Discuss
Maytag front loading washer randomly filling with water
 in
Washer Repair
I have a Maytag front-loading washer (probably a Maytag Neptune) that is randomly filling with water even when the washer
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag front loading washer randomly filling with water
  #1 (permalink)
Old 07-22-2013, 08:51 AM
Junior Member
tcknw is on a distinguished road
Post Maytag front loading washer randomly filling with water
Brand: Maytag   Age: 5 - 10 years
I have a Maytag front-loading washer (probably a Maytag Neptune) that is randomly filling with water even when the washer is turned off and the door is open. Unfortunately, I was out-of-town and my house flooded, not once, but twice. Ugh! This happened once and the machine was drained and unplugged, thinking that would take care of any issues, but when I returned home last evening, it had water in it again. I drained the machine last night before going to bed and this morning awoke to a tub of water again. Help!
  #2 (permalink)
Old 07-24-2013, 12:21 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Darn, sorry to hear that.
The most likely problem is that one or both of your inlet valves is stuck in the partially open position. If it is filling with water while the machine is unplugged this is most likely the problem.
Change out the valve assembly and see if that doesn't fix things.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Samsung WF330AN front load washer is continuously filling with water from a valve in tasmith Washer Repair 1 12-06-2012 11:51 AM
Maytag front loading washer not spinning Brazilnutjr Washer Repair 8 11-07-2012 01:10 PM
maytag front loading washer not spinning chicity Washer Repair 0 09-27-2012 09:38 PM
Maytag Atlantis top loading washer doesn't spin out water ramchaza Washer Repair 2 03-22-2010 10:47 AM
Water pools around bottom of front loading washer Warranty Avoider Washer Repair 1 03-29-2009 06:45 PM
