Discuss
kenmore washer 110 fills and stops
 in
Washer Repair
The washer fills and the stops..it makes a buzzing sound.. replaced the lid switch last year, thought it was the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » kenmore washer 110 fills and stops
  #1 (permalink)
Old 07-22-2013, 01:15 PM
Junior Member
tmo314 is on a distinguished road
Default kenmore washer 110 fills and stops
Model Number: 1102582991   Brand: Kenmore   Age: 5 - 10 years
The washer fills and the stops..it makes a buzzing sound.. replaced the lid switch last year, thought it was the motor coupler and replaced that but its not..it still spins and drains.
Related Models
Kenmore 11025832400 RESIDENTIAL WASHER
Kenmore 11025842400 AUTOMATIC WASHER
Kenmore 11025844400 AUTOMATIC WASHER
Kenmore 11025852400 AUTOMATIC WASHER
Kenmore 11025854400 AUTOMATIC WASHER
Kenmore 11025862400 AUTOMATIC WASHER
Kenmore 11025864400 AUTOMATIC WASHER
Kenmore 11026002010 AUTOMATIC WASHER
Kenmore 11026002011 AUTOMATIC WASHER
Kenmore 11026012010 AUTOMATIC WASHER
Kenmore 11026012011 AUTOMATIC WASHER
Kenmore 11026051690 COMMERCIAL AUTOMATIC WASHER
Kenmore 11026058690 COMMERCIAL AUTOMATIC WASHER
Kenmore 11026071690 COMMERCIAL WASHER
Kenmore 11026071691 COMMERCIAL WASHER
Kenmore 11026152500 WASHER COMMERCIAL
Kenmore 11026292690 AUTOMATIC WASHER
Kenmore 11026292691 AUTOMATIC WASHER
Kenmore 11026292692 AUTOMATIC WASHER
Kenmore 11026292693 AUTOMATIC WASHER
Kenmore 11026292694 WASHER
Kenmore 11026292695 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11026294690 AUTOMATIC WASHER
Kenmore 11026294691 AUTOMATIC WASHER
Kenmore 11026294692 AUTOMATIC WASHER
Kenmore 11026294693 AUTOMATIC WASHER
Kenmore 11026294694 WASHER
Kenmore 11026294695 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11026322500 WASHER
Kenmore 11026322501 WASHER
Kenmore 11026322502 RESIDENTIAL WASHER
Kenmore 11026322503 RESIDENTIAL WASHER
Kenmore 11026332500 RESIDENTIAL WASHER
Kenmore 11026332501 WASHER
Kenmore 11026332502 RESIDENTIAL WASHER
Kenmore 11026332503 RESIDENTIAL WASHER
Kenmore 11026342500 RESIDENTIAL WASHER
Kenmore 11026342501 WASHER
Kenmore 11026342502 RESIDENTIAL WASHER
Kenmore 11026342503 RESIDENTIAL WASHER
Kenmore 11026422500 RESIDENTIAL WASHER
Kenmore 11026422501 WASHER
Kenmore 11026422502 RESIDENTIAL WASHER
Kenmore 11026422503 RESIDENTIAL WASHER
Kenmore 11026432500 WASHER
Kenmore 11026432501 WASHER
Kenmore 11026432502 RESIDENTIAL WASHER
Kenmore 11026432503 RESIDENTIAL WASHER
Kenmore 1102644182 RESIDENTIAL WASHER
Kenmore 11026442500 WASHER
Kenmore 11026442501 WASHER
Kenmore 11026442502 RESIDENTIAL WASHER
Kenmore 11026442503 RESIDENTIAL WASHER
Kenmore 1102644722 RESIDENTIAL WASHER
Kenmore 11026622690 WASHER
Kenmore 11026622691 AUTOMATIC WASHER
Kenmore 11026632500 WASHER
Kenmore 11026632501 WASHER
Kenmore 11026632502 WASHER
Kenmore 11026632503 RESIDENTIAL WASHER
Kenmore 11026642500 WASHER
Kenmore 11026642501 washer
Kenmore 11026642502 WASHER
Kenmore 11026642503 RESIDENTIAL WASHER
Kenmore 11026652500 WASHER
Kenmore 11026652501 WASHER
Kenmore 11026652502 WASHER
Kenmore 11026652503 RESIDENTIAL WASHER
Kenmore 11026682503 RESIDENTIAL WASHER
Kenmore 11026692503 RESIDENTIAL WASHER
Kenmore 11026702690 AUTOMATIC WASHER
Kenmore 11026702691 AUTOMATIC WASHER
Kenmore 11026702692 AUTOMATIC WASHER
Kenmore 11026702693 AUTOMATIC WASHER
Kenmore 11026702694 AUTOMATIC WASHER
Kenmore 11026712690 WASHER
Kenmore 11026712691 AUTOMATIC WASHER
Kenmore 11026712692 AUTOMATIC WASHER
Kenmore 11026712693 AUTOMATIC WASHER
Kenmore 11026722690 WASHER
Kenmore 11026722691 AUTOMATIC WASHER
Kenmore 11026722692 AUTOMATIC WASHER
