Discuss
Agitator Is Locked Up
 in
Washer Repair
The agitator is locked up and will not spin, it is making a grinding noise. I've replaced the clutch assembly
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Agitator Is Locked Up
  #1 (permalink)
Old 07-02-2013, 10:19 AM
Junior Member
macman402 is on a distinguished road
Default Agitator Is Locked Up
Model Number: LSQ7030LQO   Brand: Whirlpool   Age: 1 - 5 years
The agitator is locked up and will not spin, it is making a grinding noise. I've replaced the clutch assembly approximately 1 month ago along with short cam agitator kit...
Related Models
Whirlpool LSQ7030LT0 WASHER - DIRECT DRIVE
Whirlpool LSQ7030MQ0 AUTOMATIC WASHER
Whirlpool LSQ7533JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ7533JQ1 WASHER
Whirlpool LSQ7533JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ7533JT1 WASHER
Whirlpool LSQ8000HQ0 WASHER
Whirlpool LSQ8000JQ0 WASHER
Whirlpool LSQ8000JQ1 WASHER
Whirlpool LSQ8000LQ0 WASHER
Whirlpool LSQ8000LQ1 AUTOMATIC WASHER
Whirlpool LSQ8000LQ2 AUTOMATIC WASHER
Whirlpool LSQ8000LQ3 AUTOMATIC WASHER
Whirlpool LSQ8200HQ0 AUTOMATIC WASHER
Whirlpool LSQ8200HZ0 AUTOMATIC WASHER
Whirlpool LSQ8220HQ0 AUTOMATIC WASHER
Whirlpool LSQ8243HQ0 AUTOMATIC WASHER
Whirlpool LSQ8243HZ0 AUTOMATIC WASHER
Whirlpool LSQ8500JQ0 AUTOMATIC WASHER
Whirlpool LSQ8500JQ1 WASHER
Whirlpool LSQ8500JQ2 WASHER
Whirlpool LSQ8500JT0 AUTOMATIC WASHER
Whirlpool LSQ8500JT1 WASHER
Whirlpool LSQ8500JT2 WASHER
Whirlpool LSQ8500LQ0 AUTOMATIC WASHER
Whirlpool LSQ8510LQ0 AUTOMATIC WASHER
Whirlpool LSQ8511KQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ8511KT0 WASHER - DIRECT DRIVE
Whirlpool LSQ8512KQ0 WASHER
Whirlpool LSQ8512KT0 WASHER
Whirlpool LSQ8520JQ0 AUTOMATIC WASHER
Whirlpool LSQ8520JQ1 WASHER
Whirlpool LSQ8543JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ8543JQ1 WASHER
Whirlpool LSQ8543JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ8543JT1 WASHER
Whirlpool LSQ8543JZ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ8543JZ1 WASHER
Whirlpool LSQ9010KQ0 WASHER
Whirlpool LSQ9010KT0 WASHER
Whirlpool LSQ9010LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9010LG1 AUTOMATIC WASHER
Whirlpool LSQ9010LG2 AUTOMATIC WASHER
Whirlpool LSQ9010LG3 AUTOMATIC WASHER
Whirlpool LSQ9010LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9010LQ1 AUTOMATIC WASHER
Whirlpool LSQ9010LQ2 AUTOMATIC WASHER
Whirlpool LSQ9010LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9010LW1 AUTOMATIC WASHER
Whirlpool LSQ9010LW2 AUTOMATIC WASHER
Whirlpool LSQ9010LW3 AUTOMATIC WASHER
Whirlpool LSQ9010PG0 AUTOMATIC WASHER
Whirlpool LSQ9010PG1 AUTOMATIC WASHER
Whirlpool LSQ9010PG2 AUTOMATIC WASHER
Whirlpool LSQ9010PG3 AUTOMATIC WASHER
Whirlpool LSQ9010PG5 AUTOMATIC WASHER
Whirlpool LSQ9010PG6 AUTOMATIC WASHER
Whirlpool LSQ9010PW0 AUTOMATIC WASHER
Whirlpool LSQ9010PW1 AUTOMATIC WASHER
Whirlpool LSQ9010PW2 AUTOMATIC WASHER
Whirlpool LSQ9010PW3 AUTOMATIC WASHER
Whirlpool LSQ9010PW5 AUTOMATIC WASHER
Whirlpool LSQ9010PW6 AUTOMATIC WASHER
Whirlpool LSQ9030PQ0 AUTOMATIC WASHER
Whirlpool LSQ9030PQ1 AUTOMATIC WASHER
Whirlpool LSQ9030PQ2 AUTOMATIC WASHER
Whirlpool LSQ9030PQ4 AUTOMATIC WASHER
Whirlpool LSQ9030PQ5 AUTOMATIC WASHER
Whirlpool LSQ9110KQ0 WASHER
Whirlpool LSQ9110KQ1 WASHER
Whirlpool LSQ9110LG0 WASHER
Whirlpool LSQ9110LG1 AUTOMATIC WASHER
Whirlpool LSQ9110LW0 WASHER
Whirlpool LSQ9110LW1 AUTOMATIC WASHER
Whirlpool LSQ9110PW0 AUTOMATIC WASHER
Whirlpool LSQ9110PW1 AUTOMATIC WASHER
Whirlpool LSQ9110PW2 AUTOMATIC WASHER
Whirlpool LSQ9110PW3 AUTOMATIC WASHER
