Hi All, I have a direct drive Whirlpool washer that would not agitate, so I replaced the dogs. It still would not work so I replaced all the upper washers and the agitator bolt It still would not agitate so I replaced the gearcase. Then, it would agitate, BEAUTIFULLY, but it quit spinning (aargh!) So, I bought new couplers and replaced those and - while I was at it and just so I didn't have to take it apart again - I also replaced the clutch. So, I put it all back together and turned it on and it filled and agitated, but I noticed it was leaking in the back from the cold hose so I turned off the water and tightened the hose. Now it is NOT AGITATING AGAIN, although it IS filling, draining and spinning. Does anyone know what I did wrong?
