Discuss
Kenmore He2+ F01 & F11 errors
 in
Washer Repair
I'm a mom and am pretty much the laundry lady in my home. To my dismay, my washer suddenly stopped
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore He2+ F01 & F11 errors
  #1 (permalink)
Old 07-20-2013, 01:52 PM
Junior Member
carter76112 is on a distinguished road
Question Kenmore He2+ F01 & F11 errors
Model Number: 11047512600   Brand: Kenmore   Age: 5 - 10 years
I'm a mom and am pretty much the laundry lady in my home. To my dismay, my washer suddenly stopped working properly a couple of days ago. It first flashed error F11. I ran the self test on it and it never seemed to spin when it was supposed to during the test. Then it flashed error F01. Both errors show up in the error history during diagnostics. There was water in the tub, where it didn't drain, which I shopvac'd out. I cleaned the trap (& found almost $2 in change ). After digging around the garage I finally found a test meter so I ohm'd the motor and get readings of ~7 ohms on each pair of leads & 125 ohms on the tach leads. (Thank goodness for the electronics training I got in the Air Force many years ago!) The testing booklet says that the prob could be the CCU, MCU, communication between the two, or the motor. Seems like the motor is probably good based on the test readings, but I can't find any info on how to test the CCU or the MCU. I saw on a repair board (don't know it it was this one or another site, I've looked at so many) that replacing the MCU might fix the problem. Can anyone help me to narrow down the problem more assuredly? Thanks!
Related Models
Kenmore 11047512600 RESIDENTIAL WASHER
Kenmore 11047512601 RESIDENTIAL WASHER
Kenmore 11047512602 RESIDENTIAL WASHER
Kenmore 11047512603 RESIDENTIAL WASHER
Kenmore 11047512604 RESIDENTIAL WASHER
Kenmore 11047512605 RESIDENTIAL WASHER
Kenmore 11047531700 RESIDENTIAL WASHER
Kenmore 11047531701 RESIDENTIAL WASHER
Kenmore 11047531702 RESIDENTIAL WASHER
Kenmore 11047532600 RESIDENTIAL WASHERS
Kenmore 11047532601 RESIDENTIAL WASHER
Kenmore 11047532602 RESIDENTIAL WASHER
Kenmore 11047532603 RESIDENTIAL WASHER
Kenmore 11047532604 RESIDENTIAL WASHER
Kenmore 11047532605 RESIDENTIAL WASHER
Kenmore 11047542600 RESIDENTIAL WASHER
Kenmore 11047542601 RESIDENTIAL WASHER
Kenmore 11047542602 RESIDENTIAL WASHER
Kenmore 11047542603 RESIDENTIAL WASHER
Kenmore 11047542604 RESIDENTIAL WASHER
Kenmore 11047542605 RESIDENTIAL WASHER
Kenmore 11047561600 RESIDENTIAL WASHERS
Kenmore 11047561601 RESIDENTIAL WASHER
Kenmore 11047561602 RESIDENTIAL WASHER
Kenmore 11047561603 RESIDENTIAL WASHER
Kenmore 11047561604 RESIDENTIAL WASHER
Kenmore 11047562700 RESIDENTIAL WASHER
Kenmore 11047566600 RESIDENTIAL WASHERS
Kenmore 11047566601 RESIDENTIAL WASHER
Kenmore 11047566602 RESIDENTIAL WASHER
Kenmore 11047566603 RESIDENTIAL WASHER
Kenmore 11047567700 RESIDENTIAL WASHER
Kenmore 11047567701 RESIDENTIAL WASHER
Kenmore 11047571600 RESIDENTIAL WASHERS
Kenmore 11047571601 RESIDENTIAL WASHER
Kenmore 11047571602 RESIDENTIAL WASHER
Kenmore 11047571603 RESIDENTIAL WASHER
Kenmore 11047571604 RESIDENTIAL WASHER
Kenmore 11047572700 RESIDENTIAL WASHERS
Kenmore 11047576600 RESIDENTIAL WASHERS
Kenmore 11047576601 RESIDENTIAL WASHER
Kenmore 11047576602 RESIDENTIAL WASHER
Kenmore 11047576603 RESIDENTIAL WASHER
Kenmore 11047577700 RESIDENTIAL WASHER
Kenmore 11047577701 RESIDENTIAL WASHER
Kenmore 11047581600 RESIDENTIAL WASHERS
Kenmore 11047581601 RESIDENTIAL WASHER
Kenmore 11047581602 RESIDENTIAL WASHER
Kenmore 11047581603 RESIDENTIAL WASHER
Kenmore 11047581604 RESIDENTIAL WASHER
Kenmore 11047602940 WASHER
Kenmore 11047661950 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11047662950 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11047701800 RESIDENTIAL WASHER
Kenmore 11047701801 WASHER
Kenmore 11047711800 RESIDENTIAL WASHER
Kenmore 11047711801 WASHER
Kenmore 11047751800 WASHER
Kenmore 11047751801 WASHER
Kenmore 11047761800 RESIDENTIAL WASHER
Kenmore 11047761801 WASHER
Kenmore 11047781700 RESIDENTIAL WASHER
Kenmore 11047781701 RESIDENTIAL WASHER
Kenmore 11047781702 WASHER
Kenmore 11047787800 WASHER
Kenmore 11047787801 WASHER
Kenmore 11047788800 WASHER
Kenmore 11047788801 WASHER
Kenmore 11047789700 RESIDENTIAL WASHER
Kenmore 11047789701 RESIDENTIAL WASHER
Kenmore 11047789702 WASHER
Kenmore 11047791700 RESIDENTIAL WASHER
Kenmore 11047791701 RESIDENTIAL WASHER
Kenmore 11047791702 WASHER
Kenmore 11047797800 RESIDENTIAL WASHER
Kenmore 11047797801 WASHER
Kenmore 11047798800 RESIDENTIAL WASHER
Kenmore 11047798801 WASHER
Kenmore 11047799701 RESIDENTIAL WASHER
Kenmore 11047799702 WASHER
Kenmore 11047852700 WASHER
Kenmore 11047852701 RESIDENTIAL WASHER
Kenmore 11047852702 RESIDENTIAL WASHER
Kenmore 11047852703 RESIDENTIAL WASHER
Kenmore 11047882700 WASHER
Kenmore 11047882701 RESIDENTIAL WASHER
Kenmore 11047882702 RESIDENTIAL WASHER
Kenmore 11047882703 RESIDENTIAL WASHER
Kenmore 11048182790 AUTOMATIC WASHER
