Discuss
Maytag Bravos X Not spinning, but no errors popping up
 in
Washer Repair
I'm gunna give it a shot and try a new shift actuator. I was testing the basket, and I think
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Bravos X Not spinning, but no errors popping up
  #11 (permalink)
Old 07-21-2013, 06:32 PM
Junior Member
jjl04002 is on a distinguished road
Default
I'm gunna give it a shot and try a new shift actuator. I was testing the basket, and I think it is spinning fairly normally.
I did try the RPM test, and the machine is detecting the rotation of the basket. I was kinda hoping it would fail so I could be sure this was the issue, but I suppose it's worth the shot. It is probably this or a control board, and I think this is the cheaper one to try first.
-Jeff
  #12 (permalink)
Old 07-24-2013, 08:51 AM
Junior Member
Default
Well that didn't fix it
I started it up again and got error F7 E6 if i remember correctly...which was a motor fault...
  #13 (permalink)
Old 07-24-2013, 10:08 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Check the motor windings (resistance) as per manual. Check continutiy of wiring between motor and capacitor, motor and control board.
Eric
  #14 (permalink)
Old 01-28-2014, 09:41 PM
Junior Member
A72model is on a distinguished road
Default
How did you finally get the clips opened. I cannot figure out how to pop the clips to open the top of mine. Thanks.
  #15 (permalink)
Old 04-08-2014, 11:19 PM
Junior Member
cokeclsc is on a distinguished road
Default
I am having the same problem... same model after the same length of time. I have changed the actuator and the capacitor, but all I get when it tries to spin or agitate is the hum. My error code is F7 E1. I was able to test the resistance on the motor and they were slightly higher (approx 22 ohms), but on an old meter.
I am not sure if it the motor or the control board. Anything else I can test?
  #16 (permalink)
Old 01-11-2015, 10:55 AM
Junior Member
samg is on a distinguished road
Default Maytag Bravos
Did you ever get the Bravos repaired? If so, what was the problem?
  #17 (permalink)
Old 06-11-2017, 12:12 PM
Junior Member
samboski is on a distinguished road
Default
I'd bet there's a broken wire - my washer has broken 2 so far:
Maytag Bravos actuator replaced but worked for less than a week
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Bravos Washer TreyWaltman Washer Repair 8 08-12-2014 07:10 AM
Maytag Bravos washer emudzin Washer Repair 0 05-07-2013 12:46 PM
maytag bravos Panterin Washer Repair 0 06-07-2012 02:17 PM
Maytag Bravos Dan boudreau Washer Repair 0 12-11-2011 11:55 AM
maytag bravos Daradale Washer Repair 0 09-15-2011 05:13 PM
