washer makes loud clunking noise at the end of spin cycle till basket stops spinning. Noise is NOT due to unbalanced load.
This may be due to a problem with the brakes, or there may be a problem with the support structure.
The first thing to do is to change out the pads and make sure the tub is sitting correctly on the structure.