Kenmore 11048182791 AUTOMATIC WASHER
Kenmore 11048184790 AUTOMATIC WASHER
Kenmore 11048184791 AUTOMATIC WASHER
Kenmore 11048722790 COMPACT AUTOMATIC WASHER
Kenmore 11048722791 COMPACT AUTOMATIC WASHER
Kenmore 11048724790 COMPACT AUTOMATIC WASHER
Kenmore 11048724791 COMPACT AUTOMATIC WASHER
Kenmore 11049182990 AUTOMATIC WASHER
Kenmore 11049182991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11049182992 WASHER
Kenmore 11049722990 AUTOMATIC WASHER
Kenmore 11049722991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11049722992 COMPACT WASHER
Kenmore 11049962600 WASHER
Kenmore 11049962601 RESIDENTIAL WASHER
Kenmore 11049962602 RESIDENTIAL WASHER
Kenmore 11049962603 RESIDENTIAL WASHER
Kenmore 11049972600 RESIDENTIAL WASHER
Kenmore 11049972601 RESIDENTIAL WASHER
Kenmore 11049972602 RESIDENTIAL WASHER
Kenmore 11049972603 RESIDENTIAL WASHER
Kenmore 1105062110 WASHER
Kenmore 110508802 KENMORE ELECTRIC DRYER
Kenmore 11051140 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11051309 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11051730 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11055592 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11055593 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11055610 WORM GEAR CASE ASSEMBLY
Kenmore 11055614 WORM GEAR CASE ASSEMBLY
Kenmore 11056171 WORM GEAR CASE ASSEMBLY
  #2 (permalink)
Old 07-21-2013, 05:24 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
This is a Whirlpool made Duet masquerading as a Kenmore. Even Whirlpool techs don't know how to fix them.
I suggest you order both boards and try replacing them one at a time. If you order from this site you can return the parts you don't need. Also, check the door lock mechanism, its not logical but sometimes that is the problem on these models.
__________________
  #3 (permalink)
Old 07-21-2013, 08:40 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
Sidfink43 is right it's a communication error or boards fouling out. The HE HE2 HE3 HE4 washers and dryers all have this problem and there a real pain. Test at the motor control the small blue wires should have 5 vdc and the 2 pink wires coming in should have 120acv if you have those readings the main board should be ok. If you have those readings at your motor control on the bottom the suspect would be the motor control or motor having issues. Also don't rule out the door lock like he had mentioned those are a common problem with front loaders when they won't go into a spin. Should have a nice heavy click when it locks/unlocks it shouldn't be hesitant or having a buzzing noise when it locks/unlocks.
  #4 (permalink)
Old 07-21-2013, 09:36 PM
Junior Member
Default
Thanks for your advice, y'all! Just a couple of more questions:
Sidfink, I think I will follow your advice on ordering both parts and replacing them one at a time. That seems to make the most sense and will save a lot of time on the front end. Do you happen to know the part numbers I will need?
Humboldt, I assume I need to test these voltages at the motore while the machine is plugged in, but do I need to turn it on and select a cycle also? If so, any cycle or a specific one? It is a real pain to reach the motor and the MCU on this machine. I feel like I am practicing to be a contortionist every time I work on it! I honestly think the door lock is fine. There is a good, solid clunk when it locks and unlocks.
I sure hope the voltage readings are good, since I am guessing you have to remove the back of the machine in order to access the motor if it goes bad. I will wait to hear a reply before doing more testing to save some wear and tear on my knees and back.
  #5 (permalink)
Old 07-22-2013, 06:20 AM
Senior Expert
APP Volunteer
Default
If you click on your model number you will be taken to the parts pages for your machine. Or you can call APP and give them the model number (they may also need the serial number, so have it handy too) and they will fix you up.
Those of us who reply on this site are not connected with the APP parts operations, we are mostly volunteers but we do this in part because APP gives great service and great prices and great delivery.
__________________
  #6 (permalink)
Old 07-22-2013, 09:03 AM
Junior Member
Default
I really appreciate your help. I'll look them up and order both as you advised. Thanks!
  #7 (permalink)
Old 07-22-2013, 09:57 AM
Senior Expert
APP Volunteer
Default
Great, good luck and let us know how it turns out.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore errors and door locked LorettaNash Oven Repair (including Ranges and Cooktops) 0 11-15-2011 05:04 PM
Fisher & Paykel 'F9 errors' Nukacola Dishwasher Repair 0 10-04-2011 08:22 PM
F10 and F30 Errors. SittingDucks Oven Repair (including Ranges and Cooktops) 0 12-19-2009 01:37 PM
F80 and F83 errors on Kenwmore Oasis toddx Washer Repair 0 10-17-2009 10:44 AM
Kenmore Washing Machine errors Vintagecharms Washer Repair 3 06-10-2009 09:29 AM