Whirlpool LSQ9110PW4 AUTOMATIC WASHER
Whirlpool LSQ9200KQ0 WASHER
Whirlpool LSQ9200KT0 WASHER
Whirlpool LSQ9200LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9200LQ1 AUTOMATIC WASHER
Whirlpool LSQ9200LQ2 AUTOMATIC WASHER
Whirlpool LSQ9200LQ3 AUTOMATIC WASHER
Whirlpool LSQ9200LT0 WASHER - DIRECT DRIVE
Whirlpool LSQ9200LT1 AUTOMATIC WASHER
Whirlpool LSQ9200LT2 AUTOMATIC WASHER
Whirlpool LSQ9200LT3 AUTOMATIC WASHER
Whirlpool LSQ9200PQ0 AUTOMATIC WASHER
Whirlpool LSQ9200PQ1 AUTOMATIC WASHER
Whirlpool LSQ9200PQ3 AUTOMATIC WASHER
Whirlpool LSQ9200PQ4 AUTOMATIC WASHER
Whirlpool LSQ9200PT0 AUTOMATIC WASHER
Whirlpool LSQ9200PT1 AUTOMATIC WASHER
Whirlpool LSQ9200PT3 AUTOMATIC WASHER
Whirlpool LSQ9200PT4 AUTOMATIC WASHER
Whirlpool LSQ9210HQ0 AUTOMATIC WASHER
Whirlpool LSQ9210HZ0 AUTOMATIC WASHER
Whirlpool LSQ9211KQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9211KQ1 WASHER - DIRECT DRIVE
Whirlpool LSQ9211KT0 WASHER - DIRECT DRIVE
Whirlpool LSQ9211KT1 WASHER - DIRECT DRIVE
Whirlpool LSQ9244EQ0 AUTOMATIC WASHER
Whirlpool LSQ9244EZ0 AUTOMATIC WASHER
Whirlpool LSQ9264HQ0 AUTOMATIC WASHER
Whirlpool LSQ9264HZ0 AUTOMATIC WASHER
Whirlpool LSQ9500LQ0 WASHER
Whirlpool LSQ9500LT0 WASHER
Whirlpool LSQ9510JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9510JQ1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9510LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9510LT0 WASHER - DIRECT DRIVE
Whirlpool LSQ9520LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9520LT0 WASHER - DIRECT DRIVE
Whirlpool LSQ9544KQ0 WASHER
Whirlpool LSQ9544KT0 WASHER
Whirlpool LSQ9549LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9549LG1 AUTOMATIC WASHER
Whirlpool LSQ9549LG2 AUTOMATIC WASHER
  #2 (permalink)
Old 07-02-2013, 11:59 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Lower agitator or upper?
  #3 (permalink)
Old 07-02-2013, 02:06 PM
Junior Member
Default
It is the bottom agitator....
  #4 (permalink)
Old 07-02-2013, 02:11 PM
Expert
APP Volunteer
Default
Are you saying it won't agitate back and forth in agitate mode or it won't spin with the basket in spin mode?
Eric
  #5 (permalink)
Old 07-02-2013, 02:14 PM
Junior Member
Default
The basket will not spin at all....
  #6 (permalink)
Old 07-02-2013, 02:22 PM
Junior Member
Default
Water emptying but tub not spinning making grinding noise. Unable to manual turn tub
  #7 (permalink)
Old 07-02-2013, 02:37 PM
Expert
APP Volunteer
Default
Remove the cabinet, jump out the lid switch and run it in spin mode while observing the clutch hub. If the motor is spinning but the clutch hub is not, check the motor coupler. If it is good and is rotating the gearcase input shaft, the gearcase is bad. If the clutch hub is spinning either the clutch is faulty, brake cam driver faulty, brakes stuck, tub drive block faulty.
Motor must pause for a few seconds after drain in order to go into spin.
Eric
  #8 (permalink)
Old 07-02-2013, 02:40 PM
Junior Member
Default
Thanks, I will try that
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Cannot Separate the Upper Agitator (mover) from the Lower Agitator Celodea Washer Repair 3 11-20-2013 11:31 AM
agitator and drum locked up Edward80 Washer Repair 1 10-22-2012 06:25 PM
GE Profile Washer Drum is locked to agitator Knutervalve00 Washer Repair 19 05-23-2010 08:01 PM
Oven Clock , Locked door display blinking but not locked RaviM Oven Repair (including Ranges and Cooktops) 2 08-05-2009 05:47 PM
Kenmore washer 80 top agitator does not move with bottom agitator erbaker Washer Repair 1 02-19-2008 11:11 AM