Kenmore 11026722693 AUTOMATIC WASHER
Kenmore 11026732500 WASHER
Kenmore 11026732501 WASHER
Kenmore 11026732502 WASHER
Kenmore 11026732503 RESIDENTIAL WASHER
Kenmore 11026742500 WASHER
Kenmore 11026742501 WASHER
Kenmore 11026742502 WASHER
Kenmore 11026742503 RESIDENTIAL WASHER
Kenmore 11026752500 WASHER
Kenmore 11026752501 WASHER
Kenmore 11026752502 WASHER
Kenmore 11026752503 RESIDENTIAL WASHER
Kenmore 11026791690 AUTOMATIC WASHER
Kenmore 11026791691 AUTOMATIC WASHER
Kenmore 11026801690 AUTOMATIC WASHER
Kenmore 11026801691 AUTOMATIC WASHER
Kenmore 11026801692 AUTOMATIC WASHER
Kenmore 11026808690 WASHER
Kenmore 11026808691 AUTOMATIC WASHER
Kenmore 11026808692 AUTOMATIC WASHER
Kenmore 11026809690 AUTOMATIC WASHER
Kenmore 11026812690 WASHER
Kenmore 11026812691 AUTOMATIC WASHER
Kenmore 11026814690 WASHER
Kenmore 11026814691 AUTOMATIC WASHER
Kenmore 11026822690 WASHER
Kenmore 11026822691 AUTOMATIC WASHER
Kenmore 11026822692 AUTOMATIC WASHER
Kenmore 11026824690 WASHER
Kenmore 11026824691 AUTOMATIC WASHER
Kenmore 11026824692 AUTOMATIC WASHER
Kenmore 11026832690 AUTOMATIC WASHER
Kenmore 11026832691 AUTOMATIC WASHER
Kenmore 11026832692 AUTOMATIC WASHER
Kenmore 11026832694 AUTOMATIC WASHER
Kenmore 11026834690 WASHER
Kenmore 11026834691 AUTOMATIC WASHER
  #2 (permalink)
Old 07-22-2013, 02:20 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Missing a number in the model number. Does the timer advance on it's own after it stops filling?
Eric
  #3 (permalink)
Old 07-22-2013, 09:18 PM
Junior Member
Default
No it doesn't
  #4 (permalink)
Old 07-22-2013, 09:32 PM
Expert
APP Volunteer
Default
Does the buzzing come from the control panel area or down at the bottom front where the motor is. Need the correct model number of the washer, should be 11 numbers.
Eric
  #5 (permalink)
Old 07-22-2013, 10:16 PM
Junior Member
Default
Model 11025852991...buzzing comes from up top
  #6 (permalink)
Old 07-23-2013, 06:52 AM
Expert
APP Volunteer
Default
Check the number again, it is not coming up.
Eric
  #7 (permalink)
Old 07-23-2013, 09:31 AM
Junior Member
Default
11029852991
  #8 (permalink)
Old 07-23-2013, 10:48 AM
Expert
APP Volunteer
Default
Open control panel and determine if buzzing is from timer or speed select switch. Does speed switch have individual connections or plug type connector(s)? Does agitation work in any other speed?
Eric
  #9 (permalink)
Old 07-24-2013, 08:16 AM
Junior Member
Default
Agitator only works in spin...buzzing is coming from timer switch...speed switch has its own connection
  #10 (permalink)
Old 07-24-2013, 09:59 AM
Expert
APP Volunteer
Default
The pressure switch is located on the left side behind the control panel. With washer off, disconnect and jump together the violet and tan wires and start washer in wash cycle. If it still won't agitate, need to jump out the speed switch but need a clear photo of your wiring diagram. Diagram should be behind control panel. Assume you tried different speed settings. Problem could be timer, speed switch or motor. Need to rule out the speed switch. No noise from motor during agitate, correct? Motor is at bottom front of cabinet.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore dishwasher fills, starts to wash then stops msbee03 Dishwasher Repair 3 11-03-2012 05:42 PM
Washer fills then stops husky Washer Repair 1 04-11-2011 05:32 PM
Kenmore Whasher fills up w/ water then stops Ruben1977 Washer Repair 2 04-03-2010 06:22 PM
washer fills and stops gabednar Washer Repair 1 09-19-2009 07:53 PM
washer fills then stops julie larson Washer Repair 3 01-07-2009 04:55 AM
