Discuss
Help
 in
Washer Repair
This started have the washer making a very loud noise when spinning. So I replaced the tub bearing, the transmission,
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Help
  #1 (permalink)
Old 07-23-2013, 05:59 AM
Junior Member
diverken is on a distinguished road
Default Help
Model Number: GZ923967G   Brand: GE   Age: More than 10 years
This started have the washer making a very loud noise when spinning. So I replaced the tub bearing, the transmission, the tub bearing washer, the split ring tub bearing and the tub seal. Now there is no noise when it spins but it is leaking and looks like it is coming from where the transmission meets the tub. I have replaced the split ring tub bearing, the tub seal and the tub bearing washer and IT STILL LEAKS. What can I do?
Related Models
Bosch GZ936-010
Whirlpool GZ9730SSS0 30" & 36" Hood
Whirlpool GZ9730XSS0 30" & 36" Hood
Whirlpool GZ9736SSS0 30" & 36" Hood
Whirlpool GZ9736XSS0 30" & 36" Hood
Bosch GZ990-010
Bosch GZ991-010
Bosch GZ992-010
Hardwick H-414 SURFACE UNIT- GAS
Hardwick H-434 SURFACE UNIT- GAS
Hardwick H-444 SURFACE UNIT- GAS
Hardwick H-445 SURFACE UNIT- ELE
Hardwick H-446 SURFACE UNIT- GAS
Thermador H-62 RANGE HOOD
Thermador H-62A RANGE HOOD
Thermador H-63 RANGE HOOD
Thermador H-63A RANGE HOOD
Thermador H-64 RANGE HOOD
Thermador H-65 RANGE HOOD
Thermador H-66 RANGE HOOD
Thermador H-66A RANGE HOOD
Thermador H-67 RANGE HOOD
Thermador H-67A RANGE HOOD
Thermador H-71 RANGE HOOD
Thermador H-76 RANGE HOOD
Thermador H-98 RANGE HOOD
Hoover H1005---
Hardwick H1100PAW RANGE- F/S STD GAS
Hardwick H1100PRA RANGE- F/S STD GAS
Hardwick H1100PRA-K RANGE- F/S STD GAS
Hardwick H1100PRW RANGE- F/S STD GAS
Hardwick H1100PRW-K RANGE- F/S STD GAS
Hardwick H1500PRW RANGE- F/S STD ELE
Frigidaire H15A Frg(v1) / Chest Freezer
Frigidaire H15B Frg(v2) / Chest Freezer
Frigidaire H15C Frg(v3) / Chest Freezer
Frigidaire H20A Frg(v1) / Chest Freezer
Frigidaire H20B Frg(v2) / Chest Freezer
Frigidaire H23A Frg(v1) / Chest Freezer
Frigidaire H23B Frg(v2) / Chest Freezer
Hoover H2510
Hoover H2800--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover H2800050 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover H28010RM UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Hoover H2850 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover H2850050 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover H3000--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover H3000001 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover H3000006 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover H3000011 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover H3000020 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover H30010RM HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover H3010--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover H3010020 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover H3012020 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Maytag H302RA HOOD
Maytag H302RB HOOD
Maytag H302RQ HOOD
Maytag H302RS HOOD
Maytag H302RW HOOD
Hoover H3030--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover H3030001 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover H3030006 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Maytag H303RA HOOD
Maytag H303RB HOOD
Maytag H303RQ HOOD
Maytag H303RS HOOD
Maytag H303RW HOOD
Maytag H304RA HOOD
Maytag H304RB HOOD
Maytag H304RQ HOOD
Maytag H304RS HOOD
Maytag H304RW HOOD
Hoover H3050 UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Hoover H3050010 UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Hoover H3060--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover H3060020 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Thermador H30HQS RANGE HOODS
Thermador H30HQW RANGE HOOD
Hardwick H31000PAAD RANGE- F/S STD GAS
Hardwick H31000PAWD RANGE- F/S STD GAS
Hardwick H3100PPA RANGE- F/S STD GAS
Hardwick H3100PPW RANGE- F/S STD GAS
Hardwick H31103SAA RANGE- F/S STD GAS
Hardwick H31103SAW RANGE- F/S STD GAS
Hardwick H3110PPA RANGE- F/S STD GAS
Hardwick H3110PPW RANGE- F/S STD GAS
Hardwick H3110PRA RANGE- F/S STD GAS
Hardwick H3110PRW RANGE- F/S STD GAS
Hardwick H3120SPA RANGE- F/S STD GAS
Hardwick H3120SPW RANGE- F/S STD GAS
Hardwick H3120SRA RANGE- F/S STD GAS
Hardwick H3120SRW RANGE- F/S STD GAS
Hardwick H3131WRA RANGE- F/S STD GAS
Hardwick H3131WRW RANGE- F/S STD GAS
Hardwick H3131WTA RANGE- F/S STD GAS
Hardwick H3131WTW RANGE- F/S STD GAS
Hardwick H3131WUA RANGE- F/S STD GAS
Hardwick H3131WUW RANGE- F/S STD GAS
Hardwick H3131XRA RANGE- F/S STD GAS
Hardwick H3131XRW RANGE- F/S STD GAS
Hardwick H3131XTA RANGE- F/S STD GAS
Hardwick H3131XTW RANGE- F/S STD GAS
Hardwick H3131XUA RANGE- F/S STD GAS
Hardwick H3131XUW RANGE- F/S STD GAS
Hardwick H3137WRA-L RANGE- F/S STD GAS
Hardwick H3137WRV-L RANGE- F/S STD GAS
Hardwick H3137WUA-L RANGE- F/S STD GAS
Hardwick H3137WUV-L RANGE- F/S STD GAS
Hardwick H3177XRA RANGE- F/S STD GAS
Hardwick H3177XRW RANGE- F/S STD GAS
Hardwick H3177XUA RANGE- F/S STD GAS
Hardwick H3177XUW RANGE- F/S STD GAS
Hardwick H3221WRV RANGE-F/S CONT CLEAN GAS
Hardwick H3221WTV RANGE-F/S CONT CLEAN GAS
Hardwick H32315WAM RANGE-F/S CONT CLEAN GAS
Hardwick H32315WAV RANGE-F/S CONT CLEAN GAS
Hardwick H3231XRA RANGE-F/S CONT CLEAN GAS
Hardwick H3231XRW RANGE-F/S CONT CLEAN GAS
Hardwick H3231XTA RANGE-F/S CONT CLEAN GAS
  #2 (permalink)
Old 07-23-2013, 07:06 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
Your model number is invalid........Buy a new machine sounds like you botched the installation and should of hired a professional.......you may have caused other damage by your installation and continuous motor leak on electronic parts.......
  #3 (permalink)
Old 07-24-2013, 05:40 AM
Junior Member
Default Leaking
Try this #WJSR2080V3WW, see if that works!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
