0 10-10-2009 07:53 AM
