Discuss
GE Washer Not Agitating or Spinning
 in
Washer Repair
Anything sufficiently thin and stiff enough such as a butter knife will work to push into the front panel groove
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE Washer Not Agitating or Spinning
  #11 (permalink)
Old 07-20-2013, 05:44 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Anything sufficiently thin and stiff enough such as a butter knife will work to push into the front panel groove to release the clips. First, I need to know if it is in fact the motor that is humming when it should be in agitate or spin. Then I need to know if you can freely rotate the motor pulley in each direction and that when you do that, the belt and the larger drive pulley rotate as well. It could just be that the belt is broken although that is very rare on these washers.
Eric
  #12 (permalink)
Old 07-22-2013, 12:21 PM
Junior Member
KerriH is on a distinguished road
Default
Got around to inspecting the washer today. Belt is still in tact, and the motor moves both ways manually. I took a video so you can hear the noises it's making . . . note the motor humming and the weird grinding noise up on the control panel.
Washer noises - YouTube
  #13 (permalink)
Old 07-22-2013, 01:48 PM
Expert
APP Volunteer
Default
Looks like you need a new timer. Unplug the washer. Open the user control panel and unplug the timer connector. Plug washer back in. Is the grinding noise gone? If so, replace the timer. If you buy from APP, you can return the timer if it isn't the problem.
GE WH12X10254 Timer - AppliancePartsPros.com
Eric
  #14 (permalink)
Old 07-22-2013, 02:27 PM
Junior Member
Default
It is definitely the timer. But what does that have to do with the motor humming when the washer is trying to run?
I will order a new timer ASAP! Thanks so very much!
  #15 (permalink)
Old 07-22-2013, 03:23 PM
Expert
APP Volunteer
Default
Well, that may not be the only problem with your washer. The only way to determine that is to do some electrical troubleshooting. Hopefully, it's just the timer. The timer has multiple sets of contacts in it to perform various functions. The motor has 4 windings in it. If it doesn't get the proper power to the proper windings it can cause the motor to just sit there and hum. Letting it sit there and just hum without rotating can damage the windings. Hopefully, that hasn't happened with your motor.
Eric
  #16 (permalink)
Old 07-22-2013, 03:29 PM
Junior Member
Default
I hope not! I'll update you when I replace the timer. Thanks for all the help, Eric! I hope it helped MamaFixedIt too.
  #17 (permalink)
Old 07-23-2013, 06:28 AM
Junior Member
MamaFixedIt is on a distinguished road
Default
Good luck getting your problem fixed Kerri. My motor is dead. I should change my screen name to MamaBoughtaNewOne!
  #18 (permalink)
Old 08-07-2013, 01:44 PM
Junior Member
Default
That wasn't the issue. Same noises, same behavior. How do I go about returning the timer?
  #19 (permalink)
Old 08-31-2013, 11:54 AM
Junior Member
dbshotgunner is on a distinguished road
Default Similar problem
I have a GE washer Model WBSR3140G5CC that won't agitate or spin. It goes through the cycles normally, so timer appears to be working, but doesn't agitate or spin when supposed to. The LED on the motor flashes normally. I followed the reset procedure, but it made no difference. I have bypassed the lid switch - same result. The belt is on, drum and shaft to agitator appear to turn freely. What do I try next?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Washer not spinning or agitating dp2763 Oven Repair (including Ranges and Cooktops) 0 12-05-2012 01:57 PM
Washer not spinning or agitating drslgsr Washer Repair 1 05-30-2011 05:03 PM
Washer - not agitating or spinning char2234 Washer Repair 0 06-30-2010 12:16 PM
washer not spinning or agitating but does everything else albarran61483 Washer Repair 5 03-29-2010 06:22 AM
washer not spinning or agitating again. bounette77 Washer Repair 2 02-17-2010 11:00 AM
