The washer pump has an approximately 1/8" diameter hole designed into it which is leaking small amounts of water, creating a mess on the floor. The machine works fine otherwise. I'm curious to know the intended function of this hole, and also to know what I should do. (By the way, the plate on the machine says WWA7070BALHA, two characters more than what I succeeded in searching with) Thanks, Jack
