Discuss
Whirlpool Washer Brake out of Sync
 in
Washer Repair
When working the water should pump out with the brake on so basket will not spin. After the water is
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Washer Brake out of Sync
  #1 (permalink)
Old 07-01-2013, 03:41 PM
Junior Member
Handyman Randy is on a distinguished road
Default Whirlpool Washer Brake out of Sync
Brand: Whirlpool   Age: 1 - 5 years
When working the water should pump out with the brake on so basket will not spin. After the water is out a short stop and the brake should disengage and let the basket spin.
Mine is spinning as it pumps out the water. Then stops and sets the brake so it will not spin. So the last part the basket is not spinning.
In short the brake is off at start and on at the end of the spin and rinse.
Top load Whirlpool Estate
  #2 (permalink)
Old 07-01-2013, 03:58 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Neutral drain mechanism in the gearcase is not working. What is your washer model number?
Eric
  #3 (permalink)
Old 07-01-2013, 04:11 PM
Junior Member
Default
Quote:
Eric
TAWS850PQ0
  #4 (permalink)
Old 07-01-2013, 06:07 PM
Expert
APP Volunteer
Default
You can either replace the gearcase or replace the neutral drain mechanism inside the gearcase.
Whirlpool 3360629 Neutral Drain Transmission - AppliancePartsPros.com
Whirlpool 388253 Neutral Drain Kit - AppliancePartsPros.com
Eric
  #5 (permalink)
Old 07-01-2013, 06:46 PM
Junior Member
Default
Eric
I've got an extra transmition so I'll switch them and see if that fixes it.
  #6 (permalink)
Old 07-04-2013, 02:19 PM
Junior Member
Default
Thanks Eric,
I switched transmisssion with one of my haul off machines. It works, Yea.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer seems out of sync Sanders24 Dryer Repair 0 04-01-2012 12:40 PM
whirlpool brake cam dave maxwell Washer Repair 1 09-20-2011 06:55 PM
Compressor/evaporater fan sync C.David Refrigerator & Freezer Repair 1 09-19-2010 07:42 AM
Brake on whirlpool washer mechanic Washer Repair 8 11-02-2009 01:33 AM
Whirlpool belt drive washer has brake noise when stopping macirion Washer Repair 0 08-08-2009 04:43 PM
